DNS issue with mbed-http
I have a weird issue on Ethernet interface.
Indeed, I connect my Nucleo-F767ZI board through an ethernet connection in DHCP.
It works almost well, indeed the ip address, gateway, netmask are ok but the DNS server is NULL.
If I connect my laptop to the same network cable then the DNS is set with the same IP as the gateway.
So, why the DNS is empty in DHCP mode ?
Here is my code:
_ethernetInterface.set_dhcp(true);
_ethernetInterface.connect();
nsapi_connection_status status = _ethernetInterface.get_connection_status();
printf("Status = %d\r\n", status);
SocketAddress address;
_ethernetInterface.get_ip_address(&address);
printf("IP : %s\r\n", address.get_ip_address() ? address.get_ip_address() : "None");
SocketAddress netmask;
_ethernetInterface.get_netmask(&netmask);
SocketAddress addressGateway;
_ethernetInterface.get_gateway(&addressGateway);
printf("IP Gateway : %s\r\n", addressGateway.get_ip_address() ? addressGateway.get_ip_address() : "None");
SocketAddress addressDns;
_ethernetInterface.get_dns_server(0, &addressDns);
printf("IP DNS = %s\r\n", addressDns.get_ip_address() ? addressDns.get_ip_address() : "None");
Thanks
Frédéric
I have the same problem as you with F767ZI. I tried to add dns server with add_dns_server and fails too. Any tips to debug it would be appreciated. Regards
Well I didn’t find a way to make it works. So I decided to detect the ethernet connection state ( using interruption attach ) and then to retrieve the gateway ip address and assign it to the gateway…
ethernetInterface->set_blocking(false);
ethernetInterface->attach(&EthernetConnectionCallback);
ethernetInterface->set_dhcp(true);
result = ethernetInterface->get_gateway(&addressGateway);
result = ethernetInterface->add_dns_server(addressGateway, NULL);
If you find another way to make it works, I will be very pleased !
Kind regards,
Frédéric
