I’m configuring three different EXT IRs on my STM32L476RG chip on Pins PA_9 (USB), PB_4 (ADC Data ready 1) and PC_6 (ADC Data ready 2).
During my procedure I’m enabling and disabling/enabling the interrupt by resetting/creating an InterruptIn object on the heap via
_rdy_ir.reset();
_rdy_ir = std::make_unique<mbed::InterruptIn>(_rdy_pin, mode);
_rdy_ir->fall(readyCallback); // RDY goes low every time a conversion is ready
From time to time I’m running into a hard fault which is produced when an interrupt is called (see gpio_irq_api.c):
++ MbedOS Error Info ++
Error Value: 0x0
For more info, visit: https://mbed.com/s/error?error=0x80FF0100&tgt=NUCLEO_L476RG
-- MbedOS Error Info --
Unexpected Spurious interrupt index 5
Does anyone know how this error is appearing. I mean the InterruptIn object should be properly reset when the destructor is called.
Thank you.
Edit: I also tried to just set the interrupt once and disable/ the interrupt via _rdy_ir->disable_irq()/enable_irq( ) → same error
