Hello!
I am currently trying to set up communication over TLS (over Ethernet) between two NUCLEO-F439ZI microcontrollers. I currently have a curious bug that I can’t seem to diagnose. I can get the TLS handshake to complete but when I try to read/write over TLS using mbedtls_ssl_read() and mbedtls_ssl_write() I get a fatal error. The fatal error appears to occur when the client/server connect to each other, before the handshake, even though the read/write is after the handshake.
Interestingly, I also get a stack overflow error during the TLS handshake if I set the mbedtls debug level to 3 or higher – seemingly when they try to print out a certificate in the debug output.
I can’t really get my head around what could be causing this so any help/thoughts would be greatly appreciated. Server and client test programs are attached below (they are modified versions of the ssl_server.c and ssl_client1.c files included in Mbed TLS) with the error causing code commented out at the end of each file. If there’s anything else I can provide to help debug this please let me know.
(Currently programming in Mbed Studio with the GCC_ARM compiler and the Debug build profile.)
tls_server/main.c:
#include "EthernetInterface.h"
#include "mbedtls/x509.h"
#include "mbedtls/certs.h"
#if defined(MBEDTLS_SSL_CACHE_C)
#include "mbedtls/ssl_cache.h"
#endif
#include <cstdio>
TCPSocket *client_sock; // srv.accept() will return pointer to socket
TCPSocket srv;
#define HTTP_RESPONSE \
"HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n" \
"<h2>mbed TLS Test Server</h2>\r\n" \
"<p>Successful connection using: %s</p>\r\n"
int sslSend(void *ctx, const unsigned char *buf, size_t len)
int ret = client_sock->send(buf, len);
if (ret == NSAPI_ERROR_WOULD_BLOCK)
ret = MBEDTLS_ERR_SSL_WANT_WRITE;
else if (ret < 0)
mbedtls_printf("socket.send() returned %d\n", ret);
return ret;
int sslRecv(void *ctx, unsigned char *buf, size_t len)
int ret = client_sock->recv(buf, len);
ret = MBEDTLS_ERR_SSL_WANT_READ;
else if (ret < 0)
mbedtls_printf("socket.recv() returned %d\n", ret);
return ret;
void sslDebug(void *ctx, int level, const char *file,
int line, const char *str)
(void)ctx;
const char *p, *basename;
/* Extract basename from file */
for (p = basename = file; *p != '\0'; p++) {
if (*p == '/' || *p == '\\')
basename = p + 1;
mbedtls_printf("%s:%d: |%d| %s\r", basename, line, level, str);
printf("TLS server example\n");
EthernetInterface eth;
mbedtls_ssl_context ssl;
mbedtls_ssl_config ssl_conf;
mbedtls_x509_crt srvcert;
mbedtls_pk_context pkey;
mbedtls_ssl_cache_context cache;
#endif
int ret = 0;
if((ret = mbedtls_platform_setup(NULL)) != 0) {
mbedtls_printf("Platform initialization failed with error %d\r\n", ret);
return 1;
const char *DRBG_PERSONALIZED_STR = "teststring";
mbedtls_ssl_init(&ssl);
mbedtls_ssl_config_init(&ssl_conf);
mbedtls_ssl_cache_init( &cache );
#endif
mbedtls_x509_crt_init( &srvcert );
mbedtls_pk_init( &pkey );
mbedtls_entropy_init(&entropy);
mbedtls_ctr_drbg_init(&ctr_drbg);
#if defined(MBEDTLS_DEBUG_C)
mbedtls_debug_set_threshold( 2 );
#endif
int len;
unsigned char buf[1024];
* 1. Load the certificates and private RSA key
mbedtls_printf( "\n . Loading the server cert. and key..." );
fflush( stdout );
ret = mbedtls_x509_crt_parse( &srvcert, (const unsigned char *) mbedtls_test_srv_crt,
mbedtls_test_srv_crt_len );
if( ret != 0 )
mbedtls_printf( " failed\n ! mbedtls_x509_crt_parse returned %d\n\n", ret );
ret = mbedtls_x509_crt_parse( &srvcert, (const unsigned char *) mbedtls_test_cas_pem,
mbedtls_test_cas_pem_len );
if( ret != 0 )
ret = mbedtls_pk_parse_key( &pkey, (const unsigned char *) mbedtls_test_srv_key,
mbedtls_test_srv_key_len, NULL, 0 );
if( ret != 0 )
mbedtls_printf( " failed\n ! mbedtls_pk_parse_key returned %d\n\n", ret );
mbedtls_printf( " ok\n" );
* 2. Setup the listening TCP socket
SocketAddress ip;
ip.set_ip_address("10.10.0.1");
SocketAddress mask;
mask.set_ip_address("255.255.255.0");
SocketAddress gateway;
gateway.set_ip_address("10.10.0.0");
eth.set_network(ip, mask, gateway);
eth.connect();
SocketAddress a;
eth.get_ip_address(&a);
printf(" . Bind on %s ...", a.get_ip_address() ? a.get_ip_address() : "None");
/* Open the server on ethernet stack */
srv.open(ð);
/* Bind the port (TCP 4433) to the server */
srv.bind(4433);
mbedtls_printf(" ok\n");
* 3. Seed the RNG
mbedtls_printf(" . Seeding the random number generator...");
fflush(stdout);
ret = mbedtls_ctr_drbg_seed(&ctr_drbg, mbedtls_entropy_func, &entropy,
(const unsigned char *)DRBG_PERSONALIZED_STR,
strlen(DRBG_PERSONALIZED_STR) + 1);
if (ret != 0) {
mbedtls_printf("mbedtls_ctr_drbg_seed() returned -0x%04X\n", -ret);
return ret;
* 4. Setup stuff
mbedtls_printf(" . Setting up the SSL data...");
fflush(stdout);
ret = mbedtls_ssl_config_defaults(&ssl_conf, MBEDTLS_SSL_IS_SERVER,
MBEDTLS_SSL_TRANSPORT_STREAM,
MBEDTLS_SSL_PRESET_DEFAULT);
if (ret != 0) {
mbedtls_printf("mbedtls_ssl_config_defaults() returned -0x%04X\n",
-ret);
return ret;
mbedtls_ssl_conf_rng(&ssl_conf, mbedtls_ctr_drbg_random, &ctr_drbg);
mbedtls_ssl_conf_dbg(&ssl_conf, sslDebug, stdout);
mbedtls_ssl_conf_session_cache( &ssl_conf, &cache,
mbedtls_ssl_cache_get,
mbedtls_ssl_cache_set );
#endif
mbedtls_ssl_conf_ca_chain( &ssl_conf, srvcert.next, NULL );
if( ( ret = mbedtls_ssl_conf_own_cert( &ssl_conf, &srvcert, &pkey ) ) != 0 )
mbedtls_printf( " failed\n ! mbedtls_ssl_conf_own_cert returned %d\n\n", ret );
if ((ret = mbedtls_ssl_setup( &ssl, &ssl_conf)) != 0) {
mbedtls_printf("mbedtls_ssl_setup() returned -0x%04X\n", -ret);
return ret;
mbedtls_ssl_session_reset(&ssl);
* 3. Wait until a client connects
mbedtls_printf(" . Waiting for a remote connection ...");
fflush(stdout);
srv.listen(1);
client_sock = srv.accept(); //return pointer of a client socket
mbedtls_ssl_set_bio(&ssl, static_cast<void *>(&client_sock), sslSend, sslRecv, NULL);
* 5. Handshake
mbedtls_printf(" . Performing the TLS handshake...");
fflush(stdout);
do {
ret = mbedtls_ssl_handshake(&ssl);
} while(ret != 0 &&
(ret == MBEDTLS_ERR_SSL_WANT_READ ||
ret == MBEDTLS_ERR_SSL_WANT_WRITE));
if (ret < 0) {
mbedtls_printf("failed \n mbedtls_ssl_handshake() returned -0x%04X\n", -ret);
return ret;
* 6. Read the HTTP Request
// mbedtls_printf(" < Read from client:");
// fflush(stdout);
// do
// len = sizeof(buf) - 1;
// memset(buf, 0, sizeof(buf));
// ret = mbedtls_ssl_read(&ssl, buf, len);
// if (ret == MBEDTLS_ERR_SSL_WANT_READ || ret == MBEDTLS_ERR_SSL_WANT_WRITE)
// continue;
// if (ret <= 0)
// switch (ret)
// case MBEDTLS_ERR_SSL_PEER_CLOSE_NOTIFY:
// mbedtls_printf(" connection was closed gracefully\n");
// break;
// default:
// mbedtls_printf(" mbedtls_ssl_read returned -0x%x\n", (unsigned int)-ret);
// break;
// break;
// len = ret;
// mbedtls_printf(" %d bytes read\n\n%s", len, (char *)buf);
// if (ret > 0)
// break;
// } while (1);
* 7. Write the 200 Response
// mbedtls_printf(" > Write to client:");
// fflush(stdout);
// len = sprintf((char *)buf, HTTP_RESPONSE,
// mbedtls_ssl_get_ciphersuite(&ssl));
// while ((ret = mbedtls_ssl_write(&ssl, buf, len)) <= 0)
// if (ret != MBEDTLS_ERR_SSL_WANT_READ && ret != MBEDTLS_ERR_SSL_WANT_WRITE)
// mbedtls_printf(" failed\n ! mbedtls_ssl_write returned %d\n\n", ret);
// goto exit;
// len = ret;
// mbedtls_printf(" %d bytes written\n\n%s\n", len, (char *)buf);
// mbedtls_printf(" . Closing the connection...");
// while ((ret = mbedtls_ssl_close_notify(&ssl)) < 0)
// ret != MBEDTLS_ERR_SSL_WANT_WRITE)
// mbedtls_printf(" failed\n ! mbedtls_ssl_close_notify returned %d\n\n", ret);
// goto reset;
// mbedtls_printf(" ok\n");
ret = 0;
exit:
// teardown
mbedtls_x509_crt_free( &srvcert );
mbedtls_pk_free( &pkey );
mbedtls_entropy_free(&entropy);
mbedtls_ctr_drbg_free(&ctr_drbg);
mbedtls_ssl_free(&ssl);
mbedtls_ssl_config_free(&ssl_conf);
mbedtls_platform_teardown(NULL);
client_sock->close();
eth.disconnect();
printf("Done\n");
return ret;
tls_client/main.c:
#include "mbedtls/debug.h"
#define GET_REQUEST "GET / HTTP/1.0\r\n\r\n"
const char *HTTP_REQUEST_FILE_PATH = "/media/uploads/mbed_official/hello.txt";
TCPSocket socket;
int ret = socket.send(buf, len);
else if (ret < 0)
return ret;
int ret = socket.recv(buf, len);
else if (ret < 0)
return ret;
(void)ctx;
basename = p + 1;
printf("TLS client example\n");
mbedtls_x509_crt cacert;
#endif
int ret = 0, len;
* 0. Initialize the RNG and the session data
mbedtls_x509_crt_init( &cacert );
mbedtls_printf("\n . Seeding the random number generator...");
fflush(stdout);
if (ret != 0) {
return ret;
* 0. Initialize certificates
mbedtls_printf( " . Loading the CA root certificate ..." );
fflush( stdout );
ret = mbedtls_x509_crt_parse( &cacert, (const unsigned char *) mbedtls_test_cas_pem,
if( ret < 0 )
mbedtls_printf( " failed\n ! mbedtls_x509_crt_parse returned -0x%x\n\n", (unsigned int) -ret );
mbedtls_printf( " ok (%d skipped)\n", ret );
* 1. Start the connection
SocketAddress ip;
ip.set_ip_address("10.10.0.2");
SocketAddress mask;
eth.connect();
socket.open(ð);
socket.set_blocking(false);
SocketAddress a;
a.set_ip_address("10.10.0.1");
a.set_port(4433);
printf(" . Connecting on %s:%d ...", a.get_ip_address(), a.get_port());
fflush(stdout);
if ((ret = socket.connect(a)) != NSAPI_ERROR_OK) {
mbedtls_printf("socket.connect() returned %d\n", ret);
return ret;
* 2. Setup stuff
mbedtls_printf(" . Setting up the SSL/TLS structure...");
fflush(stdout);
ret = mbedtls_ssl_config_defaults(&ssl_conf, MBEDTLS_SSL_IS_CLIENT,
if (ret != 0) {
-ret);
return ret;
mbedtls_ssl_conf_authmode( &ssl_conf, MBEDTLS_SSL_VERIFY_OPTIONAL );
mbedtls_ssl_conf_ca_chain( &ssl_conf, &cacert, NULL );
mbedtls_ssl_conf_dbg(&ssl_conf, sslDebug, NULL);
return ret;
if( ( ret = mbedtls_ssl_set_hostname( &ssl, "10.10.0.1") ) != 0 )
mbedtls_printf( " failed\n ! mbedtls_ssl_set_hostname returned %d\n\n", ret );
goto exit;
mbedtls_ssl_set_bio(&ssl, &socket, sslSend, sslRecv, NULL);
* 4. Handshake
fflush(stdout);
do {
} while(ret != 0 &&
if (ret < 0) {
mbedtls_printf("mbedtls_ssl_handshake() returned -0x%04X\n", -ret);
return ret;
* 6. Write the GET request
// mbedtls_printf(" > Write to server:");
// fflush(stdout);
// len = sprintf((char *)buf, GET_REQUEST);
// goto exit;
// len = ret;
// mbedtls_printf(" %d bytes written\n\n%s", len, (char *)buf);
* 7. Read the HTTP response
// mbedtls_printf(" < Read from server:");
// fflush(stdout);
// do
// continue;
// if (ret == MBEDTLS_ERR_SSL_PEER_CLOSE_NOTIFY)
// break;
// if (ret < 0)
// mbedtls_printf("failed\n ! mbedtls_ssl_read returned %d\n\n", ret);
// break;
// if (ret == 0)
// mbedtls_printf("\n\nEOF\n\n");
// break;
// len = ret;
// } while (1);
mbedtls_ssl_close_notify(&ssl);
exit:
// teardown
// Close the socket to return its memory and bring down the network interface
socket.close();
// Bring down the ethernet interface
eth.disconnect();
printf("Done\n");
return(ret);
