Here is the mbedConfig.h file
#ifndef MBEDTLS_CONFIG_H
#define MBEDTLS_CONFIG_H
#if defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
#define _CRT_SECURE_NO_DEPRECATE 1
#endif
- \name SECTION: System support
- This section sets system specific settings.
#define MBEDTLS_HAVE_ASM
#define MBEDTLS_HAVE_TIME
#define MBEDTLS_HAVE_TIME_DATE
//#define MBEDTLS_PLATFORM_MEMORY
//#define MBEDTLS_PLATFORM_NO_STD_FUNCTIONS
//#define MBEDTLS_PLATFORM_EXIT_ALT
//#define MBEDTLS_PLATFORM_TIME_ALT
//#define MBEDTLS_PLATFORM_FPRINTF_ALT
//#define MBEDTLS_PLATFORM_PRINTF_ALT
//#define MBEDTLS_PLATFORM_SNPRINTF_ALT
//#define MBEDTLS_PLATFORM_NV_SEED_ALT
//#define MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT
//#define MBEDTLS_DEPRECATED_WARNING
//#define MBEDTLS_DEPRECATED_REMOVED
/* } name SECTION: System support */
//#define MBEDTLS_TIMING_ALT
//#define MBEDTLS_AES_ALT
//#define MBEDTLS_ARC4_ALT
//#define MBEDTLS_ARIA_ALT
//#define MBEDTLS_BLOWFISH_ALT
//#define MBEDTLS_CAMELLIA_ALT
//#define MBEDTLS_CCM_ALT
//#define MBEDTLS_CMAC_ALT
//#define MBEDTLS_DES_ALT
//#define MBEDTLS_DHM_ALT
//#define MBEDTLS_ECJPAKE_ALT
//#define MBEDTLS_GCM_ALT
//#define MBEDTLS_MD2_ALT
//#define MBEDTLS_MD4_ALT
//#define MBEDTLS_MD5_ALT
//#define MBEDTLS_RIPEMD160_ALT
//#define MBEDTLS_RSA_ALT
//#define MBEDTLS_SHA1_ALT
//#define MBEDTLS_SHA256_ALT
//#define MBEDTLS_SHA512_ALT
//#define MBEDTLS_XTEA_ALT
//#define MBEDTLS_ECP_ALT
//#define MBEDTLS_MD2_PROCESS_ALT
//#define MBEDTLS_MD4_PROCESS_ALT
//#define MBEDTLS_MD5_PROCESS_ALT
//#define MBEDTLS_RIPEMD160_PROCESS_ALT
//#define MBEDTLS_SHA1_PROCESS_ALT
//#define MBEDTLS_SHA256_PROCESS_ALT
//#define MBEDTLS_SHA512_PROCESS_ALT
//#define MBEDTLS_DES_SETKEY_ALT
//#define MBEDTLS_DES_CRYPT_ECB_ALT
//#define MBEDTLS_DES3_CRYPT_ECB_ALT
//#define MBEDTLS_AES_SETKEY_ENC_ALT
//#define MBEDTLS_AES_SETKEY_DEC_ALT
//#define MBEDTLS_AES_ENCRYPT_ALT
//#define MBEDTLS_AES_DECRYPT_ALT
//#define MBEDTLS_ECDH_GEN_PUBLIC_ALT
//#define MBEDTLS_ECDH_COMPUTE_SHARED_ALT
//#define MBEDTLS_ECDSA_VERIFY_ALT
//#define MBEDTLS_ECDSA_SIGN_ALT
//#define MBEDTLS_ECDSA_GENKEY_ALT
/* Required for all the functions in this section /
//#define MBEDTLS_ECP_INTERNAL_ALT
/ Support for Weierstrass curves with Jacobi representation /
//#define MBEDTLS_ECP_RANDOMIZE_JAC_ALT
//#define MBEDTLS_ECP_ADD_MIXED_ALT
//#define MBEDTLS_ECP_DOUBLE_JAC_ALT
//#define MBEDTLS_ECP_NORMALIZE_JAC_MANY_ALT
//#define MBEDTLS_ECP_NORMALIZE_JAC_ALT
/ Support for curves with Montgomery arithmetic */
//#define MBEDTLS_ECP_DOUBLE_ADD_MXZ_ALT
//#define MBEDTLS_ECP_RANDOMIZE_MXZ_ALT
//#define MBEDTLS_ECP_NORMALIZE_MXZ_ALT
//#define MBEDTLS_TEST_NULL_ENTROPY
//#define MBEDTLS_ENTROPY_HARDWARE_ALT
//#define MBEDTLS_AES_ROM_TABLES
//#define MBEDTLS_AES_FEWER_TABLES
//#define MBEDTLS_CAMELLIA_SMALL_MEMORY
- \def MBEDTLS_CIPHER_MODE_CBC
- Enable Cipher Block Chaining mode (CBC) for symmetric ciphers.
#define MBEDTLS_CIPHER_MODE_CBC
- \def MBEDTLS_CIPHER_MODE_CFB
- Enable Cipher Feedback mode (CFB) for symmetric ciphers.
#define MBEDTLS_CIPHER_MODE_CFB
- \def MBEDTLS_CIPHER_MODE_CTR
- Enable Counter Block Cipher mode (CTR) for symmetric ciphers.
#define MBEDTLS_CIPHER_MODE_CTR
- \def MBEDTLS_CIPHER_MODE_OFB
- Enable Output Feedback mode (OFB) for symmetric ciphers.
#define MBEDTLS_CIPHER_MODE_OFB
- \def MBEDTLS_CIPHER_MODE_XTS
- Enable Xor-encrypt-xor with ciphertext stealing mode (XTS) for AES.
#define MBEDTLS_CIPHER_MODE_XTS
- \def MBEDTLS_CIPHER_NULL_CIPHER
- Enable NULL cipher.
- Warning: Only do so when you know what you are doing. This allows for
- encryption or channels without any security!
- Requires MBEDTLS_ENABLE_WEAK_CIPHERSUITES as well to enable
- the following ciphersuites:
MBEDTLS_TLS_ECDH_ECDSA_WITH_NULL_SHA
MBEDTLS_TLS_ECDH_RSA_WITH_NULL_SHA
MBEDTLS_TLS_ECDHE_ECDSA_WITH_NULL_SHA
MBEDTLS_TLS_ECDHE_RSA_WITH_NULL_SHA
MBEDTLS_TLS_ECDHE_PSK_WITH_NULL_SHA384
MBEDTLS_TLS_ECDHE_PSK_WITH_NULL_SHA256
MBEDTLS_TLS_DHE_PSK_WITH_NULL_SHA384
MBEDTLS_TLS_DHE_PSK_WITH_NULL_SHA256
MBEDTLS_TLS_RSA_WITH_NULL_SHA256
MBEDTLS_TLS_RSA_WITH_NULL_MD5
MBEDTLS_TLS_RSA_PSK_WITH_NULL_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_NULL_SHA256
MBEDTLS_TLS_PSK_WITH_NULL_SHA384
MBEDTLS_TLS_PSK_WITH_NULL_SHA256
- Uncomment this macro to enable the NULL cipher and ciphersuites
//#define MBEDTLS_CIPHER_NULL_CIPHER
- \def MBEDTLS_CIPHER_PADDING_PKCS7
- MBEDTLS_CIPHER_PADDING_XXX: Uncomment or comment macros to add support for
- specific padding modes in the cipher layer with cipher modes that support
- padding (e.g. CBC)
- If you disable all padding modes, only full blocks can be used with CBC.
- Enable padding modes in the cipher layer.
#define MBEDTLS_CIPHER_PADDING_PKCS7
#define MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS
#define MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN
//#define MBEDTLS_ENABLE_WEAK_CIPHERSUITES
#define MBEDTLS_REMOVE_ARC4_CIPHERSUITES
- \def MBEDTLS_ECP_DP_SECP192R1_ENABLED
- MBEDTLS_ECP_XXXX_ENABLED: Enables specific curves within the Elliptic Curve
- module. By default all supported curves are enabled.
- Comment macros to disable the curve and functions for it
#define MBEDTLS_ECP_DP_SECP192R1_ENABLED
#define MBEDTLS_ECP_DP_SECP224R1_ENABLED
#define MBEDTLS_ECP_DP_SECP256R1_ENABLED
#define MBEDTLS_ECP_DP_SECP384R1_ENABLED
#define MBEDTLS_ECP_DP_SECP521R1_ENABLED
#define MBEDTLS_ECP_DP_SECP192K1_ENABLED
#define MBEDTLS_ECP_DP_SECP224K1_ENABLED
#define MBEDTLS_ECP_DP_SECP256K1_ENABLED
#define MBEDTLS_ECP_DP_BP256R1_ENABLED
#define MBEDTLS_ECP_DP_BP384R1_ENABLED
#define MBEDTLS_ECP_DP_BP512R1_ENABLED
#define MBEDTLS_ECP_DP_CURVE25519_ENABLED
#define MBEDTLS_ECP_DP_CURVE448_ENABLED
#define MBEDTLS_ECP_NIST_OPTIM
#define MBEDTLS_ECDSA_DETERMINISTIC
- \def MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
- Enable the PSK based ciphersuite modes in SSL / TLS.
- This enables the following ciphersuites (if other requisites are
- enabled as well):
MBEDTLS_TLS_PSK_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_PSK_WITH_AES_256_CBC_SHA384
MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_GCM_SHA384
MBEDTLS_TLS_PSK_WITH_CAMELLIA_256_CBC_SHA384
MBEDTLS_TLS_PSK_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_PSK_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_PSK_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_PSK_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_PSK_WITH_RC4_128_SHA
#define MBEDTLS_KEY_EXCHANGE_PSK_ENABLED
#define MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED
#define MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED
- Enable the RSA-PSK based ciphersuite modes in SSL / TLS.
- Requires: MBEDTLS_RSA_C, MBEDTLS_PKCS1_V15,
MBEDTLS_X509_CRT_PARSE_C
- enabled as well):
MBEDTLS_TLS_RSA_PSK_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_AES_256_CBC_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_256_GCM_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_256_CBC_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_RSA_PSK_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_RSA_PSK_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_RSA_PSK_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_RSA_PSK_WITH_RC4_128_SHA
#define MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_RSA_ENABLED
- Enable the RSA-only based ciphersuite modes in SSL / TLS.
- enabled as well):
MBEDTLS_TLS_RSA_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_RSA_WITH_AES_256_CBC_SHA256
MBEDTLS_TLS_RSA_WITH_CAMELLIA_256_GCM_SHA384
MBEDTLS_TLS_RSA_WITH_CAMELLIA_256_CBC_SHA256
MBEDTLS_TLS_RSA_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_RSA_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_RSA_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_RSA_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_RSA_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_RSA_WITH_RC4_128_SHA
MBEDTLS_TLS_RSA_WITH_RC4_128_MD5
#define MBEDTLS_KEY_EXCHANGE_RSA_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED
- Enable the DHE-RSA based ciphersuite modes in SSL / TLS.
- Requires: MBEDTLS_DHM_C, MBEDTLS_RSA_C, MBEDTLS_PKCS1_V15,
- enabled as well):
MBEDTLS_TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_256_GCM_SHA384
MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
- \warning Using DHE constitutes a security risk as it
is not possible to validate custom DH parameters.
If possible, it is recommended users should consider
preferring other methods of key exchange.
See dhm.h for more details.
#define MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED
- Enable the ECDHE-RSA based ciphersuite modes in SSL / TLS.
- Requires: MBEDTLS_ECDH_C, MBEDTLS_RSA_C, MBEDTLS_PKCS1_V15,
- enabled as well):
MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384
MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_ECDHE_RSA_WITH_RC4_128_SHA
#define MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
- Enable the ECDHE-ECDSA based ciphersuite modes in SSL / TLS.
- Requires: MBEDTLS_ECDH_C, MBEDTLS_ECDSA_C, MBEDTLS_X509_CRT_PARSE_C,
- enabled as well):
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_ECDSA_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_ECDHE_ECDSA_WITH_RC4_128_SHA
#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED
- Enable the ECDH-ECDSA based ciphersuite modes in SSL / TLS.
- Requires: MBEDTLS_ECDH_C, MBEDTLS_X509_CRT_PARSE_C
- enabled as well):
MBEDTLS_TLS_ECDH_ECDSA_WITH_RC4_128_SHA
MBEDTLS_TLS_ECDH_ECDSA_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA
MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA
MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384
MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_256_CBC_SHA384
MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_ECDH_ECDSA_WITH_CAMELLIA_256_GCM_SHA384
#define MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED
- \def MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED
- Enable the ECDH-RSA based ciphersuite modes in SSL / TLS.
- enabled as well):
MBEDTLS_TLS_ECDH_RSA_WITH_RC4_128_SHA
MBEDTLS_TLS_ECDH_RSA_WITH_3DES_EDE_CBC_SHA
MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA
MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA
MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256
MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384
MBEDTLS_TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256
MBEDTLS_TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384
MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_128_CBC_SHA256
MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_256_CBC_SHA384
MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_128_GCM_SHA256
MBEDTLS_TLS_ECDH_RSA_WITH_CAMELLIA_256_GCM_SHA384
#define MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED
//#define MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED
#define MBEDTLS_PK_PARSE_EC_EXTENDED
#define MBEDTLS_ERROR_STRERROR_DUMMY
- \def MBEDTLS_GENPRIME
- Enable the prime-number generation code.
- Requires: MBEDTLS_BIGNUM_C
#define MBEDTLS_GENPRIME
- \def MBEDTLS_FS_IO
- Enable functions that use the filesystem.
#define MBEDTLS_FS_IO
//#define MBEDTLS_NO_DEFAULT_ENTROPY_SOURCES
- \def MBEDTLS_NO_PLATFORM_ENTROPY
- Do not use built-in platform entropy functions.
- This is useful if your platform does not support
- standards like the /dev/urandom or Windows CryptoAPI.
- Uncomment this macro to disable the built-in platform entropy functions.
//#define MBEDTLS_NO_PLATFORM_ENTROPY
//#define MBEDTLS_ENTROPY_FORCE_SHA256
//#define MBEDTLS_ENTROPY_NV_SEED
//#define MBEDTLS_MEMORY_DEBUG
//#define MBEDTLS_MEMORY_BACKTRACE
#define MBEDTLS_PK_RSA_ALT_SUPPORT
#define MBEDTLS_PKCS1_V15
#define MBEDTLS_PKCS1_V21
//#define MBEDTLS_RSA_NO_CRT
#define MBEDTLS_SELF_TEST
//#define MBEDTLS_SHA256_SMALLER
#define MBEDTLS_SSL_ALL_ALERT_MESSAGES
//#define MBEDTLS_SSL_ASYNC_PRIVATE
//#define MBEDTLS_SSL_DEBUG_ALL
#define MBEDTLS_SSL_ENCRYPT_THEN_MAC
#define MBEDTLS_SSL_EXTENDED_MASTER_SECRET
#define MBEDTLS_SSL_FALLBACK_SCSV
//#define MBEDTLS_SSL_HW_RECORD_ACCEL
#define MBEDTLS_SSL_CBC_RECORD_SPLITTING
#define MBEDTLS_SSL_RENEGOTIATION
//#define MBEDTLS_SSL_SRV_SUPPORT_SSLV2_CLIENT_HELLO
- \def MBEDTLS_SSL_SRV_RESPECT_CLIENT_PREFERENCE
- Pick the ciphersuite according to the client’s preferences rather than ours
- in the SSL Server module (MBEDTLS_SSL_SRV_C).
- Uncomment this macro to respect client’s ciphersuite order
//#define MBEDTLS_SSL_SRV_RESPECT_CLIENT_PREFERENCE
#define MBEDTLS_SSL_MAX_FRAGMENT_LENGTH
#define MBEDTLS_SSL_PROTO_TLS1
#define MBEDTLS_SSL_PROTO_TLS1_1
#define MBEDTLS_SSL_PROTO_TLS1_2
#define MBEDTLS_SSL_PROTO_DTLS
#define MBEDTLS_SSL_ALPN
#define MBEDTLS_SSL_DTLS_ANTI_REPLAY
#define MBEDTLS_SSL_DTLS_HELLO_VERIFY
#define MBEDTLS_SSL_DTLS_CLIENT_PORT_REUSE
#define MBEDTLS_SSL_DTLS_BADMAC_LIMIT
#define MBEDTLS_SSL_SESSION_TICKETS
#define MBEDTLS_SSL_EXPORT_KEYS
#define MBEDTLS_SSL_SERVER_NAME_INDICATION
#define MBEDTLS_SSL_TRUNCATED_HMAC
//#define MBEDTLS_SSL_TRUNCATED_HMAC_COMPAT
//#define MBEDTLS_THREADING_ALT
//#define MBEDTLS_THREADING_PTHREAD
#define MBEDTLS_VERSION_FEATURES
//#define MBEDTLS_X509_ALLOW_EXTENSIONS_NON_V3
#define MBEDTLS_X509_CHECK_KEY_USAGE
#define MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE
- \def MBEDTLS_X509_RSASSA_PSS_SUPPORT
- Enable parsing and verification of X.509 certificates, CRLs and CSRS
- signed with RSASSA-PSS (aka PKCS#1 v2.1).
- Comment this macro to disallow using RSASSA-PSS in certificates.
#define MBEDTLS_X509_RSASSA_PSS_SUPPORT
- \def MBEDTLS_AESNI_C
- Enable AES-NI support on x86-64.
- Module: library/aesni.c
- Caller: library/aes.c
- Requires: MBEDTLS_HAVE_ASM
- This modules adds support for the AES-NI instructions on x86-64
#define MBEDTLS_AESNI_C
#define MBEDTLS_AES_C
#define MBEDTLS_ARC4_C
#define MBEDTLS_ASN1_PARSE_C
#define MBEDTLS_ASN1_WRITE_C
- \def MBEDTLS_BASE64_C
- Enable the Base64 module.
- Module: library/base64.c
- Caller: library/pem.c
- This module is required for PEM support (required by X.509).
#define MBEDTLS_BASE64_C
#define MBEDTLS_BIGNUM_C
- \def MBEDTLS_BLOWFISH_C
- Enable the Blowfish block cipher.
- Module: library/blowfish.c
#define MBEDTLS_BLOWFISH_C
#define MBEDTLS_CAMELLIA_C
- \def MBEDTLS_ARIA_C
- Enable the ARIA block cipher.
- Module: library/aria.c
- Caller: library/cipher.c
- This module enables the following ciphersuites (if other requisites are
- enabled as well):
MBEDTLS_TLS_RSA_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_RSA_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_DHE_RSA_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_RSA_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_RSA_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_DHE_RSA_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_DHE_RSA_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_ECDHE_ECDSA_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_ECDH_ECDSA_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_ECDHE_RSA_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_ECDH_RSA_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_PSK_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_PSK_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_DHE_PSK_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_DHE_PSK_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_RSA_PSK_WITH_ARIA_256_CBC_SHA384
MBEDTLS_TLS_PSK_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_PSK_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_DHE_PSK_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_DHE_PSK_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_RSA_PSK_WITH_ARIA_128_GCM_SHA256
MBEDTLS_TLS_RSA_PSK_WITH_ARIA_256_GCM_SHA384
MBEDTLS_TLS_ECDHE_PSK_WITH_ARIA_128_CBC_SHA256
MBEDTLS_TLS_ECDHE_PSK_WITH_ARIA_256_CBC_SHA384
//#define MBEDTLS_ARIA_C
- \def MBEDTLS_CCM_C
- Enable the Counter with CBC-MAC (CCM) mode for 128-bit block cipher.
- Module: library/ccm.c
- Requires: MBEDTLS_AES_C or MBEDTLS_CAMELLIA_C
- This module enables the AES-CCM ciphersuites, if other requisites are
- enabled as well.
#define MBEDTLS_CCM_C
- \def MBEDTLS_CERTS_C
- Enable the test certificates.
- Module: library/certs.c
- Caller:
- This module is used for testing (ssl_client/server).
#define MBEDTLS_CERTS_C
- \def MBEDTLS_CIPHER_C
- Enable the generic cipher layer.
- Module: library/cipher.c
- Caller: library/ssl_tls.c
- Uncomment to enable generic cipher wrappers.
#define MBEDTLS_CIPHER_C
//#define MBEDTLS_CMAC_C
#define MBEDTLS_CTR_DRBG_C
#define MBEDTLS_DEBUG_C
#define MBEDTLS_DHM_C
#define MBEDTLS_ECDSA_C
//#define MBEDTLS_ECJPAKE_C
#define MBEDTLS_ECP_C
#define MBEDTLS_ENTROPY_C
#define MBEDTLS_ERROR_C
#define MBEDTLS_GCM_C
#define MBEDTLS_HKDF_C
#define MBEDTLS_HMAC_DRBG_C
#define MBEDTLS_MD_C
//#define MBEDTLS_MD2_C
//#define MBEDTLS_MD4_C
#define MBEDTLS_MD5_C
//#define MBEDTLS_MEMORY_BUFFER_ALLOC_C
#define MBEDTLS_NET_C
#define MBEDTLS_OID_C
#define MBEDTLS_PADLOCK_C
#define MBEDTLS_PEM_PARSE_C
#define MBEDTLS_PEM_WRITE_C
#define MBEDTLS_PK_C
#define MBEDTLS_PK_PARSE_C
#define MBEDTLS_PK_WRITE_C
#define MBEDTLS_PKCS5_C
//#define MBEDTLS_PKCS11_C
#define MBEDTLS_PKCS12_C
#define MBEDTLS_PLATFORM_C
- \def MBEDTLS_RIPEMD160_C
- Enable the RIPEMD-160 hash algorithm.
- Module: library/ripemd160.c
- Caller: library/md.c
#define MBEDTLS_RIPEMD160_C
#define MBEDTLS_RSA_C
#define MBEDTLS_SHA1_C
#define MBEDTLS_SHA256_C
#define MBEDTLS_SHA512_C
#define MBEDTLS_SSL_CACHE_C
#define MBEDTLS_SSL_COOKIE_C
#define MBEDTLS_SSL_TICKET_C
#define MBEDTLS_SSL_CLI_C
#define MBEDTLS_SSL_SRV_C
#define MBEDTLS_SSL_TLS_C
#define MBEDTLS_TIMING_C
#define MBEDTLS_VERSION_C
#define MBEDTLS_X509_USE_C
#define MBEDTLS_X509_CRT_PARSE_C
#define MBEDTLS_X509_CRL_PARSE_C
#define MBEDTLS_X509_CSR_PARSE_C
#define MBEDTLS_X509_CREATE_C
#define MBEDTLS_X509_CRT_WRITE_C
#define MBEDTLS_X509_CSR_WRITE_C
#define MBEDTLS_XTEA_C
/* } name SECTION: mbed TLS modules */
/* MPI / BIGNUM options */
//#define MBEDTLS_MPI_WINDOW_SIZE 6 /< Maximum windows size used. */
//#define MBEDTLS_MPI_MAX_SIZE 1024 /< Maximum number of bytes for usable MPIs. */
/* CTR_DRBG options */
//#define MBEDTLS_CTR_DRBG_ENTROPY_LEN 48 /< Amount of entropy used per seed by default (48 with SHA-512, 32 with SHA-256) */
//#define MBEDTLS_CTR_DRBG_RESEED_INTERVAL 10000 /< Interval before reseed is performed by default */
//#define MBEDTLS_CTR_DRBG_MAX_INPUT 256 /< Maximum number of additional input bytes */
//#define MBEDTLS_CTR_DRBG_MAX_REQUEST 1024 /< Maximum number of requested bytes per call */
//#define MBEDTLS_CTR_DRBG_MAX_SEED_INPUT 384 /**< Maximum size of (re)seed buffer */
/* HMAC_DRBG options */
//#define MBEDTLS_HMAC_DRBG_RESEED_INTERVAL 10000 /< Interval before reseed is performed by default */
//#define MBEDTLS_HMAC_DRBG_MAX_INPUT 256 /< Maximum number of additional input bytes */
//#define MBEDTLS_HMAC_DRBG_MAX_REQUEST 1024 /< Maximum number of requested bytes per call */
//#define MBEDTLS_HMAC_DRBG_MAX_SEED_INPUT 384 /< Maximum size of (re)seed buffer */
/* ECP options */
//#define MBEDTLS_ECP_MAX_BITS 521 /< Maximum bit size of groups */
//#define MBEDTLS_ECP_WINDOW_SIZE 6 /< Maximum window size used */
//#define MBEDTLS_ECP_FIXED_POINT_OPTIM 1 /**< Enable fixed-point speed-up */
/* Entropy options */
//#define MBEDTLS_ENTROPY_MAX_SOURCES 20 /< Maximum number of sources supported */
//#define MBEDTLS_ENTROPY_MAX_GATHER 128 /< Maximum amount requested from entropy sources */
//#define MBEDTLS_ENTROPY_MIN_HARDWARE 32 /**< Default minimum number of bytes required for the hardware entropy source mbedtls_hardware_poll() before entropy is released */
/* Memory buffer allocator options */
//#define MBEDTLS_MEMORY_ALIGN_MULTIPLE 4 /**< Align on multiples of this value */
/* Platform options */
//#define MBEDTLS_PLATFORM_STD_MEM_HDR <stdlib.h> /< Header to include if MBEDTLS_PLATFORM_NO_STD_FUNCTIONS is defined. Don’t define if no header is needed. */
//#define MBEDTLS_PLATFORM_STD_CALLOC calloc /< Default allocator to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_FREE free /< Default free to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_EXIT exit /< Default exit to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_TIME time /< Default time to use, can be undefined. MBEDTLS_HAVE_TIME must be enabled */
//#define MBEDTLS_PLATFORM_STD_FPRINTF fprintf /< Default fprintf to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_PRINTF printf /< Default printf to use, can be undefined /
/ Note: your snprintf must correclty zero-terminate the buffer! */
//#define MBEDTLS_PLATFORM_STD_SNPRINTF snprintf /< Default snprintf to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_EXIT_SUCCESS 0 /< Default exit value to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_EXIT_FAILURE 1 /< Default exit value to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_NV_SEED_READ mbedtls_platform_std_nv_seed_read /< Default nv_seed_read function to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_NV_SEED_WRITE mbedtls_platform_std_nv_seed_write /< Default nv_seed_write function to use, can be undefined */
//#define MBEDTLS_PLATFORM_STD_NV_SEED_FILE “seedfile” /**< Seed file to read/write with default implementation */
/* To Use Function Macros MBEDTLS_PLATFORM_C must be enabled /
/ MBEDTLS_PLATFORM_XXX_MACRO and MBEDTLS_PLATFORM_XXX_ALT cannot both be defined */
//#define MBEDTLS_PLATFORM_CALLOC_MACRO calloc /< Default allocator macro to use, can be undefined */
//#define MBEDTLS_PLATFORM_FREE_MACRO free /< Default free macro to use, can be undefined */
//#define MBEDTLS_PLATFORM_EXIT_MACRO exit /< Default exit macro to use, can be undefined */
//#define MBEDTLS_PLATFORM_TIME_MACRO time /< Default time macro to use, can be undefined. MBEDTLS_HAVE_TIME must be enabled */
//#define MBEDTLS_PLATFORM_TIME_TYPE_MACRO time_t /< Default time macro to use, can be undefined. MBEDTLS_HAVE_TIME must be enabled */
//#define MBEDTLS_PLATFORM_FPRINTF_MACRO fprintf /< Default fprintf macro to use, can be undefined */
//#define MBEDTLS_PLATFORM_PRINTF_MACRO printf /< Default printf macro to use, can be undefined /
//#define MBEDTLS_PLATFORM_SNPRINTF_MACRO snprintf /< Default snprintf macro to use, can be undefined */
//#define MBEDTLS_PLATFORM_NV_SEED_READ_MACRO mbedtls_platform_std_nv_seed_read /< Default nv_seed_read function to use, can be undefined */
//#define MBEDTLS_PLATFORM_NV_SEED_WRITE_MACRO mbedtls_platform_std_nv_seed_write /< Default nv_seed_write function to use, can be undefined */
/* SSL Cache options */
//#define MBEDTLS_SSL_CACHE_DEFAULT_TIMEOUT 86400 /< 1 day */
//#define MBEDTLS_SSL_CACHE_DEFAULT_MAX_ENTRIES 50 /< Maximum entries in cache */
/* SSL options */
//#define MBEDTLS_SSL_MAX_CONTENT_LEN 16384 /< Maxium fragment length in bytes, determines the size of each of the two internal I/O buffers */
//#define MBEDTLS_SSL_DEFAULT_TICKET_LIFETIME 86400 /< Lifetime of session tickets (if enabled) */
//#define MBEDTLS_PSK_MAX_LEN 32 /< Max size of TLS pre-shared keys, in bytes (default 256 bits) */
//#define MBEDTLS_SSL_COOKIE_TIMEOUT 60 /< Default expiration delay of DTLS cookies, in seconds if HAVE_TIME, or in number of cookies issued */
//#define MBEDTLS_SSL_CIPHERSUITES MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384,MBEDTLS_TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
/* X509 options */
//#define MBEDTLS_X509_MAX_INTERMEDIATE_CA 8 /< Maximum number of intermediate CAs in a verification chain. */
//#define MBEDTLS_X509_MAX_FILE_PATH_LEN 512 /< Maximum length of a path/filename string in bytes including the null terminator character (’\0’). */
#define MBEDTLS_TLS_DEFAULT_ALLOW_SHA1_IN_KEY_EXCHANGE
//#define MBEDTLS_PLATFORM_ZEROIZE_ALT
/* } name SECTION: Customisation configuration options */
/* Target and application specific configurations */
//#define YOTTA_CFG_MBEDTLS_TARGET_CONFIG_FILE “mbedtls/target_config.h”
#if defined(TARGET_LIKE_MBED) && defined(YOTTA_CFG_MBEDTLS_TARGET_CONFIG_FILE)
#include YOTTA_CFG_MBEDTLS_TARGET_CONFIG_FILE
#endif
- Allow user to override any previous default.
- Use two macro names for that, as:
- with yotta the prefix YOTTA_CFG_ is forced
- without yotta is looks weird to have a YOTTA prefix.
#if defined(YOTTA_CFG_MBEDTLS_USER_CONFIG_FILE)
#include YOTTA_CFG_MBEDTLS_USER_CONFIG_FILE
#elif defined(MBEDTLS_USER_CONFIG_FILE)
#include MBEDTLS_USER_CONFIG_FILE
#endif
#include “check_config.h”
#endif /* MBEDTLS_CONFIG_H */
