Hi there! –
(cc @jeromecoutant - on peut en parler en direct si besoin)
My team and I have been working on a custom board based on the 32F769IDISCO. Thanks to ST’s documentation, we were able to get it up and running very quickly. We kept most of the pins the same, especially for the complex things to make debugging easier and to allow us to still use the DISCO for development.
We’ve also created a new target by copying the DISCO. Code compiles and runs, so far so good!
As with our board all the pins, names, peripherals and functions are set in stone we put together a neat little process where we define all the pins in a Google Sheet, export a csv, create an .ioc file with CubeMX and edit the .ioc file from the command line to apply the functions and labels of all the pins defined in the csv. (I can share the script if someone’s interested)
Then we used the STM32_gen_PeripheralPins.py script to generate the PeripheralPins.c and
PinNames.h files.
The script works great but doesn’t take into account our own labels. For that I put together another script to parse the csv and generate a .h file with our all pins. (I can also share this one if needed)
First question: did I miss something in the STM32_gen_PeripheralPins.py script to also generate pin names based on our labels?
Then, we dove into the documentation (mbed/stm/pin configuration) and PeripheralPins.c.
Second question: As we know in advance if we’ll be using alternate functions and the function of each pin, we were wondering if we could comment out all the non relevant information?
For example:
MBED_WEAK const PinMap PinMap_SPI_MISO[] = {
{PA_6, SPI_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI1)}, // Connected to SD_SPI_MISO
{PA_6_ALT0, SPI_6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF8_SPI6)}, // Connected to SD_SPI_MISO
{PB_4, SPI_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI1)},
{PB_4_ALT0, SPI_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF6_SPI3)},
{PB_4_ALT1, SPI_6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF8_SPI6)},
{PB_14, SPI_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI2)}, // Connected to SCREEN_BACKLIGHT_PWM
{PC_2, SPI_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI2)},
{PC_11, SPI_3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF6_SPI3)},
{PE_5, SPI_4, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI4)}, // Connected to MOTOR_RIGHT_ENABLE
{PE_13, SPI_4, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI4)}, // Connected to FMC_SRAM_D10
{PF_8, SPI_5, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI5)}, // Connected to BLE_SPI_MISO
{PG_9, SPI_1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI1)}, // Connected to SENSOR_IMU_IRQ
{PG_12, SPI_6, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI6)},
{PH_7, SPI_5, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI5)}, // Connected to SENSOR_PROXIMITY_MUX_I2C_SCL
{PI_2, SPI_2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_NOPULL, GPIO_AF5_SPI2)}, // Connected to FMC_SRAM_D26
{NC, NC, 0}
The lines really important to us and related to PinMap_SPI_MISO are:
Is it ok to remove the other ones? Will that have a positive impact on anything besides making it clear what is used for what.
Thanks a lot for your help!
Best,
– Ladislas
