Hello all, I have created a custom target (STM32F103VDT) using STM32_gen_PeripheralPins.py. In the generated PeriphreralPins.c are some definitions that can not be found in Mbed Studio (compiler error), the AFIO_TIMx_ENABLE and others, I had to comment the related entries (last lines) to be able to compile, but in my application I need to use pins PD_12 to PD_15 as pwms, see what I did:
MBED_WEAK const PinMap PinMap_PWM[] = {
{PA_0, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 0)}, // TIM2_CH1
// {PA_0, PWM_5, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 0)}, // TIM5_CH1
{PA_1, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 0)}, // TIM2_CH2
// {PA_1, PWM_5, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 0)}, // TIM5_CH2
{PA_2, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 0)}, // TIM2_CH3
// {PA_2, PWM_5, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 0)}, // TIM5_CH3
{PA_3, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 4, 0)}, // TIM2_CH4
// {PA_3, PWM_5, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 4, 0)}, // TIM5_CH4
{PA_6, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 0)}, // TIM3_CH1
{PA_7, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 6, 1, 1)}, // TIM1_CH1N
{PA_7_ALT0, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 0)}, // TIM3_CH2
{PA_7_ALT1, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 1)}, // TIM8_CH1N
{PA_8, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 0)}, // TIM1_CH1
{PA_9, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 0)}, // TIM1_CH2
{PA_10, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 0)}, // TIM1_CH3
{PA_11, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 4, 0)}, // TIM1_CH4
{PA_15, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 8, 1, 0)}, // TIM2_CH1
{PB_0, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 6, 2, 1)}, // TIM1_CH2N
{PB_0_ALT0, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 0)}, // TIM3_CH3
{PB_0_ALT1, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 1)}, // TIM8_CH2N
{PB_1, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 6, 3, 1)}, // TIM1_CH3N
{PB_1_ALT0, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 4, 0)}, // TIM3_CH4
{PB_1_ALT1, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 1)}, // TIM8_CH3N
{PB_3, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 8, 2, 0)}, // TIM2_CH2
{PB_4, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 7, 1, 0)}, // TIM3_CH1
{PB_5, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 7, 2, 0)}, // TIM3_CH2
{PB_6, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 0)}, // TIM4_CH1
{PB_7, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 0)}, // TIM4_CH2
{PB_8, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 0)}, // TIM4_CH3
{PB_9, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 4, 0)}, // TIM4_CH4
{PB_10, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 8, 3, 0)}, // TIM2_CH3
{PB_11, PWM_2, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 8, 4, 0)}, // TIM2_CH4
{PB_13, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 1)}, // TIM1_CH1N
{PB_14, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 1)}, // TIM1_CH2N
{PB_15, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 1)}, // TIM1_CH3N
{PC_6, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 9, 1, 0)}, // TIM3_CH1
{PC_6_ALT0, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 1, 0)}, // TIM8_CH1
{PC_7, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 9, 2, 0)}, // TIM3_CH2
{PC_7_ALT0, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 2, 0)}, // TIM8_CH2
{PC_8, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 9, 3, 0)}, // TIM3_CH3
{PC_8_ALT0, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 3, 0)}, // TIM8_CH3
{PC_9, PWM_3, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 9, 4, 0)}, // TIM3_CH4
{PC_9_ALT0, PWM_8, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, 0, 4, 0)}, // TIM8_CH4
//{PD_12, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM4_ENABLE, 1, 0)}, // TIM4_CH1
//{PD_13, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM4_ENABLE, 2, 0)}, // TIM4_CH2
//{PD_14, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM4_ENABLE, 3, 0)}, // TIM4_CH3
//{PD_15, PWM_4, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM4_ENABLE, 4, 0)}, // TIM4_CH4
//{PE_8, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 1, 1)}, // TIM1_CH1N
//{PE_9, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 1, 0)}, // TIM1_CH1
//{PE_10, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 2, 1)}, // TIM1_CH2N
//{PE_11, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 2, 0)}, // TIM1_CH2
//{PE_12, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 3, 1)}, // TIM1_CH3N
//{PE_13, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 3, 0)}, // TIM1_CH3
//{PE_14, PWM_1, STM_PIN_DATA_EXT(STM_MODE_AF_PP, GPIO_NOPULL, AFIO_TIM1_ENABLE, 4, 0)}, // TIM1_CH4
{NC, NC, 0}
Do you think I missed something?, where those defines ( AFIO_TIMx_ENABLE) should be located?
Thank you very much.
