Device: Nucleo f446re
IDE: mBed studio
With the fall of a button I call a function which calls another function to set the PWM output duty-cycle.
That works great, the duty cycle is set and the wheels start turning. But after only a couple of seconds the wheels suddenly stop turning.
I used the debug function to discover that after the function pokreni_motore() is done running, it goes back to function toggle() from which it was called, but it doesnt continue from the line pokreni_motore() was originally called but it starts from the beginning, as if the function toggle() was called again. And as such the two functions are stuck in a loop calling each other.
Note:
The functions loop again even if they shouldnt only when I have already pressed the button and the wheels have started turning (AKA it stops them from turning). But if I havent pressed the button or the functions have looped illegally and have stopped the wheels, the wheels will not start turning and the functions wont be looping.
Here is the code for toggle():
void toggle()
if(timer.read() > 0.5) //Unutar ove petlje kako bi smo izbjegli debouncing
brojac++;
pokreni_motore();
timer.reset();
The func pokreni_motore();
void pokreni_motore()
if(brojac % 2 == 0)
flash = 1;
pwm_L.write(0.4);
pwm_D.write(0.4);
if(brojac % 2 != 0)
flash = 0;
pwm_L.write(0);
pwm_D.write(0);
Main:
pwm_L.period(0.02);
pwm_D.period(0.02);
timer.start(); //debounce
button.mode(PullUp);
button.rise(&toggle);
To summarize; I want to press a button, have the wheels start turning, press the same button again to make the wheels stop turning. And only have them start/stop when I click the button.
I hope what i wrote makes sense, its 5 in the morning and I have been trying to crack this thing for the last 3 hours. Hope someone sees what I’m missing.
