I am creating a programme to control temperature through the use of a stepper motor. I have the system running fine until the very end. I then want it to return to the start of the while loop after i have called the interrupt to check the temperature. The issue is that when i operate the motor i can no longer check the temperature. Any advise would be appreciated!
#include “mbed.h”
#include “TextLCD.h”
// Declarations
BusOut Steppermotor(p11, p12, p13, p14); // (IN1) - (IN2) - (IN3) - (IN4)
AnalogIn LM35(p15); // Temperature Sensor
DigitalOut GreenLED(p7);
DigitalOut RedLED(p5);
DigitalOut Orange_LED_flash(p6);
InterruptIn Button(p25); // Temperature check
InterruptIn Button2(p24); // Motor Control - Window open
InterruptIn Button3(p23); // Motor control - Window close
Timeout Response;
TextLCD lcd(p21, p22, p27, p28, p29, p30, TextLCD::LCD16x2); // LCD Display Wiring
// variable declartations
float tempC=0; // Temperature in celcius
float target_temp = 20; // Target temperature
int step = 0; // variable integer values for the system.
int dir=1;
int i=0;
void return_to_start(){
if(tempC<=target_temp)
GreenLED = 1;
wait(3);
else if(tempC>target_temp){
GreenLED = 0;
Orange_LED_flash = !Orange_LED_flash;
wait(0.5);
lcd.cls();
wait(0.5);
lcd.printf("Window requires\n adjustment\n");
lcd.cls();
void Temp_check() { // Temperature check interrupt
tempC=LM35.read();
tempC=(tempC3.3100); //LM35 Thermistor
// Display temperature
lcd.locate(0,0);
lcd.printf("cT sT");
lcd.locate(0,1);
// Display current and target temperature
lcd.printf("%.1f %.1f",tempC,target_temp);
wait(5);
lcd.cls();
void Motor_control(){
i=56; // The amount of times the loop will run, in this case, 56.
while(1){
if(i>56) {GreenLED=0; RedLED=0;}
if(Button3==1) {i=0;dir=0;} // These are the variable inputs that will
if(Button2==1) {i=0;dir=1;} // determine the movement of the motor
while (i<=56) {
switch(step)
case 0: Steppermotor = 0x1; break; //0001
case 1: Steppermotor = 0x2; break; //0010
case 2: Steppermotor = 0x4; break; //0100
case 3: Steppermotor = 0x8; break; //1000
default: Steppermotor = 0x0; break; //0000
if(dir==1) {step++;} else {step--;}
if(step>3) {step=0;}
if(step<0) {step=3;}
if(dir==1) {GreenLED=1; RedLED=0;} else {GreenLED=0; RedLED=1;}
wait(0.005); //speedooo
i++;
int main(){
Button.rise(&Temp_check); // Interrups
Button2.rise(&Motor_control);
Button3.rise(&Motor_control);
// welcome message
lcd.cls();
wait(2);
GreenLED = 1;
wait(0.5);
GreenLED = 0;
wait(0.5);
GreenLED = 1;
wait(0.5);
GreenLED = 0;
wait(0.5);
GreenLED = 1;
wait(0.5);
GreenLED = 0;
wait(3);
lcd.printf("AD Automated\nControl Systems\n");
wait(3);
lcd.cls();
wait(3);
lcd.printf("Temp. ready for\n assesment \n");
wait(3);
lcd.cls();
while(1){
GreenLED = 1;
wait(3);
GreenLED = 0;
wait(0.5);
lcd.cls();
wait(0.5);
lcd.cls();
Response.attach(&return_to_start,2.0);{
