I’ve run into a strange error with the mbed AWS client when attempting to download a shadow. It works fine until the shadow gets to a certain size, somewhere around 200 - 300 characters. The client fails with an lwip NSAPI_ERROR_DEVICE_ERROR, which doesn’t make much sense, as we have a variety of firmware versions we have run on these board that do run against AWS and we have never seen any device errors or hardware issues.
I presume there is a buffer that needs to be increased somewhere, but I have changed all of the expected settings and am not seeing any different results.
We are using a board which is based on the MK64 and inherits from the K64F target. I’ve attached the code snippet, log output, and mbed_app.json to help. I’d love to know which setting needs to be changed to allow for larger AWS shadows.
Thanks!
mbed_app.json
"macros":[
"MBED_CONF_AWS_CLIENT_BUFFER_SIZE=16384"
"config": {
"aws-endpoint": {
"help": "Endpoint URL",
"value": "\"redacted.amazonaws.com\""
"main-stack-size": {
"value": 16384
"use-tls-socket": {
"value": true
"target_overrides": {
"mbed-trace.enable": true,
"mbed-trace.max-level": "TRACE_LEVEL_INFO",
"platform.error-filename-capture-enabled": true,
"aws-client.shadow": true,
"aws-client.aws-sdk-trace": true,
"aws-client.shadow-get-response-max-size": 4096,
"aws-client.buffer-size": 4096,
"aws-client.shadow-update-document-max-size": 4096,
"aws-client.socket-timeout":"30s"
Snippet
debug("Device Already Configured!\n");
auto ret = client.downloadShadowDocument();
if (ret == MBED_SUCCESS) {
tr_info("Device Shadow document downloaded");
} else {
tr_error("AWSClient::downloadShadowDocument() failed: %d", ret);
char* test_doc = "{\"state\":{}}";
ret = client.updateShadowDocument(test_doc, strlen(test_doc));
if( ret == MBED_SUCCESS){
tr_info("Device Shadow document created");
else{
tr_error("AWSClient::updateShadowDocument() failed: %d", ret);
goto disconnect;
Logs
e[2Ke[39m[INFO][TLSW]: Closing TLSe[0m
e[2Ke[39m[INFO][TLSW]: Starting TLS handshake with redacted.amazonaws.come[0m
e[2Ke[39m[INFO][TLSW]: TLS connection to redacted.amazonaws.com establishede[0m
e[2Ke[39m[INFO][TLSW]: Certificate verification passede[0m
e[2Ke[39m[INFO][AWS SDK]: Packet received. ReceivedBytes=2.e[0m
e[2Ke[39m[INFO][AWS SDK]: CONNACK session present bit not set.e[0m
e[2Ke[39m[INFO][AWS SDK]: Connection accepted.e[0m
e[2Ke[39m[INFO][AWS SDK]: Received MQTT CONNACK successfully from broker.e[0m
e[2Ke[39m[INFO][AWS SDK]: MQTT connection established with the broker.e[0m
e[2Ke[39m[INFO][AWS SDK]: Packet received. ReceivedBytes=3.e[0m
e[2Ke[31m[ERR ][TLSW]: mbedtls_ssl_read() failed: -0x7200 (-29184): SSL - An invalid SSL record was receivede[0m
e[2Ke[31m[ERR ][AWS SDK]: A single byte was not read from the transport: transportStatus=-3012.e[0m
