Hi all,
I have created a certificate at AWS IoT Console. When I run the certificates in an AWS sample on a Raspberry Pi, everything works well. My certificates are embedded into code for testing purposes, I use mbedtls_x509_crt_parse function to parse the certificates.
Now, I want to run the application on an MCU, but getting -2700 error during the handshake.
I am using the same certificates embedded into code but I get the error.
Everything seems identical between Rasperry Pi and the MCU project. Only there is no time definition on the MCU (MBEDTLS_HAVE_TIME_DATE commented out).
I am using the mbedtls_wrapper.c implementation from the AWS IoT SDK. I am getting " ! The certificate is not correctly signed by the trusted CA" warning when I try to verify the certificates.
Problem is that I did not create the certificates, AWS did, and I am using the same certificates but gettin this.
Have an idea? Thank you
