Hi Guys,
I am still a newbie when it comes to STM32F4 MCU, mbed and Yotta, so hopefully someone can help me with issues I encountered during the debugging of the simple LEDBlink example I followed from the mbed website.
I am using STM32F411RE-Nucleo Board. I used the stm32f411re-nucleo-gcc as my Yotta target. I encountered some compilation errors along the way, but was able to resolve those by supplying the files the build was looking:
- device.h
- target_config.h
- stm32f411xe.h
- startup_stm32f4xx.s
- system_stm32f4xx.c
- STM32F411XE.ld
Now that i started to debug the firmware using Eclipse + OpenOCD + GDB setup, i encountered a HardFault exception. Tracing HardFault registers, these are the values:
- HFSR (HardFault Status Register) = 0x40000000 which means a Forced Fault
- CSFR (Configurable Fault Status Reg) = 0x100 which means IBUSERR or instruction bus error
Here is where the hardfault always happen. During debugging and I stepped into HAL_TIM_OC_Init(&TimMasterHandle); and when I reached at the exit point of the HAL_TIM_OC_Init(&TimMasterHandle); function, it will raise the HardFault exception.
// Reconfigure the HAL tick using a standard timer instead of systick.
HAL_StatusTypeDef HAL_InitTick(uint32_t TickPriority) {
_ (void)TickPriority;_
_ // Enable timer clock_
_ TIM_MST_RCC;_
_ // Reset timer_
_ TIM_MST_RESET_ON;_
_ TIM_MST_RESET_OFF;_
_ // Update the SystemCoreClock variable_
_ SystemCoreClockUpdate();_
_ // Get clock configuration_
_ RCC_ClkInitTypeDef RCC_ClkInitStruct;_
_ uint32_t PclkFreq;_
_ // Note: PclkFreq contains here the Latency (not used after)_
_ HAL_RCC_GetClockConfig(&RCC_ClkInitStruct, &PclkFreq);_
_ // Get TIM1 clock value_
_ PclkFreq = HAL_RCC_GetPCLK1Freq();_
_ // TIMxCLK = PCLKx when the APB prescaler = 1 else TIMxCLK = 2 * PCLKx_
_ if (RCC_ClkInitStruct.APB1CLKDivider != RCC_HCLK_DIV1) {_
_ PclkFreq *= 2;_
_ }_
_ // Configure time base_
_ TimMasterHandle.Instance = TIM_MST;_
_ TimMasterHandle.Init.Period = 0xFFFFFFFF;_
_ TimMasterHandle.Init.Prescaler = (uint32_t)(PclkFreq / 1000000) - 1; // 1 us tick_
_ TimMasterHandle.Init.ClockDivision = 0;_
_ TimMasterHandle.Init.CounterMode = TIM_COUNTERMODE_UP;_
_ TimMasterHandle.Init.RepetitionCounter = 0;_
_ NVIC_SetVector(TIM_MST_IRQ, (uint32_t)timer_irq_handler);_
_ NVIC_EnableIRQ(TIM_MST_IRQ);_
_ // Channel 1 for mbed timeout_
_ HAL_TIM_OC_Start(&TimMasterHandle, TIM_CHANNEL_1);_
_ // Channel 2 for HAL tick_
_ HAL_TIM_OC_Start(&TimMasterHandle, TIM_CHANNEL_2);_
_ PreviousVal = _HAL_TIM_GetCounter(&TimMasterHandle);
_ _HAL_TIM_SetCompare(&TimMasterHandle, TIM_CHANNEL_2, PreviousVal + HAL_TICK_DELAY);
_ _HAL_TIM_ENABLE_IT(&TimMasterHandle, TIM_IT_CC2);
#if 0 // For DEBUG only
_ GPIOB_CLK_ENABLE();
_ GPIO_InitTypeDef GPIO_InitStruct;
_ GPIO_InitStruct.Pin = GPIO_PIN_6;_
_ GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;_
_ GPIO_InitStruct.Pull = GPIO_PULLUP;_
_ GPIO_InitStruct.Speed = GPIO_SPEED_FAST;_
_ HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);_
#endif
_ return HAL_OK;_
Is there something I messed up in the build/compile/link environment (most especially stack)? Or i just missed to do some additional build configuration?
Thanks.
