Help Needed: HX711 Raw Value Calculation Issues
I’m trying to understand how the HX711 works and I’m facing some challenges. I recently conducted tests using a 5 kg load cell and applied standard weights while measuring the voltage across the strain gauge for each weight.
Here’s a summary of my procedure:
Connection of the Load Cell: I connected the wires of the load cell as follows:
Excitation terminals to E+ and E-
Output terminals to A+ and A- of the HX711.
Voltage Measurement: I measured the voltage across the gauge for each applied weight.
Retrieval of Raw Values: I then connected the load cell to the HX711 circuit and retrieved the raw values corresponding to the same weights used previously.
However, when I calculated the raw values using the following formulas, I found values that were very different from those measured:
Amplification Formula:
Vout=Gain×Vin(with Gain = 128)
Analog-to-Digital Conversion Formula:
Raw Value=(VrefVout)×(2n−1)
Could anyone clarify this discrepancy in results? Does the HX711 use a different method for amplification or signal conversion?
Thank you for your help!
which controller your using?
how input voltage of HX711,
are you calibration the valve with knew Weight?
you are using i2c protocol .
