I have used the below mentioned library as a reference and made some changes in it which are mentioned below:
source library : HX711 - Library to read out HX711 24-Bit Analog-to-Digita… | Mbed
My library files:
Hx711.cpp:
#include “mbed.h”
#include “Hx711.h”void Hx711::set_gain(uint8_t gain) {
switch (gain) {
case 128: // channel A, gain factor 128
gain_ = 1;
break;
case 64: // channel A, gain factor 64
gain_ = 3;
break;
case 32: // channel B, gain factor 32
gain_ = 2;
break;
}sck_.write(LOW); read();}
uint32_t Hx711::readRaw() {
// wait for the chip to become ready
// TODO: this is not ideal; the programm will hang if the chip never
// becomes ready…
while (!is_ready());uint32_t value = 0; uint8_t data[3] = { 0 }; uint8_t filler = 0x00; // pulse the clock pin 24 times to read the data data[2] = shiftInMsbFirst(); data[1] = shiftInMsbFirst(); data[0] = shiftInMsbFirst(); // set the channel and the gain factor for the next reading using the clock pin for (unsigned int i = 0; i < gain_; i++) { sck_.write(HIGH); wait_us(1); sck_.write(LOW); } /*// Datasheet indicates the value is returned as a two's complement value // Flip all the bits data[2] = ~data[2]; data[1] = ~data[1]; data[0] = ~data[0];*/ // Replicate the most significant bit to pad out a 32-bit signed integer if ( data[2] & 0x80 ) { filler = 0xFF; } //else if ((0x7F == data[2]) && (0xFF == data[1]) && (0xFF == data[0])) { // filler = 0xFF; } else { filler = 0x00; } // Construct a 32-bit signed integer value = ( static_cast<uint32_t>(filler) << 24 | static_cast<uint32_t>(data[2]) << 16 | static_cast<uint32_t>(data[1]) << 8 | static_cast<uint32_t>(data[0]) ); // ... and add 1 return static_cast<int>(value);}
uint8_t Hx711::shiftInMsbFirst() {
uint8_t value = 0;for (uint8_t i = 0; i < 8; ++i) { sck_.write(HIGH); value |= dt_.read() << (7 - i); sck_.write(LOW); } return value;}
My Hx711.h file :
#ifndef HX711_H
#define HX711_H
#include “mbed.h”
- Class for communication with the HX711 24-Bit Analog-to-Digital
- Converter (ADC) for Weigh Scales by AVIA Semiconductor.
- This library is a port of the Arduino library at
- GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales.
- It works with the FRDM K22F.
class Hx711 {public:
/** * Create an Hx711 ADC object * @param pin_sck PinName of the clock pin (digital output) * @param pin_dt PinName of the data pin (digital input) * @param offset offset for sensor values * @param scale scale factor to obtain real values * @param gain channel selection is made by passing the appropriate gain: * 128 or 64 for channel A, 32 for channel B */ Hx711(PinName pin_sck, PinName pin_dt, int offset, float scale, uint8_t gain = 128) : sck_(pin_sck), dt_(pin_dt) { set_offset(offset); set_scale(scale); set_gain(gain); } /** * Create an Hx711 ADC object with zero offset and unit scaling * @param pin_sck PinName of the clock pin (digital output) * @param pin_dt PinName of the data pin (digital input) * @param gain channel selection is made by passing the appropriate gain: * 128 or 64 for channel A, 32 for channel B * TODO: constructor overloading is not allowed? */ Hx711(PinName pin_sck, PinName pin_dt, uint8_t gain = 128) : sck_(pin_sck), dt_(pin_dt) { set_offset(0); set_scale(1.0f); set_gain(gain); } /** * Check if the sensor is ready * from the datasheet: When output data is not ready for retrieval, * digital output pin DOUT is high. Serial clock input PD_SCK should be low. * When DOUT goes to low, it indicates data is ready for retrieval. * @return true if dt_.read() == LOW * TODO: this is not ideal; the programm will hang if the chip never * becomes ready... */ bool is_ready() { return dt_.read() == LOW; } /** * Waits for the chip to be ready and returns a raw int reading * @return int sensor output value */ uint32_t readRaw(); float averageValue(uint8_t times) { int sum = 0; for (int i = 0; i < times; i++) { sum += read(); wait(.01); } return sum / times ; } /** * Obtain offset and scaled sensor output; i.e. a real value * @return float */ float read() { return convert_to_real(readRaw()); } /** * Convert integer value from chip to offset and scaled real value * @param val integer value * @return (val - get_offset()) * get_scale() */ float convert_to_real(int val) { return ((float)(val - get_offset())) / get_scale() ; } /** * Puts the chip into power down mode */ void power_down() { sck_.write(LOW); sck_.write(HIGH); } /** * Wakes up the chip after power down mode */ void power_up() { sck_.write(LOW); } /** * Set the gain factor; takes effect only after a call to read() * channel A can be set for a 128 or 64 gain; channel B has a fixed 32 gain * depending on the parameter, the channel is also set to either A or B * Ensures that gain_ = 128, 64 or 32 * @param gain 128, 64 or 32 */ void set_gain(uint8_t gain = 128); /** * Obtain current gain * @return gain_ */ uint8_t get_gain() { return gain_; } /** * Set the scale factor * @param scale desired scale */ void set_scale(float scale = 1.0f) { scale_ = scale; }; /** * Get sensor scale factor * @return scale_ */ float get_scale() { return scale_; } /** * Set the sensor offset * @param offset the desired offset */ void set_offset(int offset = 0) { offset_ = offset; } /** * Get current sensor offset * @return offset_ */ int get_offset() { return offset_; }private:
static const uint8_t LOW = 0; // digital low static const uint8_t HIGH = 1; // digital high DigitalOut sck_; // clock line DigitalIn dt_; // data line uint8_t gain_; // amplification factor at chip int offset_; // offset chip value float scale_; // scale output after offset /** * Port of the Arduino shiftIn function; shifts a byte one bit at a time * @return incoming but */ uint8_t shiftInMsbFirst();};
#endif
Datasheet of HX711 used :
https://cdn.sparkfun.com/datasheets/Sensors/ForceFlex/hx711_english.pdf
My Main.cpp code :
#include “mbed.h”
#include “platform/mbed_thread.h”
#include “math.h”
#include “string”
#include “Hx711.h”Serial pc(USBTX, USBRX);
Hx711 scale(PC_3,PF_3,128);int main()
float weight ;
float avgweight ;
while(1)
pc.printf(“Started to Weigh\n”);
weight = scale.averageValue(20);
pc.printf(“ActualValue = %.3f grams\n”, weight);
scale.power_down();
wait(.0000001);
scale.power_up();wait_us(300000); }
I’m getting some values as output but which are not increasing/decreasing w.r.t the actual know weights, there is something wrong ,please look at my code and library used and help me.
