I just started using mbed OS two weeks ago so this is a newbie question.
I’m trying to build two different firmware applications (same target hardware) with different features enabled. There is a directory “A” which is used only by Application A. There is a directory “B” used only by Application B. There are three common directories X, Y and Z used by both applications (A & B). How do you specify two different targets with two different sets of source directories as mbed cli does its own scanning looking for source code? Do you use custom_targets.json? I’m looking for some direction as to where to look or better yet, examples of how to do this.
there I have mbed-os and several libs, and also different apps that use the common code. The mbed-cli supports this by adding the libs to the compile command, e.g.
