Hi, I’m a developer for my university’s robotics team, where we’ve been using (and having great success) with the mbed
ecosystem. As a part of our competition, we create multiple robots, with a lot of code overlap between each robot, so we chose to create a CMake
based project (using mbed-tools
/Mbed CLI2) with multiple targets.
The project directory is along these lines:
MyCoolRobotProject
/mbed-os
/robots
/MyCoolRobot1
CMakeLists.txt
main.cpp
/MyCoolRobot2
CMakeLists.txt
main.cpp
main.h
CMakeLists.txt
CMakeLists.txt
The top CMakeLists is responsible for using the shared mbed-os
directory for both of the targets:
# mbed variables
set(MBED_PATH ${CMAKE_CURRENT_SOURCE_DIR}/mbed-os CACHE INTERNAL "")
set(MBED_CONFIG_PATH ${CMAKE_CURRENT_BINARY_DIR} CACHE INTERNAL "")
set(APP_TARGET MyCoolProject)
include(${MBED_PATH}/tools/cmake/app.cmake) # Enable cmake for mbed
project(${APP_TARGET})
add_subdirectory(${MBED_PATH})
link_libraries(mbed-os) # Now mbed-os can be used for my robots
add_subdirectory(robots)
The CMakeLists.txt
in my robots
directory doesn’t do too much, just adds the MyCoolRobot1
and MyCoolRobot2
dirs:
include_directories(${CMAKE_CURRENT_SOURCE_DIR}) # Include my main.h file
add_subdirectory(MyCoolRobot1 EXCLUDE_FROM_ALL)
add_subdirectory(MyCoolRobot2 EXCLUDE_FROM_ALL)
And lastly, the two CMakeLists.txt
in each robot dir (namely, MyCoolRobot1
and MyCoolRobot2
) are identical, and differ only in the target name.
project(MyCoolRobot1) # Can also be MyCoolRobot2, the CMakeLists is identical
add_executable(${PROJECT_NAME})
mbed_configure_app_target(${PROJECT_NAME})
get_filename_component(PARENT_DIR ${CMAKE_CURRENT_SOURCE_DIR} DIRECTORY)
target_sources(${PROJECT_NAME} PRIVATE main.cpp ${PARENT_DIR}/main.h)
mbed_set_post_build(${PROJECT_NAME})
Configuring this CMake
project works like a charm, and I can build each target individually using the --target
flag. Building the two targets works as expected and I am able to generate a .hex and .bin file for both targets, yet there is no .elf.map
file generated for MyCoolRobot1
(although a memory map file is generated for MyCoolRobot2
I find that when switching the order of the add_subdirectory
calls in my robots
level CMakeLists
, I am able to generate a .elf.map file for MyCoolRobot1
, so it appears that only the last directory added using add_subdirectory
will have an .elf.map
file generated.
Any insight is appreciated, thanks in advance.
