How to install python-mbedtls in win environment
I want to connect pc with server (automotive ECU) to perform secure connection using Transport layer (TCP and UDP) with cipher suite is PSK-AES128GCM-SHA256 ,using python module. I see that below link provided py module supports "PSK " key handling , when compare to default ssl py module - doesn’t support for “PSK” cipher suite.
When i try to do installation in win env , i m getting below error . can anyone please clarify the error.
ERROR: Could not find a version that satisfies the requirement python-mbedtls==1.3.0 (from versions: none)
ERROR: No matching distribution found for python-mbedtls==1.3.0
https://pypi.org/project/python-mbedtls/
Please let me know, if there is an other py library which supports TLS connection for " PSK "cipher suites Thanks in advance.
