How to send int16t_t data via BLE
Hi i am trying to modify the GATT clock ble example to be able to send int16_t data - [−32768, +32767] the data is from max30003 ECG AFE.
server.write and GattCharacteristic constructor does not support this change
		#include <stdio.h>
		#include "platform/Callback.h"
		#include "events/EventQueue.h"
		#include "platform/NonCopyable.h"
		#include "ble/BLE.h"
		#include "ble/Gap.h"
		#include "ble/GattClient.h"
		#include "ble/GapAdvertisingParams.h"
		#include "ble/GapAdvertisingData.h"
		#include "ble/GattServer.h"
		#include "BLEProcess.h"
		using mbed::callback;
		 * A Clock service that demonstrate the GattServer features.
		 * The clock service host three characteristics that model the current hour,
		 * minute and second of the clock. The value of the second characteristic is
		 * incremented automatically by the system.
		 * A client can subscribe to updates of the clock characteristics and get
		 * notified when one of the value is changed. Clients can also change value of
		 * the second, minute and hour characteristric.
		class ClockService {
			typedef ClockService Self;
		public:
			ClockService() :
				_hour_char("485f4145-52b9-4644-af1f-7a6b9322490f", 0),
				_minute_char("0a924ca7-87cd-4699-a3bd-abdcd9cf126a", 0),
				_second_char("8dd6a1b7-bc75-4741-8a26-264af75807de", 0),
				_clock_service(
					/* uuid */ "51311102-030e-485f-b122-f8f381aa84ed",
					/* characteristics */ _clock_characteristics,
					/* numCharacteristics */ sizeof(_clock_characteristics) /
											 sizeof(_clock_characteristics[0])
				_server(NULL),
				_event_queue(NULL)
				// update internal pointers (value, descriptors and characteristics array)
				_clock_characteristics[0] = &_hour_char;
				_clock_characteristics[1] = &_minute_char;
				_clock_characteristics[2] = &_second_char;
			void start(BLE &ble_interface, events::EventQueue &event_queue)
				 if (_event_queue) {
					return;
				_server = &ble_interface.gattServer();
				_event_queue = &event_queue;
				// register the service
				printf("Adding demo service\r\n");
				ble_error_t err = _server->addService(_clock_service);
				if (err) {
					printf("Error %u during demo service registration.\r\n", err);
					return;
				// updates subscribtion handlers
				_server->onUpdatesEnabled(as_cb(&Self::when_update_enabled));
				_server->onUpdatesDisabled(as_cb(&Self::when_update_disabled));
				_event_queue->call_every(1000 /* ms */, callback(this, &Self::increment_second));
		private:
			 * Handler called after a client has subscribed to notification or indication.
			 * @param handle Handle of the characteristic value affected by the change.
			void when_update_enabled(GattAttribute::Handle_t handle)
				printf("update enabled on handle %d\r\n", handle);
			 * Handler called after a client has cancelled his subscription from
			 * notification or indication.
			void when_update_disabled(GattAttribute::Handle_t handle)
				printf("update disabled on handle %d\r\n", handle);
			void increment_second(void){
			  static uint8_t second = 0;
			  ble_error_t  err = _second_char.set(*_server, ++second);
			void increment_minute(void){
				//uint8_t minute = 0;
			   // ble_error_t err = _minute_char.set(*_server, minute);
			void increment_hour(void){
			   // uint8_t hour = 0;
				//ble_error_t err = _hour_char.set(*_server, hour);
		private:
			 * Helper that construct an event handler from a member function of this
			 * instance.
			template<typename Arg>
			FunctionPointerWithContext<Arg> as_cb(void (Self::*member)(Arg))
				return makeFunctionPointer(this, member);
			 * Read, Write, Notify, Indicate  Characteristic declaration helper.
			 * @tparam T type of data held by the characteristic.
			template<typename T>
			class CustomCharacteristic : public GattCharacteristic {
			public:
				 * Construct a characteristic that can be read or written and emit
				 * @param[in] uuid The UUID of the characteristic.
				 * @param[in] initial_value Initial value contained by the characteristic.
				CustomCharacteristic(const UUID & uuid, const T& initial_value) :
					GattCharacteristic(
						/* UUID */ uuid,
						/* Initial value */ &_value,
						/* Value size */ sizeof(_value),
						/* Value capacity */ sizeof(_value),
						/* Properties */
										GattCharacteristic::BLE_GATT_CHAR_PROPERTIES_NOTIFY,
						/* Descriptors */ NULL,
						/* Num descriptors */ 0,
						/* variable len */ false
					_value(initial_value) {
				 * Get the value of this characteristic.
				 * @param[in] server GattServer instance that contain the characteristic
				 * value.
				 * @param[in] dst Variable that will receive the characteristic value.
				 * @return BLE_ERROR_NONE in case of success or an appropriate error code.
				ble_error_t get(GattServer &server, T& dst) const
					uint16_t value_length = sizeof(dst);
					return server.read(getValueHandle(), &dst, &value_length);
				 * Assign a new value to this characteristic.
				 * @param[in] server GattServer instance that will receive the new value.
				 * @param[in] value The new value to set.
				 * @param[in] local_only Flag that determine if the change should be kept
				 * locally or forwarded to subscribed clients.
				ble_error_t set(
					GattServer &server, const uint32_t &value, bool local_only = false
				) const {
					return server.write(getValueHandle(), &value, sizeof(value), local_only);
			private:
				int16_t _value;
			CustomCharacteristic<int16_t> _hour_char;
			CustomCharacteristic<int16_t> _minute_char;
			CustomCharacteristic<int16_t> _second_char;
			// list of the characteristics of the clock service
			GattCharacteristic* _clock_characteristics[3];
			// demo service
			GattService _clock_service;
			GattServer* _server;
			events::EventQueue *_event_queue;
			BLE &ble_interface = BLE::Instance();
			events::EventQueue event_queue;
			ClockService demo_service;
			BLEProcess ble_process(event_queue, ble_interface);
			ble_process.on_init(callback(&demo_service, &ClockService::start));
			// bind the event queue to the ble interface, initialize the interface
			// and start advertising
			ble_process.start();
			// Process the event queue.
			event_queue.dispatch_forever();
			return 0;
You need to send byte by byte. Try breaking up your int16_t and store them in a uint8_t array. Then, pass the array to your function specifying the size. And reconstruct int16_t on the receiver side.
