I’m trying to integrate my code as a library. It depends on a library called (lib)sodium, probably well known to many of you. My folders are structured like this:
The libsodium headers include <types.h> somewhere, which doesn’t work using the online compiler. I get the following compiler error:
Info: ‘types.h’ file not found in “OurLibrary/libsodium/sodium/crypto_onetimeauth_poly1305.h”, Line: 15, Col: 10
Why is <types.h> not findable in MBed OS? It seems to be a system library. And libsodium should compile to ARM.
I think that configuring libsodium in a different way caused the “types.h” to be rewritten to “sys/types.h”, because that’s the way it is compiled now. And that works!
The most common reason of Mutex Not allowed in ISR context is using printf() in ISR. Check if it is used in libsodium, and maybe try to configure it in release level or just disable the function call.
