I have been trying to adapt a 16x2 lcd with several libraries to my l432kc core but I can’t get anything, mbed always throws errors with any library, if someone could help me with a simple Hello World I would be very grateful, greetings engineers from the world.
I use this TextLCD and also useful guide about all things around it.
The problem can be also in your I2C GPIO expander.
Tips:
- you need set up contrast via potentiometer
- there are also some differences between expanders like different address or different setup of pins
- verify your i2c address - code below
My recommendation is use the library what I posted and setup correct expander in the TextLCD_Config.h - it start on line 70.
For i2c scanner code click here
I2C i2c(I2C_SDA, I2C_SCL);
int main(){
printf("\nI2C Scanner running...\n");
//i2c.frequency(400000);
int error, address, nDevices;
nDevices = 0;
for(address = 0; address < 128; address++ ){
thread_sleep_for(10);
/*i2c.start();
error = i2c.write(address << 1);
i2c.stop();*/
error = i2c.write(address << 1, "1", 1);
//pc.printf("Erorr %d\n", error);
if (error == 0){ //need to be change according to what version of overloaded write method is used
printf("I2C device found at address 8bit: 0x%X 7bit: 0x%X\n", address, address << 1);
nDevices++;
if (nDevices == 0){
printf("No I2C devices found\n");
}else{
printf("\ndone\n");
For Example click here
#include "TextLCD.h"
DigitalOut led(LED1);
I2C i2cBus(I2C_SDA, I2C_SCL);
TextLCD_I2C lcd(&i2cBus, PCF8574_SA7, TextLCD::LCD16x2);
int main(){
printf("LCD test\n");
lcd.setCursor(TextLCD::CurOff_BlkOff);
lcd.cls();
lcd.setBacklight(TextLCD::LightOn);
lcd.printf("LCD hello\n");
thread_sleep_for(50);
while(1) {
thread_sleep_for(500);
led = !led;
I use it with MbedOS6.5
