Hi guys,
Im trying to print a “Hello World!” on my new LCD 16 x 2 HD44780 1602 with my KL25Z:
Using I2C i2c_lcd(PTE0 ,PTE1 )
My “main.cpp” :
/* Hello World! for the TextLCD Enhanced Library*/
#include "TextLCD.h"
// Host PC Communication channels
Serial pc(USBTX, USBRX); // tx, rx
// I2C Communication
I2C i2c_lcd(PTE0,PTE1); // SDA, SCL
// LCD instantiation
TextLCD_I2C lcd(&i2c_lcd, 0x4E, TextLCD::LCD16x2, TextLCD::HD44780); // I2C exp: I2C bus, PCF8574 Slaveaddress, LCD Type, Ctrl Type
//“TextLCD Enhanced Test”
And my TextLCD_Config,h:
//Select Serial Port Expander Hardware module (one option only)
#define DEFAULT 0
#define ADAFRUIT 0
#define DFROBOT 0
#define LCM1602 1
#define YWROBOT 0
#define GYLCD 0
#define MJKDZ 0
#define SYDZ 0
#define WIDEHK 0
#define LCDPLUG 0
Actual state:
I think the problems maybe is something related with the chipsets: 1602A PCF8574T
When I use Slave Address: 0x4E Screen goes black
If I use Select Serial Port Expander Hardware DEFAULT 1 module display blink
Thanks!!!
JohnnyK
(Jan Kamidra)
May 5, 2020, 5:13pm
2
Hi Cristian,
It looks same like my expander from Aliexpress.
On the picture is not visible what is on display behind the green color but a fully filled first line = no communication.
I use this constructor and settings
TextLCD_I2C lcd (&i2cBus, PCF8574A_SA7, TextLCD::LCD16x2); // HD44780 is default
and in the TextLCD_Config.h file I use DFROBOT but I tried also with your LCM1602 and also is working.
Is not working
You are using KL25Z PTE0,PTE1 I2C ports?
The LCD display : AZDelivery HD44780 1602 LCD
JohnnyK
(Jan Kamidra)
May 5, 2020, 6:41pm
4
Nope, I have only ST boards.
You can also verify your I2C connection and address with simple code bellow.
I2C i2c(I2C_SDA, I2C_SCL);
int main(){
printf("\nI2C Scanner running...\n");
//i2c.frequency(400000);
int error, address, nDevices;
nDevices = 0;
for(address = 0; address < 128; address++ ){
thread_sleep_for(10);
error = i2c.write(address << 1, "1", 1);
if (error == 0){
printf("I2C device found at address 8bit: 0x%X 7bit: 0x%X\n", address, address << 1);
nDevices++;
if (nDevices == 0){
printf("No I2C devices found\n");
}else{
printf("\ndone\n");
Adjusting the contrast on the blue box and
#include “mbed.h”
#include “TextLCD.h”
TextLCD_I2C lcd(&i2c_lcd, 0x4E, TextLCD::LCD16x2);
