Made some extensive testing. Turns out FAT filesystem is a really bad choice as no matter how one structures the directory tree, the more files there are on the SD card the longer it takes to create a new file. Even using append mode works only until you have about 40-50 files on the card, afterwards you just can not create or reopen a file fast enough to avoid sensor FIFO overflow.
Here is a simplified code to compare different methods:
#include "FATFileSystem.h"
#include "SDBlockDevice.h"
#include "errno.h"
#define MODE 2 // 1: ofstream 2: std::FILE 3: mbed::FILE 4: plain POSIX ops without any filesystem (blob)
#define SPI_FREQ 12000000
UnbufferedSerial pc(USBTX, USBRX, 115200);
FileHandle *mbed::mbed_override_console(int fd) { return &pc; }
Timer T;
SDBlockDevice sd(MBED_CONF_SD_SPI_MOSI, MBED_CONF_SD_SPI_MISO, MBED_CONF_SD_SPI_CLK, MBED_CONF_SD_SPI_CS, 1000000);
FATFileSystem filesystem("fs");
#if MODE == 1
#include <cstdio>
#include <fstream>
#include <sstream>
ofstream ofile;
#elif MODE == 2
std::FILE *ofile;
#elif MODE == 3
mbed::File ofile;
#endif
uint8_t buf[512];
char fileName_prefix[5] = {0};
char fileName_suffix[26] = {0};
char fileName[32] = {0};
printf("Starting\r\n");
fflush(stdout);
#if MODE < 4
T.start();
filesystem.mount(&sd);
T.stop();
printf("Mounting took: %llu\r\n", T.elapsed_time().count());
fflush(stdout);
T.reset();
#endif
#if MODE == 4
if (0 != sd.init()) {
printf("Init failed \n");
return -1;
printf("sd size: %llu\n", sd.size());
printf("sd read size: %llu\n", sd.get_read_size());
printf("sd program size: %llu\n", sd.get_program_size());
printf("sd erase size: %llu\n", sd.get_erase_size());
fflush(stdout);
#endif
sd.frequency(SPI_FREQ);
// Create the dummy data
for (int i = 0; i < sizeof(buf); i++) {
buf[i] = (uint8_t)i;
printf("Dummy buffer created\r\n");
fflush(stdout);
for (int n = 0; n < 10; n++) {
#if MODE == 1 || MODE == 2
strcpy(fileName_prefix, "/fs/");
#elif MODE == 3
strcpy(fileName_prefix, "");
#endif
#if MODE < 4
sprintf(fileName_suffix, "test_ofstream%d.txt", n);
strcpy(fileName, fileName_prefix);
strcat(fileName, fileName_suffix);
T.start();
#if MODE == 1
ofile.open(fileName, std::ofstream::app);
#elif MODE == 2
ofile = fopen(fileName, "a");
#elif MODE == 3
ofile.open(&filesystem, fileName, O_WRONLY | O_APPEND);
#endif
T.stop();
printf("Opening %s file took %llu\r\n", fileName, T.elapsed_time().count());
fflush(stdout);
T.reset();
#endif
T.start();
for (int o = 0; o < 16 * 512; o++) { // Write 4 megabytes of data
#if MODE == 1
ofile.write((char *)&buf, sizeof(buf)); // 136KB/sec@12MHz
#elif MODE == 2
fwrite(&buf, 1, sizeof(buf), ofile); // 78KB/sec@12MHz
#elif MODE == 3
ofile.write(&buf, sizeof(buf)); // 151KB/sec@12MHz
#elif MODE == 4
// erase in advance is needed
if (0 != sd.erase((n * sizeof(buf) + o * sizeof(buf)), 512)) {
printf("Error Erasing block \n");
fflush(stdout);
// write data
sd.program(&buf, (n * sizeof(buf) + o * sizeof(buf)), 512); // 190KB/sec @12MHz
#endif
#if MODE == 1
ofile.flush();
#elif MODE == 2
fflush(ofile);
#elif MODE == 3
ofile.sync();
#endif
T.stop();
printf("Writing data took: %llu\r\n", T.elapsed_time().count());
fflush(stdout);
T.reset();
T.start();
#if MODE == 1
ofile.close();
#elif MODE == 2
fclose(ofile);
#elif MODE == 3
ofile.close();
#endif
T.stop();
printf("Closing took: %llu\r\n\n", T.elapsed_time().count());
fflush(stdout);
T.reset();
return 0;
In terms of file creation time there are only slight differences between using ofstream/std::FILE/mbed::File, however the data transfer rate using std::FILE is only about 50% of any other method. With ofstream i might be missing something as only the 1st cycle has good transfer rate, consecutive write cycles are ca. 10 times slower. Do not know why.
By the way i found the example located at the bottom of the documentation of File API is wrong as it uses std::FILE instead of mbed::File thus makes the documentation misleading.
So if anyone needs to log data to an SD card without a sensor FIFO overflow on a single core MCU will need to use the SD card like a blob storage without FATFS or LittleFS. In which case one shall store the starting addresses&length of each recorded data stream in a separated memory range of the SD card that would allow identication&retrieving valid data in a later moment. In other words one would need to come up with a very basic custom filesystem.
