#include<uart.h>
#include “mbed.h”
#include “stm32EEPROM.h”
#include “packets.h”
#define DB_RX PA_2
#define DB_TX PA_3
#define NU_RX PA_9
#define NU_TX PA_10
#define METER_ISR_BUFFER_SIZE 300
#define LTE_COMMAND_LENGTH 50
#define SOH ‘{’
#define ETX ‘}’
#define WAITING_FOR_START 0
#define WAITING_FOR_END 1
#define METER_PKT_SIZE 52
extern bool bDebug;
// Serial Comm (TXD, RXD)
Serial DbUart(DB_RX, DB_TX);
Serial NuUart(NU_RX, NU_TX);
Serial pc(PB_3, PB_4);
//Serial ports[3] = (pc, NuUart, DbUart);
//Initializing Debug Send flag bit for basic initialization
unsigned int DBUARTSendFlag = 0;
unsigned int NUUARTSendFlag = 0;
unsigned int PCSendFlag = 0;
uint8_t pktBufA[EEPROM_PKT_SIZE],pktBufB[EEPROM_PKT_SIZE],pktBufC[EEPROM_PKT_SIZE];
//Setting buffer index value as volatile for reinitializing when interrupt is comming
volatile uint16_t bufA_index = 0;
volatile uint16_t bufB_index = 0;
volatile uint16_t bufC_index = 0;
uint16_t bufA_outdex = 0;
uint16_t bufB_outdex = 0;
uint16_t bufC_outdex = 0;
//Setting buffer value which stored in this array.Basically, This array is changing time to time.
char buffer1[METER_ISR_BUFFER_SIZE];
char buffer2[METER_ISR_BUFFER_SIZE];
char buffer3[METER_ISR_BUFFER_SIZE];
//Serial_A Interrupt Function
void DBRxInterrupt(void)
while(DbUart.readable())
buffer1[bufA_index] = DbUart.getc();
bufA_index = (bufA_index+1) % METER_ISR_BUFFER_SIZE;
//DBUARTSendFlag = 1;
void NURxInterrupt(void)
while(NuUart.readable())
buffer2[bufB_index] = NuUart.getc();
bufB_index = (bufB_index+1) % METER_ISR_BUFFER_SIZE;
//NUUARTSendFlag = 1;
void PCRxInterrupt(void)
while(pc.readable())
buffer3[bufC_index] = pc.getc();
bufC_index = (bufC_index+1) % METER_ISR_BUFFER_SIZE;
void Init_PCUART(void)
pc.attach(&PCRxInterrupt, Serial::RxIrq);
pc.baud(9600);
void Init_DBUART(void)
DbUart.attach(&DBRxInterrupt, Serial::RxIrq);
DbUart.baud(9600);
void Init_NUUART(void)
NuUart.attach(&NURxInterrupt, Serial::RxIrq);
NuUart.baud(9600);
void checkForMeterPackets()
uint8_t c;
static uint8_t stringingStateA=WAITING_FOR_START;
static uint8_t stringingStateB=WAITING_FOR_START;
static uint8_t stringingStateC=WAITING_FOR_START;
static uint8_t stringingIndexA=0;
static uint8_t stringingIndexB=0;
static uint8_t stringingIndexC=0;
//This index value is testing for port1 data checking
while(bufA_outdex != bufA_index)
//if(bDebug) pc.printf("\rPacket is Here = %d\r",bufA_outdex);
c = (uint8_t)buffer1[bufA_outdex];
bufA_outdex = (bufA_outdex+1) % METER_ISR_BUFFER_SIZE;
switch(stringingStateA)
case WAITING_FOR_START:
if( c==SOH)
//if(bDebug) pc.printf("\rI am in Waiting for Start State:");
stringingIndexA=0;
pktBufA[stringingIndexA++] = c;
stringingStateA = WAITING_FOR_END;
// pc.putc(pktBufA[0]);
break;
case WAITING_FOR_END:
if( c == ETX)
//if(bDebug) pc.printf("\rI am in Waiting for End State: %d",stringingIndexA);
if(stringingIndexA==METER_PKT_SIZE)
if(bDebug) pc.printf("\rI got full packet = %s", pktBufA);
processMeterPacket(1, pktBufA);
stringingIndexA = 0;
else
stringingStateA = WAITING_FOR_START;
else if(stringingIndexA < METER_PKT_SIZE )
else
break;
default:
break;
//This index value is testing for port2 data checking
while(bufB_outdex != bufB_index)
//if(bDebug) pc.printf("\rPacket is Here = %d\r",bufB_outdex);
c = (uint8_t)buffer2[bufB_outdex];
bufB_outdex = (bufB_outdex+1) % METER_ISR_BUFFER_SIZE;
switch(stringingStateB)
if( c==SOH)
stringingIndexB=0;
pktBufB[stringingIndexB++] = c;
stringingStateB=WAITING_FOR_END;
//if(bDebug) pc.putc(pktBufA[0]);
break;
if( c == ETX)
if(stringingIndexB == METER_PKT_SIZE)
processMeterPacket(2, pktBufB);
stringingIndexB = 0;
else
stringingStateB = WAITING_FOR_START;
else if(stringingIndexB < METER_PKT_SIZE )
else
break;
default:
break;
//This index value is testing for port3 data checking
while(bufC_outdex != bufC_index)
//if(bDebug) pc.printf("\rPacket is Here = %d\r",bufC_outdex);
c = (uint8_t)buffer3[bufC_outdex];
bufC_outdex = (bufC_outdex+1) % METER_ISR_BUFFER_SIZE;
switch(stringingStateC)
if(c == SOH)
stringingIndexC=0;
pktBufC[stringingIndexC++] = c;
stringingStateC = WAITING_FOR_END;
break;
if(c == ETX)
if(stringingIndexC==METER_PKT_SIZE)
//if(bDebug) pc.printf("\rI got full packet = %s", pktBufA);
processMeterPacket(3, pktBufC);
stringingIndexC = 0;
else
stringingStateC = WAITING_FOR_START;
else if(stringingIndexC < METER_PKT_SIZE )
else
break;
default:
break;
//repeat for buffer B
