I’m trying to mount FAT on a SDBlockDevice but keep getting -12 (Not enough space) no matter what I try. Manually initializing the device and reading some of the properties works as expected, but when I try to mount I get the error.
The board I’m using is a FRDM-KL25Z and the SD card adapter is HW-125, bought pretty cheaply from one of the Chinese marketplaces (can’t remember which one now). I have a whole bag of these adapters, this seems to be the behaviour with all the ones I tested.
LittleFS crashes with a Hard Fault when I try to reformat, when I trace the error it points to some malloc operation.
Crash Info:
Crash location = _free_r [0x000083CC] (based on PC value)
Caller location = __rtos_malloc_lock [0x00005AEB] (based on LR value)
Stack Pointer at the time of crash = [20001748]
Target and Fault Info:
Processor Arch: ARM-V6M
Processor Variant: C60
I also tried different SD cards with the same result
Here’s the code I’m trying
#include “mbed.h”
#include “SDBlockDevice.h”
SDBlockDevice sd(PTD2, PTD3, PTD1, PTC6); // mosi, miso, sck, cs
#include “FATFileSystem.h”
FATFileSystem fs(“fs”);// #include “LittleFileSystem.h”
// LittleFileSystem fs(“fs”);int main()
// the commented out part is working as expected
// if (0 != sd.init())
// printf(“Init failed \n”);
// return -1;
// printf(“sd size: %llu\n”, sd.size());
// printf(“sd read size: %llu\n”, sd.get_read_size());
// printf(“sd program size: %llu\n”, sd.get_program_size());
// printf(“sd erase size: %llu\n”, sd.get_erase_size());// sd.deinit(); int error = 0; error = fs.mount(&sd); if (error) { printf("%s\n", strerror(-error)); error = fs.reformat(&sd); if (error) { printf("%s\n", strerror(-error)); } }}
Thank you all in advance
