I have scoured the Mbed site and internet for a solution to this problem. I have followed all of the guidance for drivers and ports and still cannot get any output to a terminal window (Putty or CoolTerm).
I am using Windows 10 Home with the basic serial example program and get the following output to the terminal: $$$$10100f2ea3eced51bdc9897acd2f201d7596.
Your help would be greatly appreciated.
#include “mbed.h”
// define the Serial object
Serial pc(USBTX, USBRX);
DigitalOut led1(LED2);
while (true) {
led1 = !led1;
// Print something over the serial connection
pc.printf("Blink! LED is now %d\r\n", led1.read());
wait(0.5);
Thank you for the prompt reply.
Following your suggestion I have received the following (abbreviated) response from the compiler:
mbed compile -t GCC_ARM -m LPC1768
[Error] main.cpp@20,2: #error [NOT_SUPPORTED] test not supported
Following subsequent failures, I imported and tried mbed-os-example-blinky. This compiled and behaved as expected.
I then ran mbed detect and received the following output:
[mbed] Detected LPC1768, port None, mounted H:, interface version unknown:
[mbed] Supported toolchains for LPC1768
Target
mbed OS 2
mbed OS 5
uARM
IAR
ARM
GCC_ARM
ARMC5
LPC1768
Supported
Supported
Supported
Supported
Supported
Supported
Supported targets: 1
Supported toolchains: 4
I note that despite Windows device Manager reporting the port etc (mbed Serial Port(COM3)) all working properly, the above report identifies no port.
@girrion Did you reset your LPC1768 after flashing your original program?
As for “[Error] main.cpp@20,2: #error [NOT_SUPPORTED] test not supported”, you are missing macro definitions. Looks like the example defines one of them in mbed_app.json (not sure how the others are defined). See line 19 to 21. If you just want to see some actions, I think you can just comment these out.
#if !defined(MBED_CPU_STATS_ENABLED) || !defined(DEVICE_LPTICKER) || !defined(DEVICE_SLEEP)
#endif
In any case, you want to press the reset button after flashing a new program.
Following @lonesometraveler advice, and compiling and flashing the code you suggested earlier to the LPC1768 resulted in LED1 blinking on and off a couple of times, but provided no printed output to any of the terminal programs.
I have resolved the port detection issue as you can see below
[mbed] Detected LPC1768, port COM3, mounted H:, interface version unknown:
Target
mbed OS 2
mbed OS 5
uARM
IAR
ARM
GCC_ARM
ARMC5
LPC1768
Supported
Supported
Supported
Supported
Supported
Supported
Using the mbed serial terminal mbed sterm
and connecting to the LPC1768 board; I can reset from this terminal but I still cannot output anything to sterm, CoolTerm or Putty.
Hoping you can help with this.
I have re-run the test program you suggested in your first response and pasted the log output below.
Output from cpu-stats.log:
[1575134137.39][HTST][INF] host test executor ver. 0.0.10
[1575134137.39][HTST][INF] copy image onto target…
1 file(s) copied.
[1575134141.41][MBED][WRN] Target ID not found: Skipping flash check and retry
[1575134141.50][HTST][INF] starting host test process…
[1575134141.84][CONN][INF] starting connection process…
[1575134141.84][CONN][INF] notify event queue about extra 60 sec timeout for serial port pooling
[1575134141.84][CONN][INF] initializing serial port listener…
[1575134141.85][SERI][INF] serial(port=COM3, baudrate=9600, read_timeout=0.01, write_timeout=5)
[1575134141.85][SERI][INF] reset device using ‘default’ plugin…
[1575134141.86][HTST][INF] setting timeout to: 60 sec
[1575134142.11][SERI][INF] waiting 1.00 sec after reset
[1575134143.11][SERI][INF] wait for it…
[1575134143.11][SERI][TXD] mbedmbedmbedmbedmbedmbedmbedmbedmbedmbed
[1575134143.12][CONN][INF] sending up to 2 __sync packets (specified with --sync=2)
[1575134143.12][CONN][INF] sending preamble ‘fb5fe8bc-38dd-4b2b-b876-079f99dea266’
[1575134143.12][SERI][TXD] {{__sync;fb5fe8bc-38dd-4b2b-b876-079f99dea266}}
[1575134148.12][CONN][INF] Reset the part and send in new preamble…
[1575134148.12][SERI][INF] reset device using ‘default’ plugin…
[1575134148.39][SERI][INF] waiting 1.00 sec after reset
[1575134149.39][SERI][INF] wait for it…
[1575134149.39][CONN][INF] resending new preamble ‘ca76689e-0531-4b9e-8882-2c3b465ecb3c’ after 5.00 sec
[1575134149.39][SERI][TXD] {{__sync;ca76689e-0531-4b9e-8882-2c3b465ecb3c}}
[1575134149.42][HTST][ERR] None
[1575134149.42][HTST][WRN] stopped to consume events due to __notify_sync_failed event
[1575134149.43][HTST][INF] __exit_event_queue received
[1575134149.43][HTST][INF] test suite run finished after 7.57 sec…
[1575134149.43][HTST][INF] CONN exited with code: 0
[1575134149.43][HTST][INF] No events in queue
[1575134149.43][HTST][INF] host test result() call skipped, received: sync_failed
[1575134149.43][HTST][WRN] missing __exit event from DUT
[1575134149.43][HTST][INF] calling blocking teardown()
[1575134149.44][HTST][INF] teardown() finished
[1575134149.44][HTST][INF] {{result;sync_failed}}
Hello @hudakz,
The board has the latest firmware (141212) and flashes programs with no difficulty, both from the online and off line compilers. Additional programs such as “Use the U and D keys to make LED1 brighter or dimmer” from the “Board to PC communication over USB” manual function as expected, but no text data can be sent to a terminal e.g. Putty, CoolTerm or sterm. Interestingly each time I disconnect from a terminal and reconnect, the terminal displays the following $$$$10100f2ea3eced51bdc9897acd2f201d7596, which seems to be “target_id_usb_id”: “10100f2ea3eced51bdc9897acd2f201d7596”.
I need to resolve this issue quickly, so any help you can offer will be greatly appreciated.
Hi @maygup01,
Have you had an opportunity to review the information I have posted?
I have had no luck resolving this issue of serial to pc comms (print output to screen) and would really appreciate your input.
I’m having much the same problem as Mark, only mine is using a new Win10 machine, Any resolution on this problem? My code use to work in 2018 when I first wrote it and was using TeraTerm. I could run the code and see the data. Now, TeraTerm doesn’t seem to work nor Putty. My code has all the same required lines for using a serial port.
…but after 2 hours with another mbed programmer, we discovered:
//in order to have a serial terminal viewer working to view your code’s output…
//go to Windows serial configuration - Handbook | Mbed
//to download the mBED WINDOWS SERIAL PORT DRIVER
