Hi all,
I have problems to set up a simple Unit test on mbed 6.15.1
I followed the official online tutorial without success… !
https://os.mbed.com/docs/mbed-os/v6.15/debug-test/unit-testing.html
It works on previous mbed version. I tried the 6.10 (Unit testing - Debugging and testing | Mbed OS 6 Documentation)
But, as things changed, I am trying to set up unit tests the new way.
After followed the tutorial and created the relevant files and classes, I ran the command :
mbed test --unittests
and the error is
[ 47%] Building CXX object connectivity/lorawan/tests/UNITTESTS/features/lorawan/loraphyeu868/CMakeFiles/lorawan-loraphy-eu868-unittest.dir/__/__/__/__/__/lorastack/phy/LoRaPHYEU868.cpp.o
/usr/bin/ld : can't find -lmbed-stubs-example-interface
I tried several things without success.
It may be a tuto missreading, but I have the impression that the tutorial forgot some files
- the
OtherClassdefinition. I commented the relevant line for the moment -
example_interface_api.h. I created the file with the function definition in UNIITESTS/stubs/example folder
but anyway, the linker can’t find mbed-stubs-example-interface at some point, even if a add it in UNITTESTS/stubs/CMakeLists.txt !
I may made some mistakes in file structure ;/
Any help welcome (or a working example on a repo ![]()
Thanks in advance,
Sebastien
