Mbed greentea utest header not found
Hi Sir,
I added a unit test according to:
Greentea testing applications - Tools | Mbed OS 5 Documentation
When I compile the simple test, tests-test-AcmInit-simple-test, the following compilation error happens:
    *[Fatal Error] main.cpp@7,10: 'utest/utest.h' file not found*
  •    [DEBUG] Return: 1*
  •    [DEBUG] Output: .\TESTS\test-AcmInit\simple-test\main.cpp:7:10: fatal error: 'utest/utest.h' file not found*
  •    [DEBUG] Output: #include "utest/utest.h"*
  •    [DEBUG] Output:          ^~~~~~~~~~~~~~~*
  •    [DEBUG] Output: 1 error generated.*
In my project custom_targets.json, I added “utest” in “requires”.
Can I know how to include folder of “\mbed-os\features\frameworks\unity” properly?
Shoujie
how have you set up your program? How are you compiling it ? What version of Mbed OS are you using?
All this information is needed before we can start to help you…
Anna
Hi Anna,
Sorry for any confusion.
I am setting up a unit test for my normal project. The normal project compiles fine, but the unit test project cannot compile.
The Mbed OS is 6.9 and I am creating a test case according to:
https://os.mbed.com/docs/mbed-os/v6.9/debug-test/greentea-for-testing-applications.html
As far as my understanding, this is a problem of configuring the utest folder (\mbed-os\features\frameworks) into the test. (not in .includes_4401223b411031052ec32817b89f12dd.txt, the automatically generated include file list)
The compiling command starts from the normal project root and there are configuration items for the UT project:
mbed test -t ARMC6 -m UTT -n tests-test-Init-simple-test
Thanks a lot,
Shoujie
Hi there,
I got my unit test case compiled. I found in my root project folder file .mbedignore that utest and unity were commented out:
mbed-os/features/frameworks/unity/*
mbed-os/features/frameworks/utest/*
However, it reports another error:
mbedgt: detecting connected mbed-enabled devices…
mbedgt: no compatible devices detected
mbedgt: completed in 0.01 sec
mbedgt: exited with code 1
BTW, I am wondering where there is a checklist or FAQ for us to check these questions?
Thanks a lot,
Shoujie
