Dear all,
How to add the “flashiap-block-device” in the mbed_app.json ?
I want to configure the “base-address” and “size” for the flash block device.
I had try below code , but don’t work …
“target_overrides”: {
“platform.stack-stats-enabled”: true,
“platform.heap-stats-enabled”: true,
“platform.cpu-stats-enabled”: true,
“platform.thread-stats-enabled”: true,
“platform.sys-stats-enabled”: true
“NUCLEO_L432KC”: {
“target.flashiap-block-device”: {
“base-address”: “0x08000000”,
“size”: “0x4000”
Note:
Mbed OS: 6.12
Best Regards,
Jason
hudakz
(Zoltan Hudak)
June 29, 2021, 12:44pm
2
Hello Jason,
Try to replace
"NUCLEO_L432KC": {
"target.flashiap-block-device": {
"base-address": "0x08000000",
"size": "0x4000"
with
"NUCLEO_L432KC": {
"flashiap-block-device.base-address": 0x08000000,
"flashiap-block-device.size": 0x4000
You can find additional info on how to configure Mbed library parameters here .
In this case the name of the associated library is flashiap-block-device as indicated in the
mbed-os/storage/blockdevice/COMPONENT_FLASH/mbed_lib.json file.
The parameters to configure are base-address and size.
JohnnyK
(Jan Kamidra)
June 29, 2021, 12:49pm
3
you also probably need to check if STM32L4 family has FlashIAP added in the target.json . If not then you need to add it.
"target.components_add": ["FLASHIAP"]
Dear JohnnyK
Yes, I had the"target.components_add": [“FLASHIAP”] in the mbed_app.jason already.
Thanks.
Dear Hudakz,
Yes, Your suggestion works well.
Best Regards,
Jason
