Hey. I’m trying to run a MQTT cliend with Quectel EC25 modem, using AT TCP/IP commands.
Since mbed does not support AT commands for EC25, I had do port the stack from BG96 modem. (which uses the same commands)
After few minutes of running, meaning, MQTT succesfully connects, and always at the same spot, I get some weird read error from the low level of the driver:
[INFO][CELL]: AT RX (18): <cr><ln>+QIRD: 0<cr><ln><cr><ln>OK<cr><ln>
[INFO][CELL]: AT TX ( 8): AT+QIRD=
[INFO][CELL]: AT TX ( 1): 0
[INFO][CELL]: AT TX ( 1): ,
[INFO][CELL]: AT TX ( 1): 1
[INFO][CELL]: AT TX ( 1): <cr>
[INFO][CELL]: AT RX (13): <cr><ln>+QIRD<cr><ln>OK<cr><ln>
[ERR ][CELL]: Socket 0 recv error -1
Looking closely at this, I spotted that for some reason, the last +QIRD response is missing characters, which I’m guessing causes the error.
Sometimes it fails like so:
[INFO][CELL]: AT RX (13): <cr><ln>+QIR<ln><cr><ln>OK<cr><ln>
I’m running buffered serial with 115200 baud rate and flowcontrol (this baud rate is set as default on the modem)
Any insight would be greatly appreciated
