- I do not think it is good practice connect Morpho headers to breadboards.
- You also wrote about some library, but you do not include any library and also you not have any library in your project.
- Methods, what you call in the context of SPI do not make sense. SPI does not have such methods. So you probably copied and rewrote the constructor from a Graphic library.
spi.text_width(1);
spi.text_height(1);
spi.filled_circle(bx, by, 2, 0xffffff);
spi.filled_rectangle(0, P1y1, 3, P1y2, 0xffffff);
spi.filled_rectangle(124, P2y1, 127, P2y2, 0xffffff);
spi.filled_rectangle(0, 9, 3, P1y1-1, 0);
spi.filled_rectangle(0, P1y2+1, 3, 127, 0);
spi.filled_rectangle(124, 9, 127, P2y1-1, 0);
spi.filled_rectangle(124, P2y2+1, 127, 127, 0);
spi.line(5, 8, 122, 8, 0xffffff);
spi.locate(2,0);
spi.printf("P1: %d P2: %d",P1S,P2S);
- you can check similar project across the Mbed web - Search | Mbed.
For example here is similar topic - Pong with ARM Cortex M3 and LPC1768 - Mbed OS - Arm Mbed OS support forum
