Migrating from an NUCLEO-F091RC where I am using HAL_FLASH_Program to do EEPROM emulation as per ST’s application note, where the code works fine, to a NUCLEO-L073RZ where mbed-os gives a hard fault.
I’ve stripped it out to a very basic program:
#include “mbed.h”
// Blinking rate in microseconds
#define BLINK 2500000
printf("\n\nosblink1TEST\n");
printf(__TIMESTAMP__"\n");
printf("mbed-os version: %d.%d.%d\n",MBED_MAJOR_VERSION, MBED_MINOR_VERSION,MBED_PATCH_VERSION);
DigitalOut led(LED1);
DigitalInOut led2(PB_12);
led2.mode(OpenDrain); // Set to open drian
led2.output(); // Set to output
led2 = 0; // Pull low
uint32_t targetAddr = 0x0802FF00;
uint32_t data = 0x12345678;
printf("Write 0x%08x to addr 0x%08x...\n", data, targetAddr);
HAL_FLASH_Unlock();
printf("flash unlocked\n");
volatile HAL_StatusTypeDef status;
printf("HAL_StatusTypeDef created\n");
status = HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, targetAddr, data);
printf("data written\n");
if(status == HAL_OK) {
printf("HAL_OK");
} else {
printf("ERROR");
HAL_FLASH_Lock();
printf("flash locked\n");
printf("starting loop\n");
while (true) {
led = !led;
printf("cycle1\n");
wait_us(BLINK);
led = !led;
led2.input(); // Set to open drain
printf("cycle2\n");
wait_us(BLINK);
And the terminal output is
osblink1TEST
Wed Dec 23 11:14:22 2020
mbed-os version: 6.6.0
Write 0x12345678 to addr 0x0802ff00…
flash unlocked
++ MbedOS Fault Handler ++
FaultType: HardFault
Context:
R 0: 00000000
R 1: 0000005B
R 2: 00000042
R 3: 00000175
R 4: 12345678
R 5: 0802FF00
R 6: 0000C350
R 7: 2000206C
R 8: 00000000
R 9: 00000000
R 10: 00000000
R 11: 00000000
R 12: 00000000
SP : 20001400
LR : 080019AF
PC : 08001778
xPSR : 61000000
PSP : 200013E0
MSP : 20004FC8
CPUID: 410CC601
Mode : Thread
Priv : Privileged
Stack: PSP
– MbedOS Fault Handler –
++ MbedOS Error Info ++
Error Value: 0x20001680
Current Thread: main Id: 0x20001A24 Entry: 0x80058B1 StackSize: 0x1000 StackMem: 0x20000460 SP: 0x20001400
For more info, visit: https://mbed.com/s/error?error=0x80FF013D&tgt=NUCLEO_L073RZ
– MbedOS Error Info --``
So it is failing when HAL_FLASH_Program is called.
I’ve tested the following combinations:
L073, mbed 6.6.0 - result: hard fault
L073, mbed 5.15.6 - result: hard fault
L073, mbed 2.0.165 - result: works OK
F091, mbed 6.6.0 - result: works OK
F091, mbed 5.15.6 - result: works OK
Can anyone see a problem in the above code?
I know that the L073 has a dedicated ‘EEPROM’ area but that is besides the point really, I need to be able to call HAL_FLASH_Program
