Flash memory throws a hard fault error
I’m having trouble using the HAL_FLASH_Program, every time it throws a hard fault error. Even when I’ve checked the memory I’m accessing and the page size.
The code is
#include <mbed.h>
#include “stm32l4xx_hal.h”
#define page249addr 0x807C800
void save(uint32_t data, uint32_t address)
HAL_FLASH_Unlock();
HAL_FLASH_OB_Unlock();
HAL_StatusTypeDef statusprogram;
statusprogram = HAL_FLASH_Program(FLASH_TYPEPROGRAM_DOUBLEWORD,address,data);
uint32_t error = HAL_FLASH_GetError();
if (statusprogram != HAL_OK){
printf(“Error %lu\n”,error);
HAL_FLASH_OB_Lock();
HAL_FLASH_Lock();
// put your setup code here, to run once:
HAL_Init();
save(30.8,page249addr);
while(1) {
// put your main code here, to run repeatedly:
It would be great if someone can point out what I’m doing wrong?
Thank you in advance
please add ``` before and after your inserted code snippets, so that the code stays formatted and is more readable.
Regarding your problem:
Did you restrict the flash size for mbed OS by adding something like "target.restrict_size": "0x807C800" to the mbed_app.json file?
For easier usage of the MCU flash you can also use the Flash IAP interface.
