Mbed-https: Unable to resolve https-address
I am currently trying to connect to an https webserver via mbed-http.
Unfortunately, I am encountering the error that my HTTPS request returns an NSAPI_ERROR_NO_CONNECTION (-3004) error. If I change the URL to the IP of the webserver, the error changes to NSAPI_ERROR_AUTH_FAILURE] (-3011), this is my code:
std::string http_request_str(staging_backend_url);
http_request_str.append(endpoint).append(api_key);
printf("HTTP Request String: %s\r\n", http_request_str.c_str());
HttpRequestBase *get_req;
if(https) {
	get_req = new HttpsRequest(network, tls_certificates, HTTP_GET, http_request_str.c_str());
} else {
	get_req = new HttpRequest(network, HTTP_GET, http_request_str.c_str());
HttpResponse *get_res = get_req->send();
if (!get_res) {
	printf("HttpRequest failed with error code %d\r\n", get_req->get_error());
	return false;
To me it looks like that mbed-os is unable to resolve the URL. The second problem is that the webservice is behind Cloudflare which is probably the reason why direct IP accesses don’t work.
Any ideas how to fix this?
What a version for MbedOS and mbed-http do you use?
You probably need to call method of the NetworkInterface gethostbyname for your URL address, that will translate it to the IP address (SocketAddress).
I took original mbed-http and made some updates, so you can try updated version of mbed-http and two basic examples for MbedOS 6+.
The mbed-http has two options (overloaded constructor):
  • pass NetworkInterface - the gethostbyname is called inside the library (only updated no original)
  • pass TCPsocket - the gethostbyname must be called by you
When the certification is not valid/outdated, the check this - Adding TLS Sockets to Mbed OS | Mbed
Hello Jan,
thank you so much for your reply.
I use Mbed-OS 6.12.0 and mbed-http tip from here: mbed-http - HTTP and HTTPS library for Mbed OS 5 | Mbed.
I also use BSP_DISCO_F746NG tip.
If I change my code to this (added the gethostbyname as you recommended):
std::string http_request_str;
if(https) {
	http_request_str = backend_url;
} else {
	http_request_str = dev_backend_url;
http_request_str.append(endpoint).append(device_key);
SocketAddress temp_socket;
const nsapi_error_t error = network->gethostbyname(http_request_str.c_str(), &temp_socket);
printf("NSAPI RESULT: %d\r\n", error);
printf("Address: %s\r\n", temp_socket.get_ip_address());
if(https) {
} else {
if (!get_res) {
	return false;
it takes about two minutes or so until the function returns with
NSAPI RESULT: -3009
Any ideas what else I can do?
Ye, that is the original library but is not compatible with MbedOS 6+.
NSAPI_ERROR_DNS_FAILURE (DNS failed to complete successfully)
NSAPI_ERROR_DNS_FAILURE indicates that DNS failed to complete successfully. Check the host name and network connection.
Also there were a bug NSAPI DNS queries failing for some websites · Issue #3926 · ARMmbed/mbed-os · GitHub in the past.
Okay, that is unfortunate.
Is there a replacement-library for Mbed OS6 which supports https-requests?
I tested it only with URLs what are in examples what are in TEST folder.
Please, let me know.
I removed the original mbed-http library and installed your version of it but I am getting the same error.
Ok, that seems to to be a not library related issue but for sure you can run the exmple code from TEST folder.
The HTTPS-GET example returns after 2 minutes or so with an error -3003
which means " NSAPI_ERROR_PARAMETER: invalid configuration "
Strange, I will check it at home, also with Disco-F746NG.
Ok, I tried mbed-http with MbedOS 6.12 on Nucleo-F429ZI and Disco-F746NG and executed this code. They both seem to work.
See log
Example of a HTTPS client
[NWK] Connecting to network…
[NWK] Connected to the network
[NWK] IP address: 10.0.1.26
----- HTTPS GET request -----
----- HTTPS GET response -----
Status: 200 - OK
Headers:
Date: Wed, 14 Jul 2021 17:23:24 GMT
Content-Type: text/plain
Content-Length: 14
Connection: keep-alive
Last-Modified: Sat, 17 Nov 2018 12:02:53 GMT
ETag: “5bf0036d-e”
Expires: Thu, 15 Jul 2021 03:23:24 GMT
Cache-Control: max-age=36000
Accept-Ranges: bytes
Strict-Transport-Security: max-age=31536000; includeSubDomains; preload
Body (14 bytes):
Hello world!
----- HTTPS POST request -----
----- HTTPS POST response -----
Status: 200 - OK
Headers:
Date: Wed, 14 Jul 2021 17:23:26 GMT
Content-Type: application/json
Content-Length: 376
Server: gunicorn/19.9.0
Access-Control-Allow-Origin: *
Access-Control-Allow-Credentials: true
Body (376 bytes):
“args”: {},
“data”: “{"hello":"world"}”,
“files”: {},
“form”: {},
“headers”: {
“Content-Length”: “17”,
“Content-Type”: “application/json”,
“Host”: “httpbin.org”,
“X-Amzn-Trace-Id”: “Root=1-60ef1d8e-022c176b6fc8e29b53c9c1f2”
“json”: {
“hello”: “world”
“origin”: “90.182.255.79”,
“url”: “https://httpbin.org/post
Do you have a public URL what I can test?
Thanks for your reply.
I get this response:
HttpRequest failed (error code -3003)
Maybe something is wrong with my internal DNS server. I’ll try to add Google DNS
Edit: Also doesn’t work if I add Google DNS :confused:
I wanted to see a list of DNS (I thought there were some defaults ) it but when I tried to call get_dns_server the result is No DNS -3006 = IP address is not known and when I add one, then the result is same.
   SocketAddress *dnsAddr;
   int result = 0;
   if((result = network->get_dns_server(0,dnsAddr)) == NSAPI_ERROR_OK){
       printf("DNS IP %d: %s\n", 0, dnsAddr->get_ip_address());
   else{
       printf("No DNS %d\n", result);
I also tried add a DNS server, especially CloudFlare public DNS server
network->add_dns_server(SocketAddress("1.1.1.1"),name);
It want to pass an interface name, but that cause a MbedOS crash when you tried to read it back.
    char name[5];
    network->get_interface_name(name);
    int result = 0;
    result = network->add_dns_server(SocketAddress("1.1.1.1"),name);
    printf("DNS add %d\n", result);
    int atempt = 0;
    while(1){
        if((result = network->get_dns_server(atempt,dnsAddr,name)) == NSAPI_ERROR_OK){
            printf("DNS IP %d: %s\n", atempt++, dnsAddr->get_ip_address());
        else{
            break;
Dear @JojoS, do you have any idea?
this is some testcode that I used:
    // print DNS entries
    err = NSAPI_ERROR_OK;
    int index = 0;
    while(err == NSAPI_ERROR_OK) {
        err = net.get_dns_server(index++, &sockAddr, "st0");
        if ((err == NSAPI_ERROR_OK) || (index == 1)) {
        switch (sockAddr.get_ip_version()) {
            case NSAPI_IPv4: printf("DNS #%d IPv4: ", index); break;
            case NSAPI_IPv6: printf("DNS #%d IPv6: ", index); break;
            default: printf ("DNS #%d IPv unknown: ", index);
            (err == NSAPI_ERROR_OK) ? printf(" %s\n", sockAddr.get_ip_address()) : printf("get DNS err: %d\n", err);
With a fixed name for ST boards, your solution with getting the interface name looks cleaner.
I remember that there is a fixed DNS built in the code, the google address 8.8.8.8:
Ah, the if and switch statements with IP version sorting are probably necessary, I knew you will advise :wink:
    nsapi_error_t err;
    char name[10];
    // add CloudFlare public DNS resolver
    if ((err = network->add_dns_server(SocketAddress("1.1.1.1"),name))== NSAPI_ERROR_OK) {
        printf("DNS added successfully\n");
    else printf("DNS add error: %d\n", err);
    SocketAddress sockAddr;
    int index = 0;
        err = network->get_dns_server(index++, &sockAddr, name);
Thank you for the response and your help :slight_smile:
I tried this code:
    connect_status = NSAPI_ERROR_OK;
    int index = 0;
    while(connect_status == NSAPI_ERROR_OK) {
        connect_status = network->get_dns_server(index++, &sockAddr, "st0");
        if ((connect_status == NSAPI_ERROR_OK) || (index == 1)) {
                case NSAPI_IPv4: printf("[NWKH] DNS #%d IPv4: ", index); break;
                case NSAPI_IPv6: printf("[NWKH] DNS #%d IPv6: ", index); break;
                default: printf ("[NWKH] DNS #%d IPv unknown: ", index);
            (connect_status == NSAPI_ERROR_OK) ? printf(" %s:%d\n", sockAddr.get_ip_address(), sockAddr.get_port()) : printf("get DNS err: %d\n", connect_status);
And sockAddr.get_port() is always 0. Can someone confirm this? Shouldn’t this be the typical DNS port 53?
My problem still is that line 62 of mbed-http - Fork of SandBox’s original mbed-http (https://os… | Mbed fails with error -3009. Any ideas where to start debugging?
Edit:
I changed NetworkInterface::gethostbyname to this:
nsapi_error_t NetworkInterface::gethostbyname(const char *name, SocketAddress *address, nsapi_version_t version, const char *interface_name)
    printf("STACK NAME: %s\r\n", typeid(get_stack()).name());
    return get_stack()->gethostbyname(name, address, version, interface_name);
with the result P12NetworkStack. After grep-ing for this name I only get entries in .map-files so it looks to me like this is some kind of binary-blob which is linked at compile time? But where is the source-code?
Can I switch the network-stack?
Edit: Okay, I think I found the solution thanks to this post: Gethostbyname() question - Mbed OS - Arm Mbed OS support forum
network->gethostbyname(_parsed_url->host(), &address, NSAPI_IPv4, "st0");
Notice the two additional parameters at the end.
just for clarification, after this
the rest is working and do you are able to connect?
Thank you
Your example code is working fine (accessing https://os.mbed.com/media/uploads/mbed_official/hello.txt) but I get -3011 error for accessing my cloudflare-website.
Basically what I did was openssl s_client -connect <my_page>:443 -showcerts and then copy the two certificates into my mbed-project.
Maybe I am using the wrong certificates?
Yes, I did it same and cope&pase the last one, according to Adding TLS Sockets to Mbed OS | Mbed
How did you get mbed_trace working? I set "mbed-trace.enable": 1 in mbed_app.json and added this library to my project: mbed-trace - Tracing Library | Mbed as well as mbed_trace_init(); but it fails with several compiler errors in mbed_trace.c.
Edit: Oh okay, it looks like mbed_trace is built-in now so I don’t need the library.
Something isn’t working though:
[INFO][TLSW]: Starting TLS handshake with ��1zg
w�6v}��߅�>��V¤Tr�z���78�L¬±����X�]�c�A�@°�?s�m��c³O¯%¨¹'#a269dt�z¹b�^����6Q6��� )Dz�:T�§E
[ERR ][TLSW]: mbedtls_ssl_handshake() failed: -0x7780 (-30592): SSL - A fatal alert message was received from our peer
