Hello, guys.
I’m trying to make a secure connection between the server and the client.
The server is on stm32f4 platform with LwIp and FreeRTOS.
For test connection I am using two utilities:
First, compiled from mbedtls repository ssl_client2 ssl_client2 ca_file=~/ca.crt key_file=~/client.key crt_file=~/client.crt debug_level=5 server_addr=192.168.0.254 server_port=4433
Second is openssl s_client: openssl s_client -crlf -cert ~/client.crt -key ~/client.key -CAfile ~/ca.crt -debug -connect 192.168.0.254:4433
Both clients can successfully connect to server and fail with different cases:
openssl is failed with Illegal Parameter (47)
ssl_client2 failed with Decrypt Error (51)
About keys and certs.
Device uses server cert and server pk, client uses client cert and client pk, both use same CA cert.
All certs and pk taken from cert.c in mbedtls git repo.
As well we dont have RTC and NTC but this can’t be an issue since server certs are valid.
The questions:
How to prove the validity of keys and certs?
Can I make more optimizations in device config to save flash?
Why clients fails with different codes?
Does these codes rely on my configuration or on cert/pk contains?
Ho I can debug, of fix this issue?
Thank you for help!
UPD:
openssl verify -CAfile=./ca.crt -show_chain -verbose ./client.crt
./client.crt: OK
Chain:
depth=0: C = NL, O = PolarSSL, CN = PolarSSL Test Client 2 (untrusted)
depth=1: C = NL, O = PolarSSL, CN = Polarssl Test EC CA
Hi @disgust
Thank you for your question and interest in Mbed TLS!
You can use the sample applications ./cert_app to verify the certificates. However, since your client throws a decrypt error, it probably means that you are doing some renegotiation, which means that first negotiation was probably some successful.
These two clients are two different TLS stacks, and implemented differently. One client may decide the fatal alert is of type A and the other may decide it’s of type B.
Could be. It depends what ciphersuite was sent\ ecp curve, cerdtificate, etc…
Since the failure is on your client application, which sends the fatal alert, you could( on ssl_client2 application):
use a debugger on the client application.
Look at the log output ( printed with debug_level=5 )
Use a local server ( ssl_server2 ) compiled with the shown configuration.
I use test PK and test certs provided by mbedtls, as well as mbed tls client application built without any changes. Why this does not work? What can be wrong?
With cert_app I have following output.
Unfortunately I’m new in SSL/TLS so this error does not tell anything to me.
How can I get or set expecting CN?
./cert_app ca_file="/root/ca.crt" mode=ssl server_name=192.168.0.254 server_port=4433 debug_level=5 permissive=1
. Loading the CA root certificate ... ok (0 skipped)
Verify requested for (Depth 1):
cert. version : 3
serial number : C1:43:E2:7E:62:43:CC:E8
issuer name : C=NL, O=PolarSSL, CN=Polarssl Test EC CA
subject name : C=NL, O=PolarSSL, CN=Polarssl Test EC CA
issued on : 2013-09-24 15:49:48
expires on : 2023-09-22 15:49:48
signed using : ECDSA with SHA256
EC key size : 384 bits
basic constraints : CA=true
This certificate has no flags
Verify requested for (Depth 0):
cert. version : 3
serial number : 09
subject name : C=NL, O=PolarSSL, CN=localhost
issued on : 2013-09-24 15:52:04
expires on : 2023-09-22 15:52:04
EC key size : 256 bits
basic constraints : CA=false
! The certificate Common Name (CN) does not match with the expected CN
The reason for your failure is because the server hostname doesn’t fit the server certificate subject \ subject alternative name. ( This is one of the checks done on the certificate)
Unfortunately, in the cert_app the server_name and server_addr are the same.
You should change the value of the server_name given in mbedtls_ssl_set_hostname to “localhost” as this is the CN of your server certificate
If I plovide big list of ciphersuites on both sides how mbedtls stack choose the one to use?
OK, seems I have same error with cert_app as with ssl_client2
mbedtls_pk_verify() returned -19968 (-0x4e00)
Since this alert is produced by client this means that here is something wrong with client PK…
I have double checked contains of keyfile and it’s same key provided in repo along with client certificate.
Is it possible it’s requires non-NULL password?
UPD:
Finaly. I checked my initializing flow. Make a few changes in this (using ssl_pthread_server.c as an example).
Now I got an error -19584 on server side.
And sometimes it hangs on
MBEDTLS_MPI_CHK( mbedtls_mpi_add_mpi( &T, &P->X, &S ) ); MOD_ADD( T );
Looks like while( 0 ) in the macro turns to while( 1 ).
I have checked heap and stacks and there is no problems with overflow. Strange.
The error you are referencing means that the calculated R is not equal to the given r.
In short, that the signature is not correct.
This could probably mean that the public key you are using to verify your certificate is not the key pair of the private key that was used to sign the certificate.
Is the certificate self signed? Did you supply the correct CA root certificate( e.g. subject name of CA certificate is same is the issuer name of the server certificate, the Ca certificate public key is of same algorithm type that signed the device certificate, etc… )?
As you can see here, the server iterates over the list of configured ciphersuites, and compares to the list of ciphersuites given in the client hello message. The first ciphersuite that matches, is chosen by the server.
I hope I understand correct. I use CA certificate from cert.c file from mbedtls folder. I hope client and server certificates provided in the same folder issued with given CA cert. As well I hope the private keys matches with public keys from that certificates.
So if client uses full list and I change the order of ciphersuites on server side - I have different algorhitm. Can selected ciphersuite affect to handshake?
As well I get that chosen curves (defined in config file) should match to used in certificates. How to know curve used in certificate?
UPD:
Finaly I am sure that provided certs and key are correct. I can successfully connect between openssl s_client and openssl s_server on localhost using it.
So now I think that there is something wrong with one of following instances:
Hi @disgust
I don’t think that it’s our entropy source, as randomness is not involved in the verification process, and the certificate is not signed by the device.
However, it is quite possible that the server initialization process is lacking something.
What is the ECP window size in your configuration? ECP max bits? etc…
Some observation:
When I am trying to connect first time - the error -19584 on server side
After that all errors is happening on client side (-19968 (-0x4e00))
./strerror -19584
Last error was: -0x4c80 - ECP - Invalid private or public key
It is returned by sev eral places, but this means that there is something wrong in the key pair you are using, which could hint on further failures.
Have you checked you don’t have any memory leak or buffer overflow?
Have you managed to look at logs from server side?
Unfortunately I can’t use full logs because of lack of flash space.
You could try a lower debug level, to print only the errors.
If the error is in the server key exchange algorithm, I would also check the entropy source, since the message includes signature and randomness.
If the signature algorithm is ecdsa_secp521r1_sha512, it probably means the the server private key is for thesecp521r1 curve, and this could probably explain the issue.
In addition, if your server key is for the 521r1 curve, then it is strange why the certificate is not for signed with a key of this curve.
Please try defining MBEDTLS_ECP_DP_SECP521R1_ENABLED as it probab ly causes the issue, however, there might be some mixup in the settings as well.
