Hi everyone,
I recently switch to version 3.0.0 and now I got a problem when I try to access to my HTTP server.
The problem appears with RSA certificates (2048 or 4096). In that case, the firmware fails into mbedtls_exit after verifying the header of a buffer during buffer_alloc_free.
After verification it seems that something creates an overflow of one byte in the buffer and override the first byte of MAGIC1 value in the buffer’s header.
I found a fix by modifying the rsa_prepare_blinding function, but I am not very confident in my correction. I simply remove some -1 operations and in that case the buffer is correctly filled by mbedtls_mpi_fill_random without overflow.
Here the code:
* Generate or update blinding values, see section 10 of:
* KOCHER, Paul C. Timing attacks on implementations of Diffie-Hellman, RSA,
* DSS, and other systems. In : Advances in Cryptology-CRYPTO'96. Springer
* Berlin Heidelberg, 1996. p. 104-113.
static int rsa_prepare_blinding( mbedtls_rsa_context *ctx,
int (*f_rng)(void *, unsigned char *, size_t), void *p_rng )
int ret, count = 0;
mbedtls_mpi R;
mbedtls_mpi_init( &R );
if( ctx->Vf.p != NULL )
/* We already have blinding values, just update them by squaring */
MBEDTLS_MPI_CHK( mbedtls_mpi_mul_mpi( &ctx->Vi, &ctx->Vi, &ctx->Vi ) );
MBEDTLS_MPI_CHK( mbedtls_mpi_mod_mpi( &ctx->Vi, &ctx->Vi, &ctx->N ) );
MBEDTLS_MPI_CHK( mbedtls_mpi_mul_mpi( &ctx->Vf, &ctx->Vf, &ctx->Vf ) );
MBEDTLS_MPI_CHK( mbedtls_mpi_mod_mpi( &ctx->Vf, &ctx->Vf, &ctx->N ) );
goto cleanup;
/* Unblinding value: Vf = random number, invertible mod N */
do {
if( count++ > 10 )
ret = MBEDTLS_ERR_RSA_RNG_FAILED;
goto cleanup;
MBEDTLS_MPI_CHK( mbedtls_mpi_fill_random( &ctx->Vf, ctx->len, f_rng, p_rng ) );
/* Compute Vf^-1 as R * (R Vf)^-1 to avoid leaks from inv_mod. */
MBEDTLS_MPI_CHK( mbedtls_mpi_fill_random( &R, ctx->len, f_rng, p_rng ) );
MBEDTLS_MPI_CHK( mbedtls_mpi_mul_mpi( &ctx->Vi, &ctx->Vf, &R ) );
/* At this point, Vi is invertible mod N if and only if both Vf and R
* are invertible mod N. If one of them isn't, we don't need to know
* which one, we just loop and choose new values for both of them.
* (Each iteration succeeds with overwhelming probability.) */
ret = mbedtls_mpi_inv_mod( &ctx->Vi, &ctx->Vi, &ctx->N );
if( ret != 0 && ret != MBEDTLS_ERR_MPI_NOT_ACCEPTABLE )
goto cleanup;
} while( ret == MBEDTLS_ERR_MPI_NOT_ACCEPTABLE );
/* Finish the computation of Vf^-1 = R * (R Vf)^-1 */
MBEDTLS_MPI_CHK( mbedtls_mpi_mul_mpi( &ctx->Vi, &ctx->Vi, &R ) );
/* Blinding value: Vi = Vf^(-e) mod N
* (Vi already contains Vf^-1 at this point) */
MBEDTLS_MPI_CHK( mbedtls_mpi_exp_mod( &ctx->Vi, &ctx->Vi, &ctx->E, &ctx->N, &ctx->RN ) );
cleanup:
mbedtls_mpi_free( &R );
return( ret );
Could you please tell my if I made any mistake ?
Thanks in advance !
Thomas
