Hi
We have a code called Freertos_TLS_Disconnect() which calls mbedtls_ssl_close_notify() internally.
The function takes 45 seconds with an error code -27648 when there is no delay added before the code as shown below
APP_PRINT("before TLS_FreeRTOS_Disconnect\r\n");
//R_BSP_SoftwareDelay(1000, BSP_DELAY_UNITS_MILLISECONDS);
gpt_init_data_process(0,1);
TLS_FreeRTOS_Disconnect (&xNetworkContext);
gpt_init_data_process(1,1);
APP_PRINT(" after TLS_FreeRTOS_Disconnect\r\n");
isSocketConnected = FALSE;
But when the delay is added (to the above code) the mbedtls_ssl_close_notify succeeds and the time taken for the function to execiute is a mere 15 ms.
The question is, does the mbedtls_ssl_close_notify function require a delay before gracefully closing the connection? if not what is the fix?
Implementation of TLS_Freertos_disconnect function is as below
void TLS_FreeRTOS_Disconnect( NetworkContext_t * pNetworkContext )
TlsTransportParams_t * pTlsTransportParams = NULL;
BaseType_t tlsStatus = 0;
if( ( pNetworkContext != NULL ) && ( pNetworkContext->pParams != NULL ) )
pTlsTransportParams = pNetworkContext->pParams;
/* Attempting to terminate TLS connection. */
tlsStatus = ( BaseType_t ) mbedtls_ssl_close_notify( &( pTlsTransportParams->sslContext.context ) );
/* Ignore the WANT_READ and WANT_WRITE return values. */
if( ( tlsStatus != ( BaseType_t ) MBEDTLS_ERR_SSL_WANT_READ ) &&
( tlsStatus != ( BaseType_t ) MBEDTLS_ERR_SSL_WANT_WRITE ) )
if( tlsStatus == 0 )
LogInfo( ( "(Network connection %p) TLS close-notify sent.",
pNetworkContext ) );
else
LogError( ( "(Network connection %p) Failed to send TLS close-notify: mbedTLSError= %s : %s.",
pNetworkContext,
mbedtlsHighLevelCodeOrDefault( tlsStatus ),
mbedtlsLowLevelCodeOrDefault( tlsStatus ) ) );
/* Call socket shutdown function to close connection. */
TCP_Sockets_Disconnect( pTlsTransportParams->tcpSocket );
/* Free mbed TLS contexts. */
sslContextFree( &( pTlsTransportParams->sslContext ) );
