I made an edge-triggered epoll HTTPS server, but I have some problems with it.
The very first call to mbedtls_ssl_read() returns MBEDTLS_ERR_NET_INVALID_CONTEXT. But I can’t see where the problem could originate from. I have correctly initialized the context and even made a TLS handshake with it.
Here are the important parts of the code:
Note that I understand this code will fail in a lot of cases. I just made an example to reproduce the error. This code just describes everything that goes on when I accept I single client and then, after receiving EPOLLIN, try to read data from it.
#define REQUEST_SIZE 8192
struct HTTP_server
mbedtls_net_context https_context;
mbedtls_ssl_config conf;
mbedtls_x509_crt srvcert;
mbedtls_pk_context pkey;
const char *pers;
typedef struct client_data
char *request;
proto_t protocol;
union
int client_fd;
mbedtls_ssl_context ssl;
} client_data_t;
struct HTTP_server server;
server->pers = "ssl_server";
mbedtls_net_init(&server->https_context);
mbedtls_ssl_config_init(&server->conf);
mbedtls_x509_crt_init(&server->srvcert);
mbedtls_pk_init(&server->pkey);
mbedtls_entropy_init(&server->entropy);
mbedtls_ctr_drbg_init(&server->ctr_drbg);
if (mbedtls_ctr_drbg_seed(&server->ctr_drbg, mbedtls_entropy_func, &server->entropy,
(const unsigned char *) server->pers, strlen(server->pers)) != 0) {
return 0;
if (mbedtls_x509_crt_parse_file(&server->srvcert, "server.crt") != 0)
return 0;
if (mbedtls_pk_parse_keyfile(&server->pkey, "server.key", "pass_phrase", mbedtls_ctr_drbg_random, &server->ctr_drbg) != 0)
return 0;
if (mbedtls_net_bind(&server->https_context, NULL, "8000", MBEDTLS_NET_PROTO_TCP) != 0)
return 0;
mbedtls_net_set_nonblock(&server->https_context);
if (mbedtls_ssl_config_defaults(&server->conf, MBEDTLS_SSL_IS_SERVER, MBEDTLS_SSL_TRANSPORT_STREAM,
MBEDTLS_SSL_PRESET_DEFAULT) != 0)
return 0;
mbedtls_ssl_conf_rng(&server->conf, mbedtls_ctr_drbg_random, &server->ctr_drbg);
if (mbedtls_ssl_conf_own_cert(&server->conf, &server->srvcert, &server->pkey) != 0)
return 0;
int epoll_fd = epoll_create1(0);
if (epoll_fd == -1)
return;
event.data.fd = server->https_context.fd;
event.events = EPOLLIN;
if (epoll_ctl(epoll_fd, EPOLL_CTL_ADD, server->https_context.fd, &event) == -1)
goto epoll_close;
while (1)
int nevents = epoll_wait(epoll_fd, events, 128, -1);
if (nevents == -1)
goto epoll_close;
else if (errno == EINTR)
goto epoll_close;
for (int i = 0; i < nevents; ++i)
if ((events[i].events & (EPOLLERR | EPOLLHUP)))
continue;
else if (events[i].data.fd == server->https_context.fd)
client_data_t client_status = malloc(sizeof(client_data_t));
mbedtls_net_context client_socket;
mbedtls_net_accept(&server->https_context, &client_socket, NULL, 0, NULL);
client_status->https_context = client_socket;
mbedtls_ssl_init(&client_status->ssl);
if (mbedtls_ssl_setup(&client_status->ssl, &server->conf) != 0)
return 0;
mbedtls_ssl_set_bio(&client_status->ssl, &client_socket, mbedtls_net_send, mbedtls_net_recv, NULL);
int ret;
while (!program_interrupted && ((ret = mbedtls_ssl_handshake(&client_status->ssl)) != 0))
if (ret != MBEDTLS_ERR_SSL_WANT_READ && ret != MBEDTLS_ERR_SSL_WANT_WRITE)
mbedtls_printf(" failed\n ! mbedtls_ssl_handshake returned %d\n\n", ret);
return 0;
client_status->request = malloc(REQUEST_SIZE + 1);
event.data.fd = client_socket.fd;
event.data.ptr = client_status;
event.events = EPOLLIN | EPOLLET;
if (epoll_ctl(epoll_fd, EPOLL_CTL_ADD, client_socket.fd, &event) == -1)
continue;
else
client_data_t *client_status = events[i].data.ptr;
// Every function call until this was successful, I checked, here nbytes == -69 or nbytes == -76
// just for simplicity I put the call directly here
// but in my actual code I call a read function described at the end
ssize_t nbytes = mbedtls_ssl_read(&client_status->ssl, (unsigned char *)(client_status->request), REQUEST_SIZE);
// other stuff
epoll_close:
close(epoll_fd);
The mbedtls debug error messages look like this:
ssl_msg.c:5662: => read
ssl_msg.c:4110: => read record
ssl_msg.c:2155: => fetch input
ssl_msg.c:2295: in_left: 0, nb_want: 5
ssl_msg.c:2315: in_left: 0, nb_want: 5
ssl_msg.c:2318: ssl->f_recv(_timeout)() returned -69 (-0x0045)
ssl_msg.c:4782: mbedtls_ssl_fetch_input() returned -69 (-0x0045)
ssl_msg.c:4141: ssl_get_next_record() returned -69 (-0x0045)
ssl_msg.c:5722: mbedtls_ssl_read_record() returned -69 (-0x0045)
This is how I actually read the message:
while (1)
nbytes = mbedtls_ssl_read(&client_status->ssl, (unsigned char *)(request + client_status->request_bytes_read), server_properties->max_request - client_status->request_bytes_read);
if (nbytes < 0)
if (errno == EAGAIN || errno == EWOULDBLOCK || nbytes == MBEDTLS_ERR_SSL_WANT_READ)
// no application data to read, wait for another epoll_wait() notification
break;
else
// print error
break;
// I also tried to replace the code above with this, but mbedtls_ssl_read() returns -69, which doesn't compare equal to MBEDTLS_ERR_SSL_WANT_READ and so there must be some sort of error
// In case there is control data pending, but no application data, so that epoll_wait() wouldn't hang
/* if (nbytes == MBEDTLS_ERR_SSL_WANT_READ)
continue;
else if (errno == EAGAIN || errno == EWOULDBLOCK)
*blocked = 1;
break;
else
ERROR_LOG("read() failed");
break;
else if (nbytes == 0)
break;
else
client_status->request_bytes_read += nbytes;
client_status->request[client_status->request_bytes_read] = '\0';
char *CRLF = strstr(client_status->request + client_status->request_bytes_read - nbytes, "\r\n\r\n");
if (CRLF)
// parse the headers, get Content-Length and move to reading body
// body is read in a similar manner
break;
