Hi guys,
I’m using Mongoose 7.3 from Cesanta with builtin mbed TLS 3.0.0 for my API server. Client is written using C# and using Webclient with https protocol. Generated pair of key+ cert and succesfully implemented them in api server, communication is going well, but after data transfered I have so many retries every 1 second, you can see them on the below. Mongoose returns err = 11, it means EAGAIN (Try again) in linux system. Errors are displayed during 100 seconds. Hint: ServicePointManager.MaxServicePointIdleTime in client is also seto to 100 seconds.
Best regards, Pls help.
It look like this:
mbedtls/ssl_msg.c:5206 |2| => read
mbedtls/ssl_msg.c:3701 |2| => read record
mbedtls/ssl_msg.c:1750 |2| => fetch input
mbedtls/ssl_msg.c:1907 |2| in_left: 0, nb_want: 5
mbedtls/ssl_msg.c:1932 |2| in_left: 0, nb_want: 5
2021-07-21 02:11:42 mongoose.c:2834:read_conn 8 00100100000010 0 0/512 err 11
Full log:
2021-07-21 02:11:37 Net: EVENT MG_EV_ACCEPT
2021-07-21 02:11:37 mongoose.c:3515:mg_tls_in 8 Setting TLS, CA: -, cert: pms.crt, key: pms.key
mbedtls/ssl_tls.c:5060 |2| => handshake
mbedtls/ssl_srv.c:4263 |2| server state: 0
mbedtls/ssl_msg.c:1966 |2| => flush output
mbedtls/ssl_msg.c:1978 |2| <= flush output
mbedtls/ssl_srv.c:4263 |2| server state: 1
mbedtls/ssl_srv.c:1145 |2| => parse client hello
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
mbedtls/ssl_msg.c:1953 |2| <= fetch input
mbedtls/ssl_msg.c:1907 |2| in_left: 5, nb_want: 153
mbedtls/ssl_msg.c:1932 |2| in_left: 5, nb_want: 153
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 148 (-0xffffff6c)
mbedtls/ssl_srv.c:1899 |2| selected ciphersuite: TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
mbedtls/ssl_srv.c:1933 |2| <= parse client hello
mbedtls/ssl_srv.c:4263 |2| server state: 2
mbedtls/ssl_srv.c:2458 |2| => write server hello
mbedtls/ssl_msg.c:2392 |2| => write handshake message
mbedtls/ssl_msg.c:2544 |2| => write record
mbedtls/ssl_msg.c:1986 |2| message length: 96, out_left: 96
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 96 (-0xffffffa0)
mbedtls/ssl_msg.c:2019 |2| <= flush output
mbedtls/ssl_msg.c:2685 |2| <= write record
mbedtls/ssl_msg.c:2521 |2| <= write handshake message
mbedtls/ssl_srv.c:2661 |2| <= write server hello
mbedtls/ssl_srv.c:4263 |2| server state: 3
mbedtls/ssl_tls.c:1702 |2| => write certificate
mbedtls/ssl_msg.c:1986 |2| message length: 584, out_left: 584
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 584 (-0xfffffdb8)
mbedtls/ssl_tls.c:1783 |2| <= write certificate
mbedtls/ssl_srv.c:4263 |2| server state: 4
mbedtls/ssl_srv.c:3262 |2| => write server key exchange
mbedtls/ssl_srv.c:3068 |2| ECDHE curve: x25519
mbedtls/ssl_msg.c:1986 |2| message length: 177, out_left: 177
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 177 (-0xffffff4f)
mbedtls/ssl_srv.c:3346 |2| <= write server key exchange
mbedtls/ssl_srv.c:4263 |2| server state: 5
mbedtls/ssl_srv.c:2697 |2| => write certificate request
mbedtls/ssl_srv.c:2711 |2| <= skip write certificate request
mbedtls/ssl_srv.c:4263 |2| server state: 6
mbedtls/ssl_srv.c:3354 |2| => write server hello done
mbedtls/ssl_msg.c:1986 |2| message length: 9, out_left: 9
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 9 (-0xfffffff7)
mbedtls/ssl_srv.c:3382 |2| <= write server hello done
mbedtls/ssl_srv.c:4263 |2| server state: 7
mbedtls/ssl_tls.c:2305 |2| => parse certificate
mbedtls/ssl_tls.c:2310 |2| <= skip parse certificate
mbedtls/ssl_srv.c:4263 |2| server state: 8
mbedtls/ssl_srv.c:3702 |2| => parse client key exchange
mbedtls/ssl_msg.c:1907 |2| in_left: 5, nb_want: 42
mbedtls/ssl_msg.c:1932 |2| in_left: 5, nb_want: 42
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 37 (-0xffffffdb)
mbedtls/ssl_msg.c:3775 |2| <= read record
mbedtls/ssl_tls.c:1306 |2| => derive keys
mbedtls/ssl_tls.c:1451 |2| => calc verify sha384
mbedtls/ssl_tls.c:1459 |2| <= calc verify
mbedtls/ssl_tls.c:1363 |2| <= derive keys
mbedtls/ssl_srv.c:3994 |2| <= parse client key exchange
mbedtls/ssl_srv.c:4263 |2| server state: 9
mbedtls/ssl_srv.c:4033 |2| => parse certificate verify
mbedtls/ssl_srv.c:4045 |2| <= skip parse certificate verify
mbedtls/ssl_srv.c:4263 |2| server state: 10
mbedtls/ssl_msg.c:4749 |2| => parse change cipher spec
mbedtls/ssl_msg.c:1907 |2| in_left: 5, nb_want: 6
mbedtls/ssl_msg.c:1932 |2| in_left: 5, nb_want: 6
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 1 (-0xffffffff)
mbedtls/ssl_msg.c:4800 |2| <= parse change cipher spec
mbedtls/ssl_srv.c:4263 |2| server state: 11
mbedtls/ssl_tls.c:2892 |2| => parse finished
mbedtls/ssl_tls.c:2656 |2| => calc finished tls sha384
mbedtls/ssl_tls.c:2682 |2| <= calc finished
mbedtls/ssl_msg.c:1907 |2| in_left: 5, nb_want: 45
mbedtls/ssl_msg.c:1932 |2| in_left: 5, nb_want: 45
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 40 (-0xffffffd8)
mbedtls/ssl_msg.c:1212 |2| => decrypt buf
mbedtls/ssl_msg.c:1716 |2| <= decrypt buf
mbedtls/ssl_tls.c:2960 |2| <= parse finished
mbedtls/ssl_srv.c:4263 |2| server state: 12
mbedtls/ssl_msg.c:4726 |2| => write change cipher spec
mbedtls/ssl_msg.c:1986 |2| message length: 6, out_left: 6
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 6 (-0xfffffffa)
mbedtls/ssl_msg.c:4740 |2| <= write change cipher spec
mbedtls/ssl_srv.c:4263 |2| server state: 13
mbedtls/ssl_tls.c:2781 |2| => write finished
mbedtls/ssl_msg.c:529 |2| => encrypt buf
mbedtls/ssl_msg.c:951 |2| <= encrypt buf
mbedtls/ssl_msg.c:1986 |2| message length: 45, out_left: 45
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 45 (-0xffffffd3)
mbedtls/ssl_tls.c:2879 |2| <= write finished
mbedtls/ssl_srv.c:4263 |2| server state: 14
mbedtls/ssl_srv.c:4368 |2| handshake: done
mbedtls/ssl_srv.c:4263 |2| server state: 15
mbedtls/ssl_tls.c:5071 |2| <= handshake
2021-07-21 02:11:38 mongoose.c:3465:mg_tls_ha 8 success
mbedtls/ssl_msg.c:1907 |2| in_left: 5, nb_want: 160
mbedtls/ssl_msg.c:1932 |2| in_left: 5, nb_want: 160
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 155 (-0xffffff65)
mbedtls/ssl_msg.c:5400 |2| <= read
2021-07-21 02:11:38 Net: EVENT MG_EV_HTTP_MSG
2021-07-21 02:11:38 Sql: Opened database successfully
2021-07-21 02:11:39 Authentication: USER LOGGED!
2021-07-21 02:11:39 mongoose.c:2974:mg_connec 1 -> udp://192.168.1.10:514
2021-07-21 02:11:39 mongoose.c:2890:close_con 1 closed
2021-07-21 02:11:39 I mongoose.c:2249:mg_mgr_fr All connections closed
2021-07-21 02:11:39 mongoose.c:2834:read_conn 8 00100100000011 0 0/512 err 11
mbedtls/ssl_msg.c:5487 |2| => write
mbedtls/ssl_msg.c:1986 |2| message length: 171, out_left: 171
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 171 (-0xffffff55)
mbedtls/ssl_msg.c:5511 |2| <= write
mbedtls/ssl_msg.c:1907 |2| in_left: 5, nb_want: 124
mbedtls/ssl_msg.c:1932 |2| in_left: 5, nb_want: 124
mbedtls/ssl_msg.c:1933 |2| ssl->f_recv(_timeout)() returned 119 (-0xffffff89)
2021-07-21 02:11:39 Net: EVENT MG_EV_HTTP_MSG
2021-07-21 02:11:39 Sql: Opened database successfully
mbedtls/ssl_msg.c:1986 |2| message length: 421, out_left: 421
mbedtls/ssl_msg.c:1991 |2| ssl->f_send() returned 421 (-0xfffffe5b)
2021-07-21 02:11:40 mongoose.c:2834:read_conn 8 00100100000010 0 0/512 err 11
2021-07-21 02:11:41 mongoose.c:2834:read_conn 8 00100100000010 0 0/512 err 11
2021-07-21 02:11:43 mongoose.c:2834:read_conn 8 00100100000010 0 0/512 err 11
