Hello, i have been trying to create a TCP server and client in a programming language called Julia, it uses the mbedTLS compiled library so i am hoping you may be able to point me in the right direction of what is going wrong.
What may be going wrong here? It is returning an error of MbedTLS error code -31104: SSL - Processing of the ServerHello handshake message failed
The debug messages can be seen below
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_tls.c", 5793, "0x55ff1392dff0: => handshake\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 4416, "0x55ff1392dff0: client state: 0\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2215, "0x55ff1392dff0: => flush output\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2227, "0x55ff1392dff0: <= flush output\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 4416, "0x55ff1392dff0: client state: 1\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 992, "0x55ff1392dff0: => write client hello\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1047, "0x55ff1392dff0: client hello, max version: [3:3]\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 908, "0x55ff1392dff0: client hello, current time: 1620714683\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1057, "0x55ff1392dff0: dumping 'client hello, random bytes' (32 bytes)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1057, "0x55ff1392dff0: 0000: 60 9a 24 bb b3 3d 64 ce a2 4d 0c e4 bf 7d 77 d9 `.\$..=d..M...}w.\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1057, "0x55ff1392dff0: 0010: dd 12 13 be 7e 7c fa 97 af 78 ec 21 c2 19 13 b1 ....~|...x.!....\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1117, "0x55ff1392dff0: client hello, session id len.: 0\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1118, "0x55ff1392dff0: dumping 'client hello, session id' (0 bytes)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xcca8 (TLS-ECDHE-RSA-WITH-CHACHA20-POLY1305-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xcca9 (TLS-ECDHE-ECDSA-WITH-CHACHA20-POLY1305-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xccaa (TLS-DHE-RSA-WITH-CHACHA20-POLY1305-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc02c (TLS-ECDHE-ECDSA-WITH-AES-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc030 (TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x9f (TLS-DHE-RSA-WITH-AES-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0ad (TLS-ECDHE-ECDSA-WITH-AES-256-CCM)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc09f (TLS-DHE-RSA-WITH-AES-256-CCM)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc024 (TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc028 (TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x6b (TLS-DHE-RSA-WITH-AES-256-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc00a (TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc014 (TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x39 (TLS-DHE-RSA-WITH-AES-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0af (TLS-ECDHE-ECDSA-WITH-AES-256-CCM-8)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0a3 (TLS-DHE-RSA-WITH-AES-256-CCM-8)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc087 (TLS-ECDHE-ECDSA-WITH-CAMELLIA-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc08b (TLS-ECDHE-RSA-WITH-CAMELLIA-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc07d (TLS-DHE-RSA-WITH-CAMELLIA-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc073 (TLS-ECDHE-ECDSA-WITH-CAMELLIA-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc077 (TLS-ECDHE-RSA-WITH-CAMELLIA-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc4 (TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x88 (TLS-DHE-RSA-WITH-CAMELLIA-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc02b (TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc02f (TLS-ECDHE-RSA-WITH-AES-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x9e (TLS-DHE-RSA-WITH-AES-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0ac (TLS-ECDHE-ECDSA-WITH-AES-128-CCM)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc09e (TLS-DHE-RSA-WITH-AES-128-CCM)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc023 (TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc027 (TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x67 (TLS-DHE-RSA-WITH-AES-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc009 (TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc013 (TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x33 (TLS-DHE-RSA-WITH-AES-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0ae (TLS-ECDHE-ECDSA-WITH-AES-128-CCM-8)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0a2 (TLS-DHE-RSA-WITH-AES-128-CCM-8)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc086 (TLS-ECDHE-ECDSA-WITH-CAMELLIA-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc08a (TLS-ECDHE-RSA-WITH-CAMELLIA-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc07c (TLS-DHE-RSA-WITH-CAMELLIA-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc072 (TLS-ECDHE-ECDSA-WITH-CAMELLIA-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc076 (TLS-ECDHE-RSA-WITH-CAMELLIA-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xbe (TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x45 (TLS-DHE-RSA-WITH-CAMELLIA-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x9d (TLS-RSA-WITH-AES-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc09d (TLS-RSA-WITH-AES-256-CCM)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x3d (TLS-RSA-WITH-AES-256-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x35 (TLS-RSA-WITH-AES-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc032 (TLS-ECDH-RSA-WITH-AES-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc02a (TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc00f (TLS-ECDH-RSA-WITH-AES-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc02e (TLS-ECDH-ECDSA-WITH-AES-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc026 (TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc005 (TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0a1 (TLS-RSA-WITH-AES-256-CCM-8)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc07b (TLS-RSA-WITH-CAMELLIA-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0 (TLS-RSA-WITH-CAMELLIA-256-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x84 (TLS-RSA-WITH-CAMELLIA-256-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc08d (TLS-ECDH-RSA-WITH-CAMELLIA-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc079 (TLS-ECDH-RSA-WITH-CAMELLIA-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc089 (TLS-ECDH-ECDSA-WITH-CAMELLIA-256-GCM-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc075 (TLS-ECDH-ECDSA-WITH-CAMELLIA-256-CBC-SHA384)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x9c (TLS-RSA-WITH-AES-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc09c (TLS-RSA-WITH-AES-128-CCM)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x3c (TLS-RSA-WITH-AES-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x2f (TLS-RSA-WITH-AES-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc031 (TLS-ECDH-RSA-WITH-AES-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc029 (TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc00e (TLS-ECDH-RSA-WITH-AES-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc02d (TLS-ECDH-ECDSA-WITH-AES-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc025 (TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc004 (TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc0a0 (TLS-RSA-WITH-AES-128-CCM-8)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc07a (TLS-RSA-WITH-CAMELLIA-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xba (TLS-RSA-WITH-CAMELLIA-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0x41 (TLS-RSA-WITH-CAMELLIA-128-CBC-SHA)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc08c (TLS-ECDH-RSA-WITH-CAMELLIA-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc078 (TLS-ECDH-RSA-WITH-CAMELLIA-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc088 (TLS-ECDH-ECDSA-WITH-CAMELLIA-128-GCM-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1184, "0x55ff1392dff0: client hello, add ciphersuite: 0xc074 (TLS-ECDH-ECDSA-WITH-CAMELLIA-128-CBC-SHA256)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1199, "0x55ff1392dff0: client hello, got 79 ciphersuites (excluding SCSVs)\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1209, "0x55ff1392dff0: adding EMPTY_RENEGOTIATION_INFO_SCSV\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1263, "0x55ff1392dff0: client hello, compress len.: 1\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1264, "0x55ff1392dff0: client hello, compress alg.: 0\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 224, "0x55ff1392dff0: client hello, adding signature_algorithms extension\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 317, "0x55ff1392dff0: client hello, adding supported_elliptic_curves extension\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 387, "0x55ff1392dff0: client hello, adding supported_point_formats extension\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 606, "0x55ff1392dff0: client hello, adding encrypt_then_mac extension\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 637, "0x55ff1392dff0: client hello, adding extended_master_secret extension\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 670, "0x55ff1392dff0: client hello, adding session ticket extension\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1423, "0x55ff1392dff0: client hello, total extension length: 76\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2651, "0x55ff1392dff0: => write handshake message\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2810, "0x55ff1392dff0: => write record\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2925, "0x55ff1392dff0: output record: msgtype = 22, version = [3:1], msglen = 281\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: dumping 'output record sent to network' (286 bytes)\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0000: 16 03 01 01 19 01 00 01 15 03 03 60 9a 24 bb b3 ...........`.\$..\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0010: 3d 64 ce a2 4d 0c e4 bf 7d 77 d9 dd 12 13 be 7e =d..M...}w.....~\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0020: 7c fa 97 af 78 ec 21 c2 19 13 b1 00 00 a0 cc a8 |...x.!.........\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0030: cc a9 cc aa c0 2c c0 30 00 9f c0 ad c0 9f c0 24 .....,.0.......\$\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0040: c0 28 00 6b c0 0a c0 14 00 39 c0 af c0 a3 c0 87 .(.k.....9......\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0050: c0 8b c0 7d c0 73 c0 77 00 c4 00 88 c0 2b c0 2f ...}.s.w.....+./\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0060: 00 9e c0 ac c0 9e c0 23 c0 27 00 67 c0 09 c0 13 .......#.'.g....\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0070: 00 33 c0 ae c0 a2 c0 86 c0 8a c0 7c c0 72 c0 76 .3.........|.r.v\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0080: 00 be 00 45 00 9d c0 9d 00 3d 00 35 c0 32 c0 2a ...E.....=.5.2.*\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0090: c0 0f c0 2e c0 26 c0 05 c0 a1 c0 7b 00 c0 00 84 .....&.....{....\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 00a0: c0 8d c0 79 c0 89 c0 75 00 9c c0 9c 00 3c 00 2f ...y...u.....<./\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 00b0: c0 31 c0 29 c0 0e c0 2d c0 25 c0 04 c0 a0 c0 7a .1.)...-.%.....z\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 00c0: 00 ba 00 41 c0 8c c0 78 c0 88 c0 74 00 ff 01 00 ...A...x...t....\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 00d0: 00 4c 00 0d 00 16 00 14 06 03 06 01 05 03 05 01 .L..............\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 00e0: 04 03 04 01 03 03 03 01 02 03 02 01 00 0a 00 1c ................\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 00f0: 00 1a 00 19 00 1c 00 18 00 1b 00 17 00 16 00 1a ................\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0100: 00 15 00 14 00 13 00 12 00 1d 00 1e 00 0b 00 02 ................\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0110: 01 00 00 16 00 00 00 17 00 00 00 23 00 00 ...........#..\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2233, "0x55ff1392dff0: message length: 286, out_left: 286\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2239, "0x55ff1392dff0: ssl->f_send() returned 286 (-0xfffffee2)\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2267, "0x55ff1392dff0: <= flush output\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2981, "0x55ff1392dff0: <= write record\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2787, "0x55ff1392dff0: <= write handshake message\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 1461, "0x55ff1392dff0: <= write client hello\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 4416, "0x55ff1392dff0: client state: 2\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 2063, "0x55ff1392dff0: => parse server hello\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 4013, "0x55ff1392dff0: => read record\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2003, "0x55ff1392dff0: => fetch input\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2156, "0x55ff1392dff0: in_left: 0, nb_want: 5\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2180, "0x55ff1392dff0: in_left: 0, nb_want: 5\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_tls.c", 5804, "0x55ff1392dff0: <= handshake\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2182, "0x55ff1392dff0: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2202, "0x55ff1392dff0: <= fetch input\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3747, "0x55ff1392dff0: dumping 'input record header' (5 bytes)\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3747, "0x55ff1392dff0: 0000: 16 03 01 01 19 .....\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3749, "0x55ff1392dff0: input record: msgtype = 22, version = [3:1], msglen = 281\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2156, "0x55ff1392dff0: in_left: 5, nb_want: 286\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2180, "0x55ff1392dff0: in_left: 5, nb_want: 286\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2182, "0x55ff1392dff0: ssl->f_recv(_timeout)() returned 281 (-0xfffffee7)\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: dumping 'input record from network' (286 bytes)\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0000: 16 03 01 01 19 01 00 01 15 03 03 60 9a 24 bb 1a ...........`.\$..\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0010: 0d 86 ec 5f ce 93 90 a8 bc 2c fd f8 07 bd be 4f ..._.....,.....O\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0020: fa 52 c8 b0 ea d2 09 87 c8 53 1e 00 00 a0 cc a8 .R.......S......\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0030: cc a9 cc aa c0 2c c0 30 00 9f c0 ad c0 9f c0 24 .....,.0.......\$\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0040: c0 28 00 6b c0 0a c0 14 00 39 c0 af c0 a3 c0 87 .(.k.....9......\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0050: c0 8b c0 7d c0 73 c0 77 00 c4 00 88 c0 2b c0 2f ...}.s.w.....+./\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0060: 00 9e c0 ac c0 9e c0 23 c0 27 00 67 c0 09 c0 13 .......#.'.g....\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0070: 00 33 c0 ae c0 a2 c0 86 c0 8a c0 7c c0 72 c0 76 .3.........|.r.v\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0080: 00 be 00 45 00 9d c0 9d 00 3d 00 35 c0 32 c0 2a ...E.....=.5.2.*\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0090: c0 0f c0 2e c0 26 c0 05 c0 a1 c0 7b 00 c0 00 84 .....&.....{....\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 00a0: c0 8d c0 79 c0 89 c0 75 00 9c c0 9c 00 3c 00 2f ...y...u.....<./\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 00b0: c0 31 c0 29 c0 0e c0 2d c0 25 c0 04 c0 a0 c0 7a .1.)...-.%.....z\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 00c0: 00 ba 00 41 c0 8c c0 78 c0 88 c0 74 00 ff 01 00 ...A...x...t....\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 00d0: 00 4c 00 0d 00 16 00 14 06 03 06 01 05 03 05 01 .L..............\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 00e0: 04 03 04 01 03 03 03 01 02 03 02 01 00 0a 00 1c ................\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 00f0: 00 1a 00 19 00 1c 00 18 00 1b 00 17 00 16 00 1a ................\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0100: 00 15 00 14 00 13 00 12 00 1d 00 1e 00 0b 00 02 ................\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3858, "0x55ff1392dff0: 0110: 01 00 00 16 00 00 00 17 00 00 00 23 00 00 ...........#..\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 3129, "0x55ff1392dff0: handshake message: msglen = 281, type = 1, hslen = 281\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 4087, "0x55ff1392dff0: <= read record\n")
(1, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_cli.c", 2127, "0x55ff1392dff0: bad server hello message\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 5037, "0x55ff1392dff0: => send alert message\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 5038, "0x55ff1392dff0: send alert level=2 message=50\n")
(3, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2925, "0x55ff1392dff0: output record: msgtype = 21, version = [3:1], msglen = 2\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: dumping 'output record sent to network' (7 bytes)\n")
(4, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2930, "0x55ff1392dff0: 0000: 15 03 01 00 02 02 32 ......2\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2233, "0x55ff1392dff0: message length: 7, out_left: 7\n")
(2, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2239, "0x55ff1392dff0: ssl->f_send() returned -80 (-0x0050)\n")
(1, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 2977, "0x55ff1392dff0: mbedtls_ssl_flush_output() returned -80 (-0x0050)\n")
(1, "/build/mbedtls/src/mbedtls-mbedtls-2.25.0/library/ssl_msg.c", 5047, "0x55ff1392dff0: mbedtls_ssl_write_record() returned -80 (-0x0050)\n")
