Initially I need to make one function run periodically with high precision without interuption.
I use the template for DISCO-F746NG named “Basic demo showing how to use touch screen”.
My user code is the following:
DigitalOut TESTO(PF_8);
Ticker TickReg;
void Regulate(void) {
TESTO = 1;
for(int i=0; i<1000; i++);
TESTO = 0;
void main(void)
TickReg.attach_us(&Regulate, 105);
Signal on PF_8 is looks like this:
(the upper signal in red)
As you can see this routine is interupted from time to time.
I think that the solution can be one of the folowing:
- Make the timer responsible for this Ticker higher priority. But as I know MBED library don’t have this functionality from the box. By the way: I can not figure out which hardware timer taking this particular Ticker.
- Configure any available timer (which I can pick basing on the STM32CubeMX configuration for this board) to run my ISR with needed period and with a high priority. I know that this code will not be portable anymore and I will need to go deep into the CPU datasheet…
Question:
- What I can really do in this case?
- Does MBED provide any solution?
- Is there any posibility to find out which TIM associated with the given Ticker?
- Any thought on the subject?
