Hi!
I want to develop a simple program which count pulses in a digital pin in an interval of 10ms. I want to use a timer as a counter to count the pulses, also I want to use another counter to read the amount of pulses that occurs in the pin and reset the first counter.
I’m using MBED STUDIO with the nrf52-dk and the SDK15.0 (which is the default in mbed studio). The counter works well, but the second one doesn’t. When I enable the interrupts, that I want use to read the value of the counter, the MCU freeze and never execute the interrupt.
Here is my code:
#include “nrf.h”
#include “nrfx_timer.h”
#include “mbed.h”
#include “app_error.h”
#include “nrfx_clock.h”
#include “nrfx_ppi.h”
#include “nrfx_gpiote.h”#define TIMEOUT_MS 10
#define INPUT_PIN P0_4DigitalOut led1(LED1);
DigitalOut led2(LED2, true);volatile uint32_t count0 = 0;
const nrfx_timer_t counter_timer = NRFX_TIMER_INSTANCE(3);
const nrfx_timer_t timeout_timer = NRFX_TIMER_INSTANCE(4);nrf_ppi_channel_t ppi_channel1;
nrf_ppi_channel_t ppi_channel2;void timer_handler_read(nrf_timer_event_t event_type, void * p_context)
count0 = nrfx_timer_capture_get(&counter_timer, NRF_TIMER_CC_CHANNEL0);
}void timer_counter_handler(nrf_timer_event_t event_type, void* p_context)
static void in_pin_handler(nrfx_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
void gpiote_init()
uint32_t err_code = NRF_SUCCESS;
if(!nrfx_gpiote_is_init())
err_code = nrfx_gpiote_init();
APP_ERROR_CHECK(err_code);
}nrfx_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_LOTOHI(true); in_config.pull = NRF_GPIO_PIN_PULLUP; err_code = nrfx_gpiote_in_init(INPUT_PIN, &in_config, in_pin_handler); APP_ERROR_CHECK(err_code); nrfx_gpiote_in_event_enable(INPUT_PIN, false);}
void timer_init()
//Configure the timer
nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_32;
timer_cfg.mode = NRF_TIMER_MODE_TIMER;
timer_cfg.frequency = NRF_TIMER_FREQ_16MHz;err_code = nrfx_timer_init(&timeout_timer, &timer_cfg, timer_handler_read); APP_ERROR_CHECK(err_code); printf("2 Error code: %d\n\r", err_code); uint32_t time_ticks = nrfx_timer_ms_to_ticks(&timeout_timer, TIMEOUT_MS); printf("Ticks: %d\n\r", time_ticks); nrfx_timer_extended_compare(&timeout_timer, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true); nrfx_timer_enable(&timeout_timer); //Configure TIMER for counting of low to high events on GPIO nrfx_timer_config_t counter_cfg = NRFX_TIMER_DEFAULT_CONFIG; counter_cfg.bit_width = NRF_TIMER_BIT_WIDTH_32; counter_cfg.mode = NRF_TIMER_MODE_COUNTER; err_code = nrfx_timer_init(&counter_timer, &counter_cfg, timer_counter_handler); APP_ERROR_CHECK(err_code); nrfx_timer_enable(&counter_timer); printf("1 Error code: %d\n\r", err_code);}
void ppi_init()
uint32_t err_code = NRF_SUCCESS;err_code = nrfx_ppi_channel_alloc(&ppi_channel1); APP_ERROR_CHECK(err_code); err_code = nrfx_ppi_channel_alloc(&ppi_channel2); APP_ERROR_CHECK(err_code); uint32_t gpiote_evt_addr_1 = nrfx_gpiote_in_event_addr_get(INPUT_PIN); uint32_t timer_count_count_task_addr = nrfx_timer_task_address_get(&counter_timer, NRF_TIMER_TASK_COUNT); uint32_t timer_count_capture_task_addr = nrfx_timer_task_address_get(&counter_timer, NRF_TIMER_TASK_CAPTURE0); uint32_t timer_count_clear_task_addr = nrfx_timer_task_address_get(&counter_timer, NRF_TIMER_TASK_CLEAR); uint32_t timer_timeout_compare_event_addr = nrfx_timer_event_address_get(&timeout_timer, NRF_TIMER_EVENT_COMPARE0); err_code = nrfx_ppi_channel_assign(ppi_channel1, gpiote_evt_addr_1, timer_count_count_task_addr); APP_ERROR_CHECK(err_code); err_code = nrfx_ppi_channel_assign(ppi_channel2, timer_timeout_compare_event_addr, timer_count_capture_task_addr); // Capture counter timer using PPI to make sure this is not delayed by BLE interrupt APP_ERROR_CHECK(err_code); err_code = nrfx_ppi_channel_fork_assign(ppi_channel2, timer_count_clear_task_addr); // Clear counter timer using PPI to make sure this is not delayed by BLE interrupt APP_ERROR_CHECK(err_code); err_code = nrfx_ppi_channel_enable(ppi_channel1); APP_ERROR_CHECK(err_code); err_code = nrfx_ppi_channel_enable(ppi_channel2); APP_ERROR_CHECK(err_code);}
int main(void)
if (!nrf_clock_hf_is_running(NRF_CLOCK_HFCLK_HIGH_ACCURACY))
nrfx_clock_hfclk_start();
}//Configure in pin gpiote_init(); //Configure the timmers timer_init(); //Configure the PPI ppi_init(); while (1) { led1 = !led1; ThisThread::sleep_for(200ms); printf("Counts 0: %d\n\r", count0); }}
Thanks
