Hi All
I’m coding on EByte_E73 module of nrf52840 core with mbed os, It’s work fine with MX25L12833FM2I external spi flash by SPIFBlockDevice class.
But I want to use this flash as secondary_bd for DFU function by mcuboot 。
I can make sure the bootloader is work, because it can load the first version with mcuboot bootloader. All other function is OK. But when I test DFU , I need use the external flash as secondary_bd to save update firmware. but SPIFBlockDevice can’t work fine now, the init function return -4002.
I searched on the Internet, and there was no useful information to help me. So I narrowed down my investigation. @Official Can you tell why the external flash init fail ? Anyone meet same situation ? thanks
This is my custom_targets.json:
"EBYTE_E73": {
"inherits": [
"MCU_NRF52840"
"detect_code": [
"1102"
"components_add": ["SPIF", "FLASHIAP", "SD"],
"features_remove": ["CRYPTOCELL310"],
"macros_remove": ["MBEDTLS_CONFIG_HW_SUPPORT"],
"config": {
"enable-objects-extensions": {
"help": "Enable inclusion of objects_extensions.h",
"value": false
"lf_clock_xtal_accuracy": {
"value": "NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM",
"macro_name": "MBED_CONF_NORDIC_LF_CLOCK_XTAL_ACCURACY"
"overrides": {
"lf_clock_src": "NRF_LF_SRC_RC",
"lf_clock_rc_calib_timer_interval": 16,
"lf_clock_rc_calib_mode_config": 0
"supported_application_profiles": [
"full", "bare-metal"
This is my mbed_app.json:
"target_overrides": {
"target.bootloader_img": null,
"target.printf_lib": "std",
"target.components_add": ["SD"]
"EBYTE_E73": {
"target.mbed_app_start": "0x21000",
"target.mbed_app_size": "0xBE000"
