Nucleo to nucleo serial Communication via TX and RX pins
Hi All,
I am using two Nucleo board (F746ZG and F746ZG) both are same to simulate a Serial communication. The HW Connection is as follows
MAIN-NUCLEO (STM32-F746ZG) and SUB-NUCLEO(STM32-F746ZG)
F746ZG pin-PC_12(TX) —>F746ZG pin-PG_9 (RX)
F746ZG pin-PD_2(RX) —>F746ZG pin-PG_14(TX)
I want to send a set of character(String) from main nucleo to sub nucleo and After sent the Full String some done Message will send from sub nucleo to main nucleo. pls see my Codes.
// main Nucleo
#include"string.h"
Serial pc(USBTX, USBRX);           // tx, rx
Serial receiver(PC_12,PD_2);       // NUCLEO-F746zg
char resStr[] = "ABCDEFGH#";
    pc.baud(115200);
    receiver.baud(115200);
    pc.printf("Starting...\r\n");           // Send to PC's serial terminal
    int ch;
    int i=0;
    while (1)
        pc.printf("\n Select The case :");
        scanf("%d",&ch);
        switch(ch)
                case 1:
                    printf("\n nucleo to nucleo Communication");
                    while(resStr[i] != '#' )
                            if(receiver.writeable())
                                    receiver.putc(resStr[i]);         //sending to Sub Nucleo F746ZG
                                    printf("\n send=%c",resStr[i]);
                                    wait_ms(100);
                            i++;
                    printf("\nsending done");
                break;
// Sub Nucleo
#include"string.h"
Serial receiver(PG_14,PG_9); // NUCLEO-F746ZG
char received[50] = "\0"; // buffer with a size with Null
char c='\0';
    pc.baud(115200);
    pc.printf("Ready\n\r");
    int i=0;
    while(1)
            //while(receiver.readable() < '\0')
           while(receiver.readable() )
                    c = receiver.getc(); // Receive from main NUCLEO-F746zg
                    received[i]=c;
                    printf("Received=%c",received[i]);
                    i++;
                    c='\0'; // make it c null for ready to receive the next Char
                    wait_ms(100);
            for(int j=0;j!=50;j++)
                    received[j] = '\0';   // make it Received String Null for Next Receive Data
                    wait_ms(100);
thank you for code formatting but not understand why new topic again…
  • pc.printf and printf have same efect would be good to use just one.
  • scanf is also on same uart
  • variable i has to be increase after sucesful send and not in the loop because the loop can be much faster than UART will be available again send something and that can cause zou will send nothing.
// main Nucleo
#include"string.h"
DigitalOut led(LED1);
    pc.baud(115200);
    int ch;
    int i=0;
    while (1)
        pc.printf("Select The case :\n");
        pc.scanf("%d",&ch);
        pc.printf("Perform command %d \n", ch);
        switch(ch)
            case 1:
                pc.printf("nucleo to nucleo Communication\n");
                        led = !led;
                        receiver.putc(resStr[i++]);         //sending to Sub Nucleo F746ZG
                        wait_ms(100);
                pc.printf("send=%s\n",resStr);
                pc.printf("sending done\n");
            break;
// Sub Nucleo
#include"string.h"
char c='\0';
bool msgComplete = false;
    pc.baud(115200);
    int i=0;
    while(1)
        while(receiver.readable())
            led = !led; //signal for something is readed
            received[i++]=c; // place char to buffer and increase counter
            if(c == '#') //check msg is complete
                received[i]='\0'; // this will help to mark end of string because buffer is much bigger than a single msg and is not necessary to clean whole buffer
                msgComplete = true; //flag msg is complete
        if(msgComplete)
            pc.printf("Received=%s\n",received);   // printf everithing until \0
            msgComplete  = false;  // clean flag
        wait_ms(10);
Please do not write “it is not working”, rather write console output from both sides and check Led indication.
working fine i add some delay before variable increment, thanks very much to johnnyk…
