Nucleo to nucleo serial Communication via TX and RX
Hi All,
I am using two Nucleo board (F746ZG and F746ZG) both are same to simulate a Serial communication. The HW Connection is as follows
MAIN-NUCLEO SUB-NUCLEO
F746ZG (TX) —>F746ZG (RX)
F746ZG (RX) —>F746ZG (TX)
I want to send a character from main nucleo to sub nucleo and After send some done from sub nucleo to main nucleo. but i cann’t do this automatically , could you have some ideas? pls see my Code snip below .
// main Nucleo
#include “mbed.h”
#include"string.h"
Serial pc(USBTX, USBRX); // tx, rx
Serial receiver(PG_14,PG_9); // NUCLEO-F746zg
char resStr = “#ABCDEFGH$”;
char received=“”;
pc.baud(115200);
receiver.baud(9600);
pc.printf(“Starting…\r\n”); // Send to PC’s serial terminal
int ch;
while (1) {
     pc.printf("\n Select The case :");
    scanf("%d",&ch);
     switch(ch)
        case 1:
            printf("nucleo to nucleo Communication");
            for (int i = 0; resStr[i] != '$'; i++)
            { //sending to Sub Nucleo F746ZG
            receiver.putc(resStr[i]);
            printf("\n send=%c",resStr[i]);
            wait_ms(10);
            printf("sending done");
           while (receiver.readable() !='#') //receive from Sub Nucleo F746zg
            printf("inside while loop ready for reading");
            int j=0;
            char c = receiver.getc();   // Receive from main NUCLEO-F746zg
            printf("\n received=%c",c);
            received[j]=c;
            j++;
            wait_ms(10);
       break;
// Sub Nucleo
#include “mbed.h”
#include"string.h"
Serial receiver(PG_14,PG_9); // NUCLEO-F746ZG
char resStr = “done#”;
char received=“”;
pc.baud(115200);
pc.printf(“Starting…\n\r”);
int k=0;
while (1)
while(receiver.readable() !=‘$’)
int i=0;
received[i]=c;
printf(“\n received=%c”,received[i]);
i++;
k++;
wait_ms(10);
        while(k==7)
        for (int j = 0; resStr[j] != '#'; j++)
            { //sending to main Nucleo F746ZG
            printf("ready to sending");
            receiver.putc(resStr[j]);
            printf("\n send= %c",resStr[j]);
            wait_ms(10);
        }       // Send back to main NUCLEO(done message);
these are my code,
be so kind use these symbols ``` before and after your code for corect formating
//my code
int main(){
   // do something
First this line is wrong
The readable methond return just bool so you cano not ask for a char.
//the i variable need to be somewhere else
int i=0;
// insde the loop
if(receiver.readable())
   if (c  !=‘$’) {
      // do something
   }else{
      // do something else
// rest...
hi
i will send 0and1 combination for one string ,that String Length are around 200 ,
// Sub Nucleo
#include “mbed.h”
#include"string.h"
char received=“”;
pc.baud(115200);
int k=0;
while (1)
int i=0;
received[i]=c;
i++;
k++;
wait_ms(10);
if(c==‘$’)
break;
        if(k==7)
            wait_ms(10);
i changed the code now also its not working,
You did only half. The i variable have to be outside of loop and set to zero inside whne the msg is complete.
hi i changed i variable also ,now also not working ,can you my code
// Sub Nucleo code
#include “mbed.h”
#include"string.h"
char received= “”;
pc.baud(115200);
int i=0;
while (1)
received[i]=c;
i++;
wait_ms(10);
if(c==‘$’)
i=0;
break;
Please I do not want to struggling with your code in this state, use code formatting (how i wrote above) for looks like below.
Try this.
#include"string.h"
char received[50]; // buffer with a size
    pc.baud(115200);
    pc.printf("Starting…\n\r");
    int i=0;
    while (1)
            //if(c != '$' && c != '#') //posible ignoring flags
            received[i++]=c;
            if(c == '$') //end of string detection
                received[i]= '\0';
                printf("received=%s\n",received);
                i=0;
        else wait_ms(10);
hi JohnnyK i tried this one also not Working my Nucleo F746ZG$AU1.
