I’m using U blox-C027 and I’m using 7 threads in my code. I’ve already define my threads as the following:
Thread GNSS_UDP(osPriorityNormal, 2000); //sending to the FMS the GNSS data
Thread GNSS_PB_UDP(osPriorityNormal, 2000); // Sending the Push button 1 with the GNSS data to the truck
Thread TCP_Server(osPriorityNormal, 2000); //TCP server thread FMS
Thread Temp_Sensor(osPriorityNormal, 2000); //TCP server thread FMS
//test threads
Thread Safety_Relay(osPriorityNormal, 2000);
Thread UDP_Socket(osPriorityNormal, 2000);
indent preformatted text by 4 spaces
I have athread for reading push button each 5ms and then sending the status of the push buttons via UDP socket as the following
void Safety_Relay_Thread()
printf("Safety \n\r");
//Inputs:
int Local_SB1_O3_press = 0;
int Local_SB2_O3_press = 0;
int Local_SK_S34_press_old = 0;
int Local_SK_S34_press_new;
int Local_SK_14_press = 0;
int Local_SK_24_press = 0;
int Local_SK_32_press =0;
const char* SB1_O3_Status = "OFF";
const char* SB2_O3_Status = "OFF";
const char* SK_S34_Status = "OFF";
const char* SK_14_Status = "OFF";
const char* SK_24_Status = "OFF";
const char* SK_32_Status = "OFF";
bool UDP_sending;
while(1)
Local_SB1_O3_press = SB1_O3;
Local_SB2_O3_press = SB2_O3;
Local_SK_S34_press_new = SK_S34;
Local_SK_14_press = SK_14;
Local_SK_24_press = SK_24;
Local_SK_32_press = SK_32;
SB1_O3_Mutex.lock () ;
SB1_O3_press = Local_SB1_O3_press;
SB1_O3_Mutex.unlock();
SB2_O3_Mutex.lock () ;
SB2_O3_press = Local_SB2_O3_press;
SB2_O3_Mutex.unlock();
SK_S34_Mutex.lock () ;
SK_S34_press_new = Local_SK_S34_press_new;
SK_S34_Mutex.unlock();
SK_14_Mutex.lock () ;
SK_14_press = Local_SK_14_press;
SK_14_Mutex.unlock();
SK_24_Mutex.lock () ;
SK_24_press = Local_SK_24_press;
SK_24_Mutex.unlock();
SK_32_Mutex.lock () ;
SK_32_press = Local_SK_32_press;
SK_32_Mutex.unlock();
if(Local_SB1_O3_press ==0)
SB1_O3_Status= "ON";
else
SB1_O3_Status= "OFF";
if(Local_SB2_O3_press ==0)
SB2_O3_Status= "ON";
else
SB2_O3_Status= "OFF";
if(Local_SK_S34_press_new ==1 && Local_SK_S34_press_old ==0)
SK_S34_Status= "ON";
SK_S34_press_old = SK_S34_press_new;
else
SK_S34_Status= "OFF";
if(Local_SK_14_press ==0)
SK_14_Status= "ON";
else
SK_14_Status= "OFF";
if(Local_SK_24_press ==0)
SK_24_Status= "ON";
else
SK_24_Status= "OFF";
if(Local_SK_32_press ==0)
SK_32_Status= "ON";
else
SK_32_Status= "OFF";
if(SB1_O3_Status== "ON"&& SB2_O3_Status== "ON"&&SK_14_Status=="ON" && SK_24_Status=="ON" && SK_32_Status=="OFF")
UDP_Socket.signal_set(0x1);
UDP_sending= true;
//printf("Safe\n\r");
sending_Mutex.lock();
sending_bool = UDP_sending;
sending_Mutex.unlock();
myled_01 = 1;
else
UDP_sending= false;
//printf("Emergency\n\r");
myled_01 = 0;
ThisThread::sleep_for(5);
void UDP_Socket_thread ()
printf("UDP_Socket \n\r");
const char* Local_recvIP;
int Local_PORT;
RceiverIP_Mutex.lock () ;
Local_recvIP = recvIP;
RceiverIP_Mutex.unlock();
ReceiverPort_Mutex.lock () ;
Local_PORT = PORT;
ReceiverPort_Mutex.unlock();
//char out_buffer[30];
//Inputs_Safety
//Status
bool Local_sending;
//address of destination ip address and port
SocketAddress td_addr(Local_recvIP, 4466);
UDPSocket td_sock;
Network_Mutex.lock();
td_sock.open(&net);
Network_Mutex.unlock();
while(true)
Thread::signal_wait(0x1);
Local_sending = sending_bool;
// printf("UDP start\n\r");
char* buffer = new char[40];
char* prefix = "";
//printf("Data \r\n");
if(Local_sending ==true)
//Buffer for output messages
strcpy(buffer, "Safe");
//myled_01 = 1;
else
strcpy(buffer, "Emergency");
//myled_01=0;
int ret = td_sock.sendto(td_addr, buffer, strlen(buffer));
//td_sock.close();
// ThisThread::sleep_for();
when I run my code and try to press the bush button I got this error
++ MbedOS Error Info ++
Error Status: 0x8001011F Code: 287 Module: 1
Er ror Message: Operator new[] out of memory
Error Value: 0x28
Current Thread: application_unnamed_thread Id: 0x10000BF8 Entry: 0xA6AD StackSize: 0x7D0 StackMem: 0x100067C8 SP: 0x10006E74
F or more info, visit: mbedos-error
– MbedOS Error Info –
Please your advise
