Using OS2 on Nucleo-F042K6 and scanf no longer works and blocks the program. It did not before.
I cannot use OS5 as the board does not look like its properly supported.
Mbed2 is not developed or maintained for years, so I do not believe it is Mbed library issue.
Please be so kind and describe some steps how to reproduce this issue in its simplest form and also your environment (IDE/Toolchain).
I am using Keil Studio Cloud
Created an empty program with:
#include"Serial.h"
DigitalOut myled(LED1);
Serial pc(USBTX,USBRX);
int i;
while(1) {
printf("before scanf");
scanf("%d", i);
myled = 1;
wait(0.2);
myled = 0;
wait(0.2);
I can see the printf but the LED never lights up…
This code worked few years back in the MBED studio days.
USBRX is defined as PA_15, this maybe wrong. Try Serial pc(PA_2, PA_3);
in the board page overview and in the schematics it is PA_3 for RX, this seems to be wrong for F031 as well.
But if I’m right, then it was wrong in Mbed2 already.
edit:
ok, PA_15 is correct. I got confused with the STLink on board, there it is PA_3. For the target MCU, PA_15 is correct.
Yeah it has to be correct as I can see the printf in teraterm.
Still cant get the scanf to not block the rest of the program
scanf is a blocking function, that is no bug.
It is reading chars until CR.
I do not remember the scanf was non-blocking anytime and also in pre-Mbed Studio time.
You can try also in simulator https://cplusplus.com/reference/cstdio/scanf/
Edit: Yeah, how Jojo wrote, there is a while loop what is waiting for CR.
