Please mbed support. Try to fix all the issues exist in the online compiler.
None of the export from the online compiler works for me when I export to (eclipse, or GNU MAKE).
I reported this issue before but nothing happens.
for example:
Each makefile I get from the online compiler contains this line
ASM_FLAGS += /filer/workspace_data/exports/0/0b56195140e36b1c83f4483fb903ae8c/NucleoBT_Module_copy/mbed_config.h
which is obvious that it should be like this
ASM_FLAGS += . . /mbed_config.h
Other issues I have, the export is not complete … It dosen’t compile sometimes… It is missing header or other files inside the makefile …etc
Many many issues that I cannot write down them all. So, please you need to use by yourself the online compiler and try to compile your code. Take a project with multiple library so you see the problems.
I hope you fix these issues … They have been there for a loooooooooong time … and I think it is time to fix it pleasesss!!
Using mbed-cli dosen’t work either … what are these problems?
[mbed] Updating library “mbed” to rev #34e6b704fe68
[mbed] Downloading library build “34e6b704fe68” (might take a while)
[mbed] ERROR: OS Error: The process cannot access the file because it is being used by another process
So, I am stuck here … I cannot compile my project, I cannot download, I tried to import mbed-dev … it dosen’t work either it generates “Gate time out …etc”
