I have a Nucleo-F411RE with an LCD 20x4 display with blue light background. I previously tested the module with STM32CubeIDE and it works pretty great.
I am trying to make it work with Mbed with the TextLCD library and after doing some debugging with the config files I was able to make it work but I still have a problem: The backlight is not turning ON. I can barely see the characters printed in the module but since the backlight is OFF it is difficult to check the outputs.
So my question is… How can I control this? Where I need to set up to turn on the backlight again? Is it possible that I still need to look for the proper setup for my display in the library? This is my configuration:
//Select Serial Port Expander Hardware module (one option only)
#define DEFAULT 0
#define ADAFRUIT 0
#define DFROBOT 1
#define LCM1602 0
#define YWROBOT 0
#define GYLCD 0
#define MJKDZ 0
#define SYDZ 0
#define WIDEHK 0
#define LCDPLUG 0
I hope to get some good suggestion from you guys!
#include "TextLCD.h"
// Host PC Communication channels
Serial pc(USBTX, USBRX); // tx, rx
// I2C Communication
I2C i2c_lcd(PB_9,PB_8); // SDA, SCL
TextLCD_I2C lcd(&i2c_lcd, 0x4E, TextLCD::LCD20x4); // I2C bus, PCF8574 Slaveaddress, LCD Type
lcd.printf("testing");
