I am on a rather special quest, that involves back porting STM32L5 target from the latest MBED-OS ie., 6.4.0 into an older version of MBED-Os, specifically mbed-os 5.12.1.
For this unusual task I have selected to first try on a bear-metal code example. What I have done sofare is:
- I have taken the latest mbed os- (6.4.0) and exported the beare metal application
- Ensured that I can compile and link using GCC_ARM for target MCU_STM32L562xE (check)
- Copied the entire folder to another location
- cd mbed os and “mbed update mbed-os-5.12.1” to move to an older version of mbed (Check)
- Copied the target.json together with the STm32L5 target code from the latest mbed os build to this folder
- compile and ensured that I can compile (need to copy and some more files), 100% compiled (check)
- now come the linker, here I get the following error:
Link: mbed-os-example-blinky-baremetal
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: No address assigned to the veneers output section .gnu.sgstubs
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: cannot size stub section: Invalid operation
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: …/BUILD/KWM2200/GCC_ARM/mbed-os-example-blinky-baremetal_application.elf: warning: allocated section .text' not in segment c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: ../BUILD/KWM2200/GCC_ARM/mbed-os-example-blinky-baremetal_application.elf: warning: allocated section .ARM.exidx’ not in segment
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: …/BUILD/KWM2200/GCC_ARM/mbed-os-example-blinky-baremetal_application.elf: warning: allocated section .data' not in segment collect2.exe: error: ld returned 1 exit status [ERROR] c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: No address assigned to the veneers output section .gnu.sgstubs c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: cannot size stub section: Invalid operation c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: ../BUILD/KWM2200/GCC_ARM/mbed-os-example-blinky-baremetal_application.elf: warning: allocated section .text’ not in segment
c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/…/lib/gcc/arm-none-eabi/6.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: …/BUILD/KWM2200/GCC_ARM/mbed-os-example-blinky-baremetal_application.elf: warning: allocated section .ARM.exidx' not in segment c:/program files (x86)/gnu tools arm embedded/6 2017-q2-update/bin/../lib/gcc/arm-none-eabi/6.3.1/../../../../arm-none-eabi/bin/ld.exe: ../BUILD/KWM2200/GCC_ARM/mbed-os-example-blinky-baremetal_application.elf: warning: allocated section .data’ not in segment
The linker script is the same as the one from mbed-os 6.4.0 … am i missing something here?
I assume this is something todo with " No address assigned to the veneers output section .gnu.sgstubs",
any idea of what this means and how I can fix it? ![]()
Edit: I can compile and link with IAR compiler, but not with GCC_ARM.
