Hi.
In trying to install MBed Studio for the first time, I just tried to run the following command in Konsole with the result shown.
$ sh MbedStudio-1.4.5.sh
MbedStudio-1.4.5.sh: 828: Syntax error: word unexpected (expecting ")")
Nor being familiar with Bash programming, I tried to run the updated installer with a similar result.
$ sh MbedStudio-1.4.6.sh
MbedStudio-1.4.6.sh: 828: Syntax error: word unexpected (expecting ")")
Is there an edit I can perform on line 828 of either install script that will allow the script to successfully install MBed Studio ?
Stuart
MACRUM
(Toyomasa Watarai)
June 16, 2024, 5:57am
2
As the 1st line of this script says, it reuqired bash rather than sh.
$ bash MbedStudio-1.4.6.sh
Or, run this script by adding execution attribute.
$ chmod +x ./MbedStudio-1.4.6.sh
$ ./MbedStudio-1.4.6.sh
Good morning MACRUM,
Thank you for your reply. Yes, I do have Bash installed. The second line of the script that you supplied (thank you!) is the way I did eventually go. After posting to this forum I then then(!!) found the install support on the Documentation section of this website. Is my face !
Thanks again for your help.
Stuart
