Problems using USB_DP and USB_DM pins on the NUCLEO-L432KC board
Hello everyone
I have a little problem with the NUCLEO-L432KC board. I want to implement serial communications between the board and the PC via USB but without using ST-LINK USB (USBTX, USBRX)
I want to implement it using the USB_DP and USB_DM pins. When trying to use USBSerial I get the error. “this board does not have a hardware USB driver”
Can you help me please?
The error is not exact, there is no problem with hardware but with drivers what were not implemented.
How I remember the USB DEVICE was not supported on this target.
You can verify that when you add this to thembed_app.json
    "target_overrides": {
            "target.device_has_add": ["USBDEVICE"]
and also DTR from PC serial monitor is required. But I think it is still not working.
Same issue
you will see
